Discuss
Frigidaire won't spin
 in
Washer Repair
I have a Frigidaire front loader that washes and drains but doesn't spin. Most threads online indicate the door lock
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidaire won't spin
  #1 (permalink)
Old 01-29-2013, 09:49 PM
Junior Member
elemakule is on a distinguished road
Default Frigidaire won't spin
Model Number: LTE2140ES3   Brand: Frigidaire   Age: 5 - 10 years
I have a Frigidaire front loader that washes and drains but doesn't spin. Most threads online indicate the door lock if an E47 code is displayed. This machine has blinking lights instead of LEDs and I can't tell if it's a 46 or 47 (it doesn't cycle the way the service guide says, just displays the error once then goes into the startup sequence). The door lock light comes on and the door does lock. Could it still be the door lock mechanism or is it more likely the motor control?
Ads By Google
Related Models
Whirlpool LTE5243BN0
Whirlpool LTE5243BN1
Whirlpool LTE5243BN2
Whirlpool LTE5243BW0
Whirlpool LTE5243BW1
Whirlpool LTE5243BW2
Whirlpool LTE5243DQ0
Whirlpool LTE5243DQ1
Whirlpool LTE5243DQ2
Whirlpool LTE5243DQ3
Whirlpool LTE5243DQ4 Washer/dryer Laundry System
Whirlpool LTE5243DQ5 Washer/dryer Laundry System
Whirlpool LTE5243DQ6 Washer/dryer Laundry System
Whirlpool LTE5243DQ7 Washer/dryer Laundry System
Whirlpool LTE5243DT2
Whirlpool LTE5243DT3
Whirlpool LTE5243DT4 Washer/dryer Laundry System
Whirlpool LTE5243DT5 Washer/dryer Laundry System
Whirlpool LTE5243DT6 Washer/dryer Laundry System
Whirlpool LTE5243DT7 Washer/dryer Laundry System
Whirlpool LTE5243DZ0
Whirlpool LTE5243DZ1
Whirlpool LTE5243DZ2
Whirlpool LTE5500W1
Whirlpool LTE6234AN0
Whirlpool LTE6234AN1
Whirlpool LTE6234AN2
Whirlpool LTE6234AN3
Whirlpool LTE6234AW0
Whirlpool LTE6234AW1
Whirlpool LTE6234AW2
Whirlpool LTE6234AW3
Whirlpool LTE6234DQ0
Whirlpool LTE6234DQ1
Whirlpool LTE6234DQ2
Whirlpool LTE6234DQ3 Washer/dryer Laundry System
Whirlpool LTE6234DQ4 Washer/dryer Laundry System
Whirlpool LTE6234DQ5 Washer/dryer Laundry System
Whirlpool LTE6234DQ6 Washer/dryer Laundry System
Whirlpool LTE6234DT2
Whirlpool LTE6234DT3 Washer/dryer Laundry System
Whirlpool LTE6234DT4 Washer/dryer Laundry System
Whirlpool LTE6234DT5 Washer/dryer Laundry System
Whirlpool LTE6234DT6 Washer/dryer Laundry System
Whirlpool LTE6234DZ0
Whirlpool LTE6234DZ1
Whirlpool LTE6234DZ2
Whirlpool LTE7245AN0
Whirlpool LTE7245AW0
Whirlpool LTE7800W1
Frigidaire LTF1670DS0 Frigidaire/washer
Admiral LTF1812ARB Ref - Top Mount
Admiral LTF1812ARW Ref - Top Mount
Admiral LTF1812ARZ Ref - Top Mount
Admiral LTF2112ARB Ref - Top Mount
Admiral LTF2112ARW Ref - Top Mount
Admiral LTF2112ARZ Ref - Top Mount
Frigidaire LTF2140ES0 Frigidaire/washer
Frigidaire LTF2140ES1 Frigidaire/washer
Frigidaire LTF2140ES2 Frigidaire/washer
Frigidaire LTF2140ES3 Frigidaire/washer
Frigidaire LTF2140FS0 Frigidaire/washer
Frigidaire LTF2940EE0 Frigidaire/washer
Frigidaire LTF2940ES0 Frigidaire/washer
Frigidaire LTF2940ES1 Frigidaire/washer
Frigidaire LTF2940ES2 Frigidaire/washer
Frigidaire LTF2940ES3 Frigidaire/washer
Frigidaire LTF2940FE0 Frigidaire/washer
Frigidaire LTF530DS0 Frigidaire/washer
Frigidaire LTF530DS1 Frigidaire/washer
Frigidaire LTF530FS0 Frigidaire/washer
Frigidaire LTF6000ES0 Frigidaire/washer
Frigidaire LTF6000ES1 Frigidaire/washer
Frigidaire LTF6000FS0 Frigidaire/washer
Frigidaire LTF7000EG0 Frigidaire/washer
Frigidaire LTF7000ES0 Frigidaire/washer
Frigidaire LTF7000ES1 Frigidaire/washer
Frigidaire LTF7000FG0 Frigidaire/washer
Whirlpool LTG5243BN0
Whirlpool LTG5243BN1
Whirlpool LTG5243BN2
Whirlpool LTG5243BW0
Whirlpool LTG5243BW1
Whirlpool LTG5243BW2
Whirlpool LTG5243DQ0
Whirlpool LTG5243DQ1
Whirlpool LTG5243DQ2
Whirlpool LTG5243DQ3
Whirlpool LTG5243DQ4 Washer/dryer Laundry System
Whirlpool LTG5243DQ5 Washer/dryer Laundry System
Whirlpool LTG5243DQ6 Washer/dryer Laundry System
Whirlpool LTG5243DQ7 Washer/dryer Laundry System
Whirlpool LTG5243DT2
Whirlpool LTG5243DT3
Whirlpool LTG5243DT4 Washer/dryer Laundry System
Whirlpool LTG5243DT5 Washer/dryer Laundry System
Whirlpool LTG5243DT6 Washer/dryer Laundry System
Whirlpool LTG5243DT7 Washer/dryer Laundry System
Whirlpool LTG5243DZ0
Whirlpool LTG5243DZ1
Whirlpool LTG5243DZ2
Whirlpool LTG6234AN0
Whirlpool LTG6234AN1
Whirlpool LTG6234AN2
Whirlpool LTG6234AN3
Whirlpool LTG6234AW0
Whirlpool LTG6234AW1
Whirlpool LTG6234AW2
Whirlpool LTG6234AW3
Whirlpool LTG6234DQ0
Whirlpool LTG6234DQ1
Whirlpool LTG6234DQ2 Washer/dryer Laundry System
Whirlpool LTG6234DQ3 Washer/dryer Laundry System
Whirlpool LTG6234DQ4 Washer/dryer Laundry System
Whirlpool LTG6234DQ5 Washer/dryer Laundry System
Whirlpool LTG6234DT1
Whirlpool LTG6234DT2 Washer/dryer Laundry System
Whirlpool LTG6234DT3 Washer/dryer Laundry System
Whirlpool LTG6234DT4 Washer/dryer Laundry System
Whirlpool LTG6234DT5 Washer/dryer Laundry System
  #2 (permalink)
Old 01-30-2013, 03:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
The model number you posted does not come up. Verify and repost it please.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 01-30-2013, 04:29 PM
Junior Member
Default
Apologies. That should read LTF20140ES3
  #4 (permalink)
Old 01-30-2013, 08:55 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The problem could be a bad door lock assembly if the control board does not see it's closed. You have to check it for continuity. Post the results as well as a picture of the old door lock. It will help to determine what you have to order in case the old door lock is bad.
Here are the breakdown diagrams and Parts for Frigidaire LTF2140ES3 Washer - AppliancePartsPros.com
__________________
  #5 (permalink)
Old 01-30-2013, 08:57 PM
Junior Member
Default
Okay. This is getting embarrassing. One more time. The correct model number is LTF2140ES3.
  #6 (permalink)
Old 01-30-2013, 09:01 PM
Junior Member
Default
So even if the door lock light comes on and the door actually locks, it could still be the door lock failing? (i.e. Not sending a signal to the control board?)
  #7 (permalink)
Old 01-30-2013, 10:13 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Yes, it is possible.
You can perform the diagnosis as instructed in the attached tech sheet to verify the error code.
__________________
  #8 (permalink)
Old 01-31-2013, 07:38 AM
Junior Member
Default
Thank you. I'll pull the switch and test it this weekend. Where it says, "Replace control board", is that the main control panel or the motor controller?
  #9 (permalink)
Old 02-01-2013, 02:37 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
It is the main control board.
- The main control board Part number: 137005000
- The door lock assembly Part number: 131763202
Frigidaire has redesigned the door lock and the original can be different. If this correct then you may need the new wire harness for the door lock.
- The wire harness Part number: 131882400
__________________
  #10 (permalink)
Old 02-01-2013, 08:55 PM
Junior Member
Default
Is it possible to tell if I would need the new wiring harness from the model and serial number? I don't mind spending $70 for the door lock but if it's going to be $200 for the lock and wiring harness, I may just buy a new machine. I've already replaced the control panel once, about 8 months ago. The machine is only 6 years old but I don't care to throw good money after bad.
Model# LTF2140ES3
Serial# XC61305766
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire won't spin out Soets1 Washer Repair 1 12-05-2012 05:07 PM
Spin cycle drains, but doesn't spin (Frigidaire Affinity) tsteinruck Washer Repair 5 04-23-2012 02:34 PM
Help, No Spin Frigidaire coxcassie Washer Repair 4 06-28-2011 06:06 PM
Frigidaire Gallery Series Won't Spin On Spin Cycle mosler Washer Repair 1 11-24-2010 02:13 PM
Frigidaire won't spin wtfarrer3 Washer Repair 4 02-02-2010 08:01 AM
