Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Frigidaire won't spin (http://forum.appliancepartspros.com/washer-repair/516793-frigidaire-wont-spin.html)
elemakule 01-29-2013 09:49 PM
I have a Frigidaire front loader that washes and drains but doesn't spin. Most threads online indicate the door lock if an E47 code is displayed. This machine has blinking lights instead of LEDs and I can't tell if it's a 46 or 47 (it doesn't cycle the way the service guide says, just displays the error once then goes into the startup sequence). The door lock light comes on and the door does lock. Could it still be the door lock mechanism or is it more likely the motor control?
Gene 01-30-2013 03:14 PM
Hello,
The model number you posted does not come up. Verify and repost it please.
elemakule 01-30-2013 04:29 PM
Apologies. That should read LTF20140ES3
Gene 01-30-2013 08:55 PM
The problem could be a bad door lock assembly if the control board does not see it's closed. You have to check it for continuity. Post the results as well as a picture of the old door lock. It will help to determine what you have to order in case the old door lock is bad.
Here are the breakdown diagrams and Parts for Frigidaire LTF2140ES3 Washer - AppliancePartsPros.com
elemakule 01-30-2013 08:57 PM
Okay. This is getting embarrassing. One more time. The correct model number is LTF2140ES3.
elemakule 01-30-2013 09:01 PM
So even if the door lock light comes on and the door actually locks, it could still be the door lock failing? (i.e. Not sending a signal to the control board?)
Gene 01-30-2013 10:13 PM
2 Attachment(s)
Yes, it is possible.
You can perform the diagnosis as instructed in the attached tech sheet to verify the error code.
elemakule 01-31-2013 07:38 AM
Thank you. I'll pull the switch and test it this weekend. Where it says, "Replace control board", is that the main control panel or the motor controller?
Gene 02-01-2013 02:37 PM
It is the main control board.
- The main control board Part number: 137005000
- The door lock assembly Part number: 131763202
Frigidaire has redesigned the door lock and the original can be different. If this correct then you may need the new wire harness for the door lock.
- The wire harness Part number: 131882400
elemakule 02-01-2013 08:55 PM
Is it possible to tell if I would need the new wiring harness from the model and serial number? I don't mind spending $70 for the door lock but if it's going to be $200 for the lock and wiring harness, I may just buy a new machine. I've already replaced the control panel once, about 8 months ago. The machine is only 6 years old but I don't care to throw good money after bad.
Model# LTF2140ES3
Serial# XC61305766
