| » Washer will drain but not spin |
Model Number: 970-C47072-10 Brand: Sears Age: 1 - 5 years
It's a front load washer. Works perfectly fine up to the final spin. It sounds like the motor is cutting in but it won't spin out the clothes. When the washer stops the clothes are soaking wet.
Hello,
The model number you posted does not come up. Verify and repost it please. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Kenmore, front load, 3.5 Super Capacity. Model number 970-C47072-10. The Sears repair guy called and said he would save us $60 for a visit by telling us that it is not an uncommon problem with this model and that its the sensor. Told us we are better off buying a new washer. Can't believe it. the washer is only 3 years old. It goes through the full wash but when it comes time to spin out in the end, it drains and sounds like it cuts in but the clothes just sit there. It won't spin. Any information you could give me would be a great help......
It looks to me like this is Canadian model. Is it? If that's correct then we don't have access to any technical information for non American models.
Based on my experience I can suspect the door switch/lock assembly. You can check it for continuity. The normal reading suppose to be about 1500 Ohms. Gene.
__________________
| Display Modes | |
| LG washer will not drain or spin | rangers02 | Washer Repair | 1 | 11-13-2011 06:30 PM |
| washer does not spin, fills up and drain the water nornal but do not spin | leaderman | Washer Repair | 0 | 10-04-2010 02:28 PM |
| My Hotpoint washer won't drain or spin, but it will if I drain the hose by gravity? | ks_becker | Washer Repair | 0 | 08-10-2010 10:25 AM |
| my washer doesn't spin or drain | monickm | Washer Repair | 1 | 04-07-2009 03:11 PM |
| washer will not drain for 1st spin cycle. Does finish with spin dry | tec6422 | Washer Repair | 1 | 01-23-2009 07:44 AM |
