Discuss
Neptune MAH3000AAW wont spin up and no door lock light
 in
Washer Repair
This washer has been repaired before with the R11 Q6 upgrade and a new wax motor with the black pintel.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Neptune MAH3000AAW wont spin up and no door lock light
  #1 (permalink)
Old 01-29-2013, 11:37 AM
Junior Member
scgt1 is on a distinguished road
Default Neptune MAH3000AAW wont spin up and no door lock light
Model Number: MAH3000AAW   Brand: Maytag   Age: More than 10 years
This washer has been repaired before with the R11 Q6 upgrade and a new wax motor with the black pintel. Now it is back to not doing the max extract high speed spin and the door lock light isn't lighting.
I have switched the two microswitches out with each other. I have jumped the door lock spin switch wires. When those are jumped it goes into high speed spin like it should.
I've ran through the test sequence lists as follows:
Does the door locked light illuminate NO
Restart does the wax motor extend NO
The Wax motor had somewhere around 1400OHMS I believe or 1600 I didn't write that value down. There is no 120VAC across the Wax motor when powered on and in spin cycle. I checked continuity between the wax motor and board P7(4)/BR14. My tested signaled there was continuity. Although wouldn't you want it to tone showing that there isn't a short in the wire from the board to the motor? The paperwork states it needs a new control board though.
Control board checks for voltage are as follows: (All are said to be 24VDC)
1. P3-1(RD23) to P5 =26.6VDC
2. P3-7(YL36) to P5 = 0VDC
3. P2-4(OR40) to P5 = 26.6VDC
4. P2-3(YL20) to P5 = 26.6VDC
I have also tested for continuity across the pins of the microswitches when the tab is pushed in and my tester alarms. So they both have continuity and a complete circuit when the pin is pressed in.
To test the Wax motor VAC I have used many different locations for my neutral location. Including the white 13 on the wax motor itself the white 13 on the door light and the orange 12 on the door light as well the neutral port on the control board itself. No where did it show a change on my meter. which was just a 1. So something isn't powering the wax motor to make the wax motor extend and activate the two microswitches.
I'm sure I'm missing tests here. These are what I could find by digging around.
Ads By Google
Related Models
Maytag MAH3000AAW Washer - Horizontal Axis
Maytag MAH3000AEW Washer - Horizontal Axis
International MAH3000AGW Washer - Horizontal Axis
International MAH3000AKW Washer - Horizontal Axis
Maytag MAH3000AWA Washer - Horizontal Axis
Maytag MAH3000AWQ Washer - Horizontal Axis
Maytag MAH3000AWW Washer - Horizontal Axis
International MAH3000BGW Washer - Horizontal Axis
Maytag MAH4000AWQ Washer - Horizontal Axis
Maytag MAH4000AWW Washer - Horizontal Axis
Maytag MAH4000BWQ Washer - Horizontal Axis
Maytag MAH4000BWW Washer - Horizontal Axis
Maytag MAH5500AWQ Washer - Horizontal Axis
Maytag MAH5500AWW Washer - Horizontal Axis
Maytag MAH5500BWQ Washer - Horizontal Axis
Maytag MAH5500BWW Washer - Horizontal Axis
Maytag MAH55FLBWQ Washer - Horizontal Axis
Maytag MAH55FLBWW Washer - Horizontal Axis
Maytag MAH6500AWQ Washer - Horizontal Axis
Maytag MAH6500AWW Washer - Horizontal Axis
Maytag MAH6700AWM Washer - Horizontal Axis
Maytag MAH6700AWW Washer - Horizontal Axis
Maytag MAH7500AWQ Washer - Horizontal Axis
Maytag MAH7500AWW Washer - Horizontal Axis
International MAH7550AAW Washer - Horizontal Axis
Maytag MAH7550AGW Washer - Horizontal Axis
International MAH7550AGW Washer - Horizontal Axis
Maytag MAH8700AWM Washer - Horizontal Axis
Maytag MAH8700AWW Washer - Horizontal Axis
Maytag MAH9700AWM Washer - Horizontal Axis
Maytag MAH9700AWQ Washer - Horizontal Axis
Maytag MAH9700AWW Washer - Horizontal Axis
Frigidaire MAL123P1A1 Wwh(v1) / Room Air Conditioner
Maytag MAL1800AXM Misc / Accessory
Maytag MAL1800AXQ Misc / Accessory
Maytag MAL1800AXW Misc / Accessory
Maytag MAL2000AXQ Misc / Accessory
Maytag MAL2000AXW Misc / Accessory
Frigidaire MAS183P2A1 Wwh(v1) / Room Air Conditioner
Maytag MAT10CSAAL Washer - Top Loading
Maytag MAT10CSAAW Washer - Top Loading
Maytag MAT10CSAGL Washer - Top Loading
Maytag MAT10CSAGW Washer - Top Loading
Maytag MAT10CSBKL Washer - Top Loading
Maytag MAT10CSEGL Washer - Top Loading
Maytag MAT10CSEGW Washer - Top Loading
Maytag MAT10DAAAL Washer - Top Loading
Maytag MAT10DAAAW Washer - Top Loading
Maytag MAT10DAABL Washer - Top Loading
Maytag MAT10DAABW Washer - Top Loading
Maytag MAT10PDAAL Washer - Top Loading
Maytag MAT10PDAAW Washer - Top Loading
Maytag MAT10PDABL Washer - Top Loading
Maytag MAT10PDABW Washer - Top Loading
Maytag MAT10PDEGW Washer - Top Loading
Maytag MAT10PSAAL Washer - Top Loading
Maytag MAT10PSAAW Washer - Top Loading
Maytag MAT10PSAGL Washer - Top Loading
Maytag MAT10PSAGW Washer - Top Loading
Maytag MAT11CSBKL Washer - Top Loading
Maytag MAT11MNAAW Washer - Top Loading
Maytag MAT11MNAGW Washer - Top Loading
Maytag MAT11MNEGW Washer - Top Loading
Maytag MAT11PDAAL Washer - Top Loading
Maytag MAT11PDAAW Washer - Top Loading
Maytag MAT11PDABL Washer - Top Loading
Maytag MAT11PDABW Washer - Top Loading
Maytag MAT12CSAAL Washer - Top Loading
Maytag MAT12CSAAQ Washer - Top Loading
Maytag MAT12CSAAW Washer - Top Loading
Maytag MAT12CSAGW Washer - Top Loading
Maytag MAT12CSAKL Washer - Top Loading
Maytag MAT12CSAKQ Washer - Top Loading
Maytag MAT12CSDAQ Washer - Top Loading
Maytag MAT12CSDAW Washer - Top Loading
Maytag MAT12CSDGW Washer - Top Loading
Maytag MAT12CSEGW Washer - Top Loading
Maytag MAT12CSFWQ Washer - Top Loading
Maytag MAT12CSFWW Washer - Top Loading
Maytag MAT12PDAAL Washer - Top Loading
Maytag MAT12PDAAW Washer - Top Loading
Maytag MAT12PDABL Washer - Top Loading
Maytag MAT12PDABW Washer - Top Loading
Maytag MAT12PDAGW Washer - Top Loading
Maytag MAT12PDBAL Washer - Top Loading
Maytag MAT12PDBAQ Washer - Top Loading
Maytag MAT12PDBAW Washer - Top Loading
Maytag MAT12PDBBL Washer - Top Loading
Maytag MAT12PDBBQ Washer - Top Loading
Maytag MAT12PDBBW Washer - Top Loading
Maytag MAT12PDCBL Washer - Top Loading
Maytag MAT12PDCBQ Washer - Top Loading
Maytag MAT12PDCBW Washer - Top Loading
Maytag MAT12PDDAQ Washer - Top Loading
Maytag MAT12PDDAW Washer - Top Loading
Maytag MAT12PDDBW Washer - Top Loading
Maytag MAT12PDDGW Washer - Top Loading
Maytag MAT12PDEGW Washer - Top Loading
Maytag MAT12PDLAQ Washer - Top Loading
Maytag MAT12PDLAW Washer - Top Loading
Maytag MAT12PDLGW Washer - Top Loading
Maytag MAT12PDSAW Washer - Top Loading
Maytag MAT12PRAAW Washer - Top Loading
Maytag MAT12PRAEW Washer - Top Loading
Maytag MAT12PRBAW Washer - Top Loading
Maytag MAT12PRDAW Washer - Top Loading
Maytag MAT12PRSAW Washer - Top Loading
Maytag MAT12PSAAW Washer - Top Loading
Maytag MAT12PSAGW Washer - Top Loading
Maytag MAT12PSBAW Washer - Top Loading
Maytag MAT12PSDAW Washer - Top Loading
Maytag MAT12PSLWQ Washer - Top Loading
Maytag MAT12PSLWW Washer - Top Loading
Maytag MAT13MNAAW Washer - Top Loading
Maytag MAT13MNAGW Washer - Top Loading
Maytag MAT13MNDAW Washer - Top Loading
Maytag MAT13MNDGW Washer - Top Loading
Maytag MAT13MNEGW Washer - Top Loading
Maytag MAT13PDAAW Washer - Top Loading
Maytag MAT13PDBAW Washer - Top Loading
  #2 (permalink)
Old 01-30-2013, 12:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
What is the serial number of the washer?
Did you check the control board for any discolorations due to a failed resistor (not limited to R11)?
The Wax motor normal resistance suppose to be about 1900 Ohms. Possible it is bad.
Quote:
...Control board checks for voltage are as follows: (All are said to be 24VDC)
4. P2-3(YL20) to P5 = 26.6VDC...
Where did you find these check points?
If you do have the tech sheet for the washer, can you post it please?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 01-30-2013, 01:15 PM
Junior Member
Default
31132822UU
No discolorations, leaking/seeping, bloated resistors. All contacts on back appear solid and no burn marks.
Just rechecked 1564 on the resistance
I could spend forever pulling it up again if needed but I took various checks from all over just copying them and pasting them in notepad then printing them out and going up the street to check my neighbors washer. Off had I have no idea where I found the checks. It may have been burried deep in ************************** or somewhere else.
I no longer have the pdf file for the service manual. But the section I have printed is the trouble shooting section copyright 1998 maytag corp Section 3 3-13. which shows the wheel for the timer. Then various trouble scenarios then the next section is the well basically a flow chart to find the problem. Which the sections I have are Washer will not spin then Maximum Spin Speed is not Reached. In my case the later refers to the first listed scenario. so 3-9 refers to 3-6.
Then is the component Exploded view. Although this sheet is copyright 2000 So my guess is I printed pages from a couple maytag sheets and stapled them together.
If your wanting me to scan these pages I can.
  #4 (permalink)
Old 01-30-2013, 08:23 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
That's what the Service manual says:
Quote:
...The purpose of the door lock mechanism is to secure the door during the spin cycle. When the door is shut, the wire loop on the door engages the rotating gear in the door lock mechanism. When the proper water level is reached and the pressure switch is satisfied, 120 VAC is applied to the wax motor...
You may want to verify proper operation of the pressure switch by checking it's terminals for continuity. If there is nothing wrong, check for 120 VAC at the wax motor terminals while the washer is in spin mode. If the voltage reading is incorrect, replace the control board.
- The pressure switch Part number: 22002921
Your washer made to use overseas and, if you use it there then the control board Part number: 22002917
__________________
  #5 (permalink)
Old 02-04-2013, 05:16 PM
Junior Member
Default
Wow never got an email stating that a reply was made to this thread. I was hopping in to update with some more tests I ran:
These VDC readings are taken with the Black #1 on the Line Relay being used as the common lead for voltage checks.
#1 to P3 pin 1 Should read 24VDC =26.6
#1 to P3 pin 7 Should read 24VDC = 00.1
#1 to P2 pin 4 Should read 24VDC = 26.6
P3 pin 1 is 24VDC out to the components (no DC volts, bad control board)
P3 pin 7 is 24VDC back from the spin enable switch(when the door is locked)
P2 pin 4 is VDC back from the tub off balance switches (any one switch will break the circuit)
#1 to P2 pin 3 Should read 24VDC =26.6
#1 to P2 pin 1 Should read 24vdc = 0 (I assume it was 0 because it wasn't the end of cycle)
These are return VDC from the option switch.
Yellow is the max extract selection and purple is the end of cycle buzzer.
#1 to P4 pin 3 Should read 24VDC = 26.7
#1 to P4 pin 1 Should read 24VDC =0
The VDC should fluctuate and increase to 24VDC as the motor RPM's increase.
Blue is out to motor control board and yellow is the power back to the control board. Red is tach circuit back to the control, you will have irratic readings until the motor rpm is consistant.
VAC checks using P5 as common
P5 to Gray wire on line relay Should read 120VAC =123.5
P5 to P1 pin 1 Should read 120VAC =69.1
P5 to blue #32 wire Should read 120VAC =34.1
P5 to Gray #33 Should read 120VAC =34.1
Gray is power into the control board from the door switch and you should have VAC whenever the door is closed (does not have to be locked) The P1 pin 1 purple wire at the control board is the water level switch return path no voltage would indicate a bad water level (pressure switch) and the washer won't spin
No VAC on the gray or blue wire at the switch would indicate a bad timer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Affinity washer wont start/door lock light stays off KEOKI369 Washer Repair 5 08-27-2012 03:11 PM
Maytag Neptune door Lock Paul F Washer Repair 0 10-27-2011 01:59 PM
Neptune doorlock wax motor works, but doesn't actuate lock light microswitch Pull Up Now! Washer Repair 0 05-09-2010 01:09 PM
maytag neptune door lock another mom Washer Repair 5 07-09-2009 04:50 PM
Door Lock Switch Neptune Robertydebbie Washer Repair 1 06-15-2009 06:04 PM
