| » Kenmore Washer stops |
Model Number: 110.22702100 Brand: Kenmore Age: 1 - 5 years
I have Kenmore 70 series washer that stops during cycle.
This is how it goes: Fills, agitates, timer dial progresses When it comes to the end of the first cycle where it should drain it stops and doesnt drain to go to the next cycle. If i slowly advance the dial just a hair or two it goes into drain/spin and dumps the water. It then fills up for the next cycle which I think is the rinse portion, then it agitates and spins out/drains on its own. Any help would be greatly appreciated. Ads By Google Related Models |
Quote:
If it was the lid switch, it wouldn't drain/spin at all, regardless of the position of the timer knob. There are a set of "bypass" contacts in the timer that bypass the water level pressure switch when it's time for drain/spin. The bypass contacts are in series with the lid switch. Both the bypass contacts and lid switch must be closed (and making good contact) in order for drain/spin to work. Apparently, the bypass contacts are not initially closing when they should. This not only kills power to the motor, it kills power to the timer motor, so the timer does not advance any further on it's own. Turning the knob manually a couple clicks is engaging the bypass contacts completing the circuit. Take a look at the schematic on the inside of the rear panel and you'll see the bypass contacts, labled "2" and the lid switch in series with each other. You could check these contacts with multimeter across the blk/wht and gry wires on the timer. When the timer gets to the rinse cycle, the same bypass contacts are used but a different part of the cam on the spool in the timer is closing these contacts.
Eric Last edited by fairbank56 : 01-28-2013 at 08:50 PM. |
Quote:
Is there a diagram out there to assit in this? Im great mechanically but im more of a picture or video guy when it comes to electrical items. |
Quote:
Thanks if totally missed it just pulling my head out with this. |
I tested the lid switch and it is good so I guess it would be the Timer then? Should I just replace it or is there a test for that also?
| Display Modes | |
| kenmore washer gets to driain or spin then stops | jmerp | Washer Repair | 1 | 12-10-2012 05:15 PM |
| Kenmore Elite washer agitates OK for 10 sec, then stops | wodag | Washer Repair | 11 | 11-21-2012 10:13 AM |
| Old kenmore 60 series washer stops in the middle of cycle | Wrgrky | Washer Repair | 1 | 07-05-2012 06:39 PM |
| Kenmore washer stops too quick after spin | f_barton | Washer Repair | 1 | 12-21-2011 06:55 PM |
| Kenmore washer stops after filling for rinse cycle | emb900 | Washer Repair | 1 | 07-30-2010 01:33 PM |
