| » Whirlpool Duet Sport Issues |
Model Number: WFW8300SW03 Brand: Whirlpool Age: 1 - 5 years
My Duet Sport washing machine has dim lights, including the digital display, it stops mid cycle and all the lights go out besides the Door Locked light. I've pulled the small front panel and the back panel and cannot see anything obvious that would cause this to happen. It gives no error codes at all. The dimness of the display lights is obvious when compared to the brightness of the dryers display lights. The Service Tech Manuel that is behind the small front panel gives no troubleshooting for the issue I'm having. When I unplug and replug the washer back into the outlet there is a click in the washer and I believe that is the CCU(?), which is supposed to happen. I'm not sure if there is a blown fuse or a bad relay but I haven't been able to locate any fuses or relay to check. Any help would be great.
After a little more tinkering around with it, I was able to get it to go into the diagnostics mode, where it recalls fault codes. It gave me in this order F33, F28, F24 and F34. Not sure why I got an F34 since I've never ran it in "cleaning cycle" with clothes in it. I'm assuming its one component that would make all of these items trip because in the 4 1/2 years I've had this washer I haven't had a single issue. Any help?
| Display Modes | |
| Whirlpool Duet Sport | tudocomprazer | Washer Repair | 2 | 05-14-2012 06:52 PM |
| Whirlpool Duet Sport | rmach | Washer Repair | 1 | 01-04-2012 01:41 PM |
| Whirlpool Duet Sport | rmach | Washer Repair | 1 | 01-04-2012 08:41 AM |
| Whirlpool Duet sport | Pat B | Washer Repair | 1 | 06-06-2011 12:41 PM |
| whirlpool duet sport | Deasley1 | Dryer Repair | 0 | 03-07-2011 07:14 PM |
