Discuss
2nd Agitation does not work
 in
Washer Repair
Washer works fine except for 1 thing. There use to be a 2nd agitation cycle after the first initial (what
Appliance Repair Forum > Appliance Repair Help > Washer Repair » 2nd Agitation does not work
  #1 (permalink)
Old 01-27-2013, 09:55 AM
Junior Member
GonzoDogBand is on a distinguished road
Question 2nd Agitation does not work
Model Number: A5530xsw1   Brand: Whirlpool   Age: More than 10 years
There use to be a 2nd agitation cycle after the first initial (what I would call "Hard" agitation) washing agitation. I guess you might call the 2nd cycle the "Normal Wash" portion of the wash.
The machine works as described...
1. Fills and 1st agitation cycle works.
2. When time comes for the "Normal" cycle it just sits there. You can hear the timer running but nothing from the motor area.
3. Drain cycle kicks in after the "Normal" cycle times out.
4. Fills for Rinse cycle
5. Rinses and drains
This machine is probably 25 - 30 years old. It is a solid machine of mostly metal parts and with the right maintainence and care should be repairable. I just don't know if it's the clutch or what. I'd like to get a better idea of what to look for before I start taking it apart.
Ads By Google
Related Models
Admiral A5651XRS Range - D/i Cont Clean Ele
Admiral A5892XRS Range - S/c D/i Ele
Admiral A5898VRV Range - S/c D/i Ele
Admiral A5898XRB Range - S/c D/i Ele
Admiral A59-5EXW-R Walloven - S/c Ele
Maytag A590 Washer - Top Loading
Maytag A590T Washer - Top Loading
Maytag A5910 Washer - Top Loading
Admiral A59E-5EXW-R Walloven - S/c Ele
Admiral A59F-5TXW-R Walloven - S/c Ele
Admiral A59F-5TXWM-R Walloven - S/c Mwave Ele
Admiral A59FN-5TVW-R Walloven - S/c Ele
Admiral A59FN-5TVWM-R Walloven - S/c Mwave Ele
Admiral A59G-5TXW-R Range - F/s Std Ele
Admiral A59GN-5TVW-R Range - F/s Std Ele
Frigidaire A5LECC2 Frg(v3) / Room Air Conditioner
Frigidaire A5LECDC2 Frg(v4) / Room Air Conditioner
Frigidaire A5LECDD2 Frg(v13) / Room Air Conditioner
Frigidaire A5LECDSD2 Frg(v14) / Room Air Conditioner
Frigidaire A5LECUC2 Frg(v12) / Room Air Conditioner
Maytag A606 Washer - Top Loading
Maytag A606S Washer - Top Loading
Maytag A608 Washer - Top Loading
Maytag A608S Washer - Top Loading
Maytag A610 Washer - Top Loading
Maytag A612 Washer - Top Loading
Maytag A612S Washer - Top Loading
Maytag A612ST Washer - Top Loading
Maytag A612T Washer - Top Loading
Maytag A613 Washer - Top Loading
Maytag A613T Washer - Top Loading
Admiral A6257XRS Range - S/i Cont Clean Gas
Jenn-Air A626 Misc / Accessory
Jenn-Air A626B Misc / Accessory
Jenn-Air A626W Misc / Accessory
Jenn-Air A627B Misc / Accessory
Jenn-Air A627W Misc / Accessory
Admiral A6498VRV Range - S/c S/i Gas
Admiral A6498XRS Range - S/c S/i Gas
Admiral A64HN-4TKVW-R Range - S/c S/i Gas
Admiral A6892XRS Range - S/c S/i Ele
Admiral A6898VRV Range - S/c S/i Ele
Admiral A6898XRB Range - S/c S/i Ele
Admiral A68HK-6TXW-R Range - S/c S/i Ele
Maytag A6910 Washer - Top Loading
Frigidaire A6LECC2 Frg(v5) / Room Air Conditioner
Frigidaire A6LECC3 Frg(v1) / Room Air Conditioner
Frigidaire A6LECD2 Frg(v15) / Room Air Conditioner
Frigidaire A6LECDC2 Frg(v13) / Room Air Conditioner
Frigidaire A6LECDC3 Frg(v14) / Room Air Conditioner
Frigidaire A6LECDD2 Frg(v16) / Room Air Conditioner
Frigidaire A6LECUD2 Frg(v17) / Room Air Conditioner
Frigidaire A6LECUSD2 Frg(v18) / Room Air Conditioner
Maytag A700 Washer - Top Loading
Maytag A700S Washer - Top Loading
Maytag A702 Washer - Top Loading
Maytag A702S Washer - Top Loading
Maytag A710 Washer - Top Loading
Maytag A710S Washer - Top Loading
Maytag A712 Washer - Top Loading
Maytag A712T Washer - Top Loading
Maytag A7300 Washer - Top Loading
Maytag A7400 Washer - Top Loading
Maytag A7500 Washer - Top Loading
Maytag A7500S Washer - Top Loading
Maytag A7500W Washer - Top Loading
Maytag A7800 Washer - Top Loading
Admiral A79E-5CXW Walloven - S/c Ele
Admiral A79F-5EXW-R Walloven - S/c Ele
Admiral A79FN-5EVW-R Walloven - S/c Ele
Frigidaire A7LECUD2 Frg(v19) / Room Air Conditioner
Maytag A806 Washer - Top Loading
Maytag A806S Washer - Top Loading
Maytag A810 Washer - Top Loading
Maytag A8100 Washer - Top Loading
Maytag A8120 Washer - Top Loading
Maytag A8140 Washer - Top Loading
Maytag A8200 Washer - Top Loading
Maytag A8210 Washer - Top Loading
Admiral A8210PA Surface Unit - Gas
Admiral A8210PA-L Surface Unit - Gas
Admiral A8210PT-L Surface Unit - Gas
Admiral A8210PW Surface Unit - Gas
Admiral A8210PW-L Surface Unit - Gas
Admiral A8211PA Surface Unit - Gas
Admiral A8211PS Surface Unit - Gas
Admiral A8211PW Surface Unit - Gas
Maytag A8240 Washer - Top Loading
Admiral A8241RA Surface Unit - Gas
Admiral A8241RA-L Surface Unit - Gas
Admiral A8241RS Surface Unit - Gas
Admiral A8241RT-L Surface Unit - Gas
Admiral A8241RV Surface Unit - Gas
Admiral A8241RW Surface Unit - Gas
Admiral A8241RW-L Surface Unit - Gas
Admiral A8261RB Surface Unit - Gas
Admiral A8261RV Surface Unit - Gas
Admiral A82LK-3K-R Surface Unit - Gas
Admiral A82LN-3K-R Surface Unit - Gas
Admiral A82LW-2K-R Surface Unit - Gas
Admiral A82R1RV Surface Unit - Gas
Admiral A8321PA Surface Unit - Gas
Admiral A8321PS Surface Unit - Gas
Admiral A8321PW Surface Unit - Gas
Admiral A8321TA-L Surface Unit - Gas
Admiral A8321TW-L Surface Unit - Gas
Maytag A8340 Washer - Top Loading
Maytag A8420 Washer - Top Loading
Maytag A8440 Washer - Top Loading
Maytag A8500 Washer - Top Loading
Maytag A8520 Washer - Top Loading
Maytag A8600 Washer - Top Loading
Admiral A8610PA Surface Unit - Ele
Admiral A8610PS Surface Unit - Ele
Admiral A8610PV Surface Unit - Ele
Maytag A8640 Washer - Top Loading
Maytag A8650 Washer - Top Loading
Admiral A8670PB Surface Unit - Ele
Admiral A8670PV Surface Unit - Ele
Admiral A86LW-1-R Surface Unit - Ele
  #2 (permalink)
Old 01-27-2013, 11:00 AM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
Can't help you but if no other response here, you might try this forum for older appliances.
Eric
  #3 (permalink)
Old 01-27-2013, 11:21 AM
Junior Member
Default
Thanks! I didn't see the other forum for older machines.
My spin cycle has become slower too which from what I'm reading, the most obvious culprit is the clutch assemby. I think I'm gonna jump in and replace that and while I'm in there I'll look to see if I can get a visual on anything else that might seem out of place or broken.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE top load washer make grinding noise during agitation and spin, but work fine, just dchanson55 Washer Repair 27 02-12-2013 05:23 AM
no agitation winder68 Washer Repair 0 03-12-2011 09:22 AM
no agitation winder68 Washer Repair 0 03-12-2011 09:21 AM
Agitation tom wells Washer Repair 0 12-30-2010 01:58 PM
Agitation! fjrbob Washer Repair 0 01-05-2009 11:33 AM
