washer overflows and unbalance load displayed
Here is the problem that i am having with this washer it automatically selects the water level by sensing the load being washed but it will overflow if allowed on the automatic fill setting and if you select the manual setting it will not over fill and also it will display unbalance load while during the spin cycle
I would first take off the back and check the supports, one or more may be broken and causing your problem. Not likely but check anyway just to rule that out.
I think the next place to go is the control unit, but you will probably have to replace it to determine if that is the problem. If you buy from this site you can return the part if it is not needed. |
problem found its is not an overflow but rather a leak underneath the bottom of the tub located the part and decided to replace the washer rather than repair it.
With that model that's a great decision. Good luck and thanks for updating us.
| All times are GMT -7. The time now is 04:55 PM. |
