Discuss
Kenmore Washer
 in
Washer Repair
My Kenmore washer will not spin during a normal cycle (i.e. put the clothes in, add the soap and turn
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Washer
  #1 (permalink)
Old 01-26-2013, 08:50 AM
Junior Member
juli0923 is on a distinguished road
Default Kenmore Washer
Model Number: 11023832100   Brand: Kenmore   Age: More than 10 years
My Kenmore washer will not spin during a normal cycle (i.e. put the clothes in, add the soap and turn it on to wash) it agitates just fine, rinses and drains but then when it should spin the water out of the clothes it just sits there. When the cycle is complete, I can turn the dial back to spin and it will spin just fine- I just have to manually reset it to spin. The lid switch was replaced a couple years ago so I don't think that is the problem. I have read it could be the timer, clutch or trasmission. I can fix it myself if I could just figure out what to fix.
Related Models
Kenmore 11023832100 AUTOMATIC WASHER
Kenmore 11023902200 AUTOMATIC WASHER
Kenmore 11023902201 AUTOMATIC WASHER
Kenmore 11023904200 AUTOMATIC WASHER
Kenmore 11023904201 AUTOMATIC WASHER
Kenmore 11023912100 AUTOMATIC WASHER
Kenmore 11023912101 AUTOMATIC WASHER
Kenmore 11023912102 AUTOMATIC WASHER
Kenmore 11023922200 AUTOMATIC WASHER
Kenmore 11023922201 AUTOMATIC WASHER
Kenmore 11023924200 AUTOMATIC WASHER
Kenmore 11023924201 AUTOMATIC WASHER
Kenmore 11023932200 WASHER
Kenmore 11023934200 WASHER
Kenmore 11024032301 AUTOMATIC WASHER
Kenmore 11024036301 AUTOMATIC WASHER
Kenmore 11024042301 AUTOMATIC WASHER
Kenmore 11024052300 AUTOMATIC WASHER
Kenmore 11024054300 AUTOMATIC WASHER
Kenmore 11024056300 AUTOMATIC WASHER
Kenmore 11024082200 AUTOMATIC WASHER
Kenmore 11024084200 AUTOMATIC WASHER
Kenmore 11024086200 AUTOMATIC WASHER
Kenmore 11024292300 AUTOMATIC WASHER
Kenmore 11024294300 AUTOMATIC WASHER
Kenmore 11024422300 AUTOMATIC WASHER
Kenmore 11024432300 AUTOMATIC WASHER
Kenmore 11024442300 AUTOMATIC WASHER
Kenmore 11024622300 AUTOMATIC WASHER
Kenmore 11024632300 AUTOMATIC WASHER
Kenmore 11024642300 AUTOMATIC WASHER
Kenmore 11024652300 AUTOMATIC WASHER
Kenmore 11024662300 AUTOMATIC WASHER
Kenmore 11024692300 AUTOMATIC WASHER
Kenmore 11024712300 AUTOMATIC WASHER
Kenmore 11024722300 AUTOMATIC WASHER
Kenmore 11024732300 AUTOMATIC WASHER
Kenmore 11024812200 AUTOMATIC WASHER
Kenmore 11024812201 AUTOMATIC WASHER
Kenmore 11024822200 AUTOMATIC WASHER
Kenmore 11024822201 AUTOMATIC WASHER
Kenmore 11024832200 AUTOMATIC WASHER
Kenmore 11024832201 AUTOMATIC WASHER
Kenmore 11024852300 AUTOMATIC WASHER
Kenmore 11024862300 AUTOMATIC WASHER
Kenmore 11024872300 AUTOMATIC WASHER
Kenmore 11024892300 AUTOMATIC
Kenmore 11024894300 AUTOMATIC
Kenmore 11024902200 AUTOMATIC WASHER
Kenmore 11024902201 AUTOMATIC WASHER
Kenmore 11024902202 AUTOMATIC WASHER
Kenmore 11024904200 AUTOMATIC WASHER
Kenmore 11024904201 AUTOMATIC WASHER
Kenmore 11024904202 AUTOMATIC WASHER
Kenmore 11024922200 AUTOMATIC WASHER
Kenmore 11024922201 AUTOMATIC WASHER
Kenmore 11024922202 AUTOMATIC WASHER
Kenmore 11024924200 AUTOMATIC WASHER
Kenmore 11024924201 AUTOMATIC WASHER
Kenmore 11024924202 AUTOMATIC WASHER
Kenmore 11024932200 AUTOMATIC WASHER
Kenmore 11024932201 AUTOMATIC WASHER
Kenmore 11024932202 AUTOMATIC WASHER
Kenmore 11024934200 AUTOMATIC WASHER
Kenmore 11024934201 AUTOMATIC WASHER
Kenmore 11024934202 AUTOMATIC WASHER
Kenmore 11024942300 AUTOMATIC WASHER
Kenmore 11024942301 RESIDENTIAL WASHER
Kenmore 11024944300 AUTOMATIC WASHER
Kenmore 11024944301 RESIDENTIAL WASHER
Kenmore 11024946300 AUTOMATIC WASHER
Kenmore 11024946301 RESIDENTIAL WASHER
Kenmore 11024952300 AUTOMATIC WASHER
Kenmore 11024952301 RESIDENTIAL WASHER
Kenmore 11024954300 AUTOMATIC WASHER
Kenmore 11024954301 RESIDENTIAL WASHER
Kenmore 11024956300 AUTOMATIC WASHER
Kenmore 11024956301 RESIDENTIAL WASHER
Kenmore 11024962300 AUTOMATIC WASHER
Kenmore 11024962301 RESIDENTIAL WASHER
Kenmore 11024964300 AUTOMATIC WASHER
Kenmore 11024964301 RESIDENTIAL WASHER
Kenmore 11024966300 AUTOMATIC WASHER
Kenmore 11024966301 RESIDENTIAL WASHER
Kenmore 11024972300 AUTOMATIC WASHER
Kenmore 11024974300 AUTOMATIC WASHER
Kenmore 11024982300 AUTOMATIC WASHER
Kenmore 11024992300 AUTOMATIC WASHER
Kenmore 11024994300 AUTOMATIC WASHER
Kenmore 11024996300 AUTOMATIC WASHER
Kenmore 11025062500 WASHER
Kenmore 11025064500 WASHER
Kenmore 11025066500 WASHER
Kenmore 11025292500 WASHER
Kenmore 11025292501 WASHER
Kenmore 11025292502 RESIDENTIAL WASHER
Kenmore 11025292503 RESIDENTIAL WASHER
Kenmore 11025294500 WASHER
Kenmore 11025294501 WASHER
Kenmore 11025294502 RESIDENTIAL WASHER
Kenmore 11025294503 RESIDENTIAL WASHER
Kenmore 11025832400 RESIDENTIAL WASHER
Kenmore 11025842400 AUTOMATIC WASHER
Kenmore 11025844400 AUTOMATIC WASHER
Kenmore 11025852400 AUTOMATIC WASHER
Kenmore 11025854400 AUTOMATIC WASHER
Kenmore 11025862400 AUTOMATIC WASHER
Kenmore 11025864400 AUTOMATIC WASHER
Kenmore 11026002010 AUTOMATIC WASHER
Kenmore 11026002011 AUTOMATIC WASHER
Kenmore 11026012010 AUTOMATIC WASHER
Kenmore 11026012011 AUTOMATIC WASHER
Kenmore 11026051690 COMMERCIAL AUTOMATIC WASHER
Kenmore 11026058690 COMMERCIAL AUTOMATIC WASHER
Kenmore 11026071690 COMMERCIAL WASHER
Kenmore 11026071691 COMMERCIAL WASHER
Kenmore 11026152500 WASHER COMMERCIAL
Kenmore 11026292690 AUTOMATIC WASHER
Kenmore 11026292691 AUTOMATIC WASHER
Kenmore 11026292692 AUTOMATIC WASHER
  #2 (permalink)
Old 01-27-2013, 06:02 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
This really does sound like the timer, so change it out and see if that fixes things.
If you buy from this site and the timer does not fix the problem you can return it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore washer william fischer reed Washer Repair 13 10-27-2011 09:37 AM
kenmore washer-installing clips for the top of the washer donnadean Washer Repair 1 02-17-2010 11:49 AM
Kenmore elite washer is leaking under washer cbs Washer Repair 1 07-12-2009 06:27 PM
Help with Kenmore washer Dan Thomas Washer Repair 0 07-04-2008 02:15 PM
kenmore washer DeeWayne Washer Repair 0 03-08-2008 12:19 PM
