Discuss
Rinse - low water level - 2 Water Level Switches...
 in
Washer Repair
Hello! I'm trying to fix a friends Washing machine. It's an ESTATE. I'm studying major appliance repair. It is NOT
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Rinse - low water level - 2 Water Level Switches...
  #1 (permalink)
Old 01-25-2013, 05:20 AM
Junior Member
Aleste is on a distinguished road
Default Rinse - low water level - 2 Water Level Switches...
Model Number: ETW4400XQ0   Brand: Estate   Age: Less than 1 year
Hello! I'm trying to fix a friends Washing machine. It's an ESTATE. I'm studying major appliance repair. It is NOT EASY!
The Washer uses 2 Water Level Switches (WPS) that seem to be used either during the Wash or Rinse function respectively according to the Techsheet. I would think that one of the WLS's is faulty but am not sure. I've called to try and buy the parts but have only been able to locate 1 of the WPS. One person told me to get only one switch or that it was no longer available. Both WPS's are joined with a "Y" shaped pressure hose that connects the the Pressure Dome. I've cleaned out the hoses and screens already. sooo...
The suspected WPS number is C13143599
Can you tell me what's wrong and what parts to get. Thank you.
Ads By Google
Related Models
Whirlpool FGP335EQ0
Whirlpool FGP335EW0
Whirlpool FGP335GN0
Whirlpool FGP335GN1
Whirlpool FGP335GQ0
Whirlpool FGP335GQ1
Whirlpool FGP335GW0
Whirlpool FGP335GW1
Whirlpool FGP335HN0
Whirlpool FGP335HQ0
Whirlpool FGP335HW0
Whirlpool FGP335VL0
Whirlpool FGP335VL1
Whirlpool FGP335VL2
Whirlpool FGP335VL3
Whirlpool FGP335VW0
Whirlpool FGP335VW1
Whirlpool FGP335VW2
Whirlpool FGP335VW3
Whirlpool FGP335YL0
Whirlpool FGP335YL1
Whirlpool FGP335YL2
Whirlpool FGP335YW0
Whirlpool FGP335YW1
Whirlpool FGP335YW2
Whirlpool FGP337GN0
Whirlpool FGP337GN1
Whirlpool FGP337GN5
Whirlpool FGP337GQ0
Whirlpool FGP337GQ1
Whirlpool FGP337GQ5
Whirlpool FGP337GW0
Whirlpool FGP337GW1
Whirlpool FGP337GW5
Whirlpool FGP337HN0
Whirlpool FGP337HQ0
Whirlpool FGP337HW0
Whirlpool FGP337KN0
Whirlpool FGP337KQ0
Whirlpool FGP337KW0
Whirlpool FGP337KW1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool FGP345VL0
Whirlpool FGP345VL1
Whirlpool FGP345VL2
Whirlpool FGP345VW0
Whirlpool FGP345VW1
Whirlpool FGP345VW2
Whirlpool FGP345YL0
Whirlpool FGP345YW0
Whirlpool FGP355VL0
Whirlpool FGP355VL1
Whirlpool FGP355VL2
Whirlpool FGP355VL3
Whirlpool FGP355VW0
Whirlpool FGP355VW1
Whirlpool FGP355VW2
Whirlpool FGP355VW3
Whirlpool FGP355YL0
Whirlpool FGP355YW0
Whirlpool FGP357XL0
Whirlpool FGP357XW0
Whirlpool FGP357YL0
Whirlpool FGP357YL1
Whirlpool FGP357YL3
Whirlpool FGP357YW0
Whirlpool FGP357YW1
Whirlpool FGP357YW2
Whirlpool FGP357YW3
Frigidaire FGQ1442ES0 Frigidaire/dryer
Frigidaire FGQ332ES0 Frigidaire/gas Dryer
Frigidaire FGQB2152FE0 Frigidaire/dryer
Frigidaire FGQB4000FS0 Frigidaire/dryer
Frigidaire FGQBB30DS0 Frigidaire/dryer
Frigidaire FGR211AS0 Dryer - Frigidaire
Frigidaire FGR211AS1 Dryer - Frigidaire
Frigidaire FGR211AS2 Frigidaire/gas Dryer
Frigidaire FGR211AS3 Frigidaire/gas Dryer
Frigidaire FGR211AS4 Frigidaire/dryer
Frigidaire FGR211MAS0 Frigidaire/dryer
Frigidaire FGR221AS0 Dryer - Frigidaire
Frigidaire FGR231AS0 Dryer - Frigidaire
Frigidaire FGR231AS1 Dryer - Frigidaire
Frigidaire FGR231AS2 Frigidaire/dryer
Frigidaire FGR231AS3 Frigidaire/gas Dryer
Frigidaire FGR231AS4 Frigidaire/dryer
Frigidaire FGR231CAS4 Frigidaire/dryer
Frigidaire FGR311FS0 Frigidaire/dryer
Frigidaire FGR331AS0 Dryer - Frigidaire
Frigidaire FGR331AS1 Dryer - Frigidaire
Frigidaire FGR331KAS1 Frigidaire/gas Dryer
Frigidaire FGR341AC0 Frigidaire/dryer
Frigidaire FGR341AC1 Frigidaire/dryer
Frigidaire FGR341AS0 Dryer - Frigidaire
Frigidaire FGR341AS1 Dryer - Frigidaire
Frigidaire FGR641FS0 Frigidaire/dryer
Frigidaire FGR6600ES0 Frigidaire/dryer
Frigidaire FGR6600FS0 Frigidaire/dryer
Frigidaire FGRB5700DS0 Frigidaire/dryer
Frigidaire FGRB6600ES0 Frigidaire/dryer
Frigidaire FGRB6600FS0 Frigidaire/dryer
Frigidaire FGRB7800DS0 Frigidaire/dryer
Whirlpool FGS325RQ0 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ1 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD0 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD1 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD3 30" Gas Freestanding Self Clean Range
Whirlpool FGS335EN0
Whirlpool FGS335EQ0
Whirlpool FGS335EW0
Whirlpool FGS337GN0
Whirlpool FGS337GN1
Whirlpool FGS337GN5
Whirlpool FGS337GQ0
Whirlpool FGS337GQ1
Whirlpool FGS337GQ5
Whirlpool FGS337GQ6
Whirlpool FGS337GQ7
Whirlpool FGS337GW0
  #2 (permalink)
Old 01-25-2013, 06:17 AM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
This is probably normal. This washer complies with 2011 energy standards and uses much less water than a traditional one. It is likely that it is supposed to use less water for the rinse cycle than the wash cycle and the reason it has two pressure switches.
Eric
  #3 (permalink)
Old 01-25-2013, 07:43 AM
Junior Member
Default
Ok. I guess I'll take that answer but It's an old looking DIRECT DRIVE washer. something old complies with new regulations. I guess you should mark this fixed. BTW is there anyway you can mark this fixed. I've seen other forums have that option... just wondering. No bigee
  #4 (permalink)
Old 01-25-2013, 08:27 AM
Expert
APP Volunteer
Default
Yes, it's a direct drive design but the X in the model number indicates it's a 2010 model. If you can give the serial number, I can give the exact date of manufacture of the washer. There have been other complaints about the low rinse level and the answer given by the "experts" is that this is normal operation. The part number for the switch assembly is W10403282 and consists of both switches, hoses and tee connection. One switch has a stem on it for the control knob on the front panel and the other switch has the stem removed and is set for low level.
The government thinks we are saving all this water and energy not realizing so many people are having to run extra rinse cycles or washing twice just to get the clothes clean and/or the soap out. The energy/water requirements will be even tighter in 2015. All the more reason to keep your pre 2007 washer going no matter the cost.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Inadequate water level for rinse cycle KatMed Washer Repair 1 04-11-2012 11:52 AM
How to change the water level in the rinse cycle juansh1969 Washer Repair 3 03-14-2012 11:38 AM
water level on rinse cycle juansh1969 Washer Repair 1 03-07-2012 07:45 AM
Two water level switches bad in 12 months? jfwilliams3 Washer Repair 3 08-01-2011 09:49 AM
