F51 Code still after replace RPS sensor
I have a MAytag Bravos MTW6700Tq1 HE washer. I performed diagonistic chedck and get code F51 and F-41 Codes. I replaced RPS sensor but still get code and washer will not spin. I did not replace as kit and did not replace harness. Did I need to?
1 Attachment(s)
Hello,
Did you perform the test #3 on page 4 as instructed in the Tech sheet before you replaced RPS? If you did not then do it now. The Tech sheet is attached to the post. Here are the breakdown diagrams and Parts for Maytag MTW6700TQ1 Washer - AppliancePartsPros.com Gene. |
| All times are GMT -7. The time now is 04:06 AM. |
