| » Agitator jerks back and forth and makes loud banging sound while in spin cycle. |
Model Number: 110.28932790 Brand: Kenmore Age: 5 - 10 years
Washer agitates fine when in washing mode but when it goes into spin cycle there is a loud grinding and banging sound coming from agitator, when it is spinning the agitator is bouncing back and forth making those sounds, if i place my hand on top of agitator and press down or hold agitator from spining noise stops
can you help. Ads By Google Related Models |
Hi.
Remove the agitator and run the washer without it.Observe the shaft while the washer in the spin, does it turns? If it turns, can you stop it if you hold it? If the transmission shaft turns when the washer is in the spin then it's the bad transmission. If the shaft is not turning you should check the agitator's splines and replace if needed Part number: 3947517 The transmission Part number: 3360629 Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Spins Cycle makes a semi-loud humming sound | deanvanvu | Washer Repair | 5 | 05-04-2012 12:47 PM |
| Front load washer makes a loud whining sound during spin/rinse cycle | ecrouch1121 | Washer Repair | 0 | 01-02-2011 08:43 PM |
| Loud Banging at END of EVERY Spin Cycle | TheGD | Washer Repair | 3 | 11-04-2010 07:06 AM |
| makes loud banging while in spin, does not spin fast | shaggylong | Washer Repair | 2 | 01-30-2009 02:29 AM |
| Agitator makes loud "smashing sound" during spin cycle | Spug | Washer Repair | 3 | 04-06-2008 05:43 PM |
