Discuss
Transmission Troubleshoot!!!
 in
Washer Repair
I've been able to troubleshoot my maytag washer as the washer was not spinning. My motor needs to be replaced
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Transmission Troubleshoot!!!
  #1 (permalink)
Old 01-23-2013, 08:51 PM
Junior Member
DanielJS is on a distinguished road
Question Transmission Troubleshoot!!!
Model Number: LAT9406AAE   Brand: Maytag   Age: More than 10 years
I've been able to troubleshoot my maytag washer as the washer was not spinning. My motor needs to be replaced since i need to either nudge it to make it spin or move the pulley to get it to spin. If I take off the pulleys, the motor still won't kick in unless I gently hit the motor. So without my assistance, the motor will not spin and just make a loud buzzing noise.
Before I replace the motor, I was concerned if the transmission is what caused my motor to fail. I don't want the new motor to fail as well if the real problem was something else so that is why I'm checking to see if the transmission is okay.
I did a quick check on my transmission by taking off the pulleys and I was able to turn the transmission wheel underneath the washer easily counter clockwise. But when I turned it clockwise, it would turn (not as easily as counter clockwise) but after a couple quarter turns, the orbital transmission would also turn (Is that what should happen?). When I kept turning clockwise, it sounded like something inside the orbital transmission was knocking. Should that be happening? I'm hoping that its just the motor that needs to be replaced and my transmission is okay. Any comments? or suggestions for how to check the transmission or anything else I should be checking?
(the pump is clear, the lid switch assembly is working, the timer is working).
Thank you,
daniel
Ads By Google
Related Models
Maytag LAT9406AAE Washer - Top Loading
Maytag LAT9406AAM Washer - Top Loading
Maytag LAT9406ABE Washer - Top Loading
Maytag LAT9416AAE Washer - Top Loading
Maytag LAT9416AAM Washer - Top Loading
Maytag LAT9416AAQ Washer - Top Loading
Maytag LAT9420AAE Washer - Top Loading
Maytag LAT9457AAE Washer - Top Loading
Maytag LAT9457AAM Washer - Top Loading
Maytag LAT9457AAQ Washer - Top Loading
Maytag LAT9457BAE Washer - Top Loading
Maytag LAT9520AAE Washer - Top Loading
Maytag LAT9520AAQ Washer - Top Loading
Maytag LAT9557AAE Washer - Top Loading
Maytag LAT9557AAM Washer - Top Loading
Maytag LAT9557AAQ Washer - Top Loading
Maytag LAT9593AAL Washer - Top Loading
Maytag LAT9593AAW Washer - Top Loading
Maytag LAT9593ABL Washer - Top Loading
Maytag LAT9593ABW Washer - Top Loading
Maytag LAT9600AAL Washer - Top Loading
Maytag LAT9600AAW Washer - Top Loading
Maytag LAT9600ABL Washer - Top Loading
Maytag LAT9600ABW Washer - Top Loading
Maytag LAT9604AAE Washer - Top Loading
Maytag LAT9604AAL Washer - Top Loading
Maytag LAT9604AAM Washer - Top Loading
Maytag LAT9604ABE Washer - Top Loading
Maytag LAT9604ABL Washer - Top Loading
Maytag LAT9605AAE Washer - Top Loading
Maytag LAT9605AAM Washer - Top Loading
Maytag LAT9606AAE Washer - Top Loading
Maytag LAT9606AAM Washer - Top Loading
Maytag LAT9606ABE Washer - Top Loading
Maytag LAT9606ABM Washer - Top Loading
International LAT9606AGE Washer - Top Loading
International LAT9606BGE Washer - Top Loading
International LAT9606GGE Washer - Top Loading
Maytag LAT9614AAE Washer - Top Loading
Maytag LAT9614AAL Washer - Top Loading
Maytag LAT9614AAM Washer - Top Loading
Maytag LAT9615AAE Washer - Top Loading
Maytag LAT9615AAM Washer - Top Loading
Maytag LAT9616AAE Washer - Top Loading
Maytag LAT9616AAM Washer - Top Loading
Maytag LAT9634AAE Washer - Top Loading
Maytag LAT9634AAL Washer - Top Loading
Maytag LAT9634AAM Washer - Top Loading
Maytag LAT9634ABE Washer - Top Loading
Maytag LAT9635AAE Washer - Top Loading
Maytag LAT9635AAM Washer - Top Loading
Maytag LAT9700AAG Washer - Top Loading
Maytag LAT9700AAL Washer - Top Loading
Maytag LAT9700AAW Washer - Top Loading
Maytag LAT9700AAX Washer - Top Loading
Maytag LAT9700ABL Washer - Top Loading
Maytag LAT9700ABW Washer - Top Loading
Maytag LAT9700DAG Washer - Top Loading
Maytag LAT9700DAL Washer - Top Loading
Maytag LAT9700DAW Washer - Top Loading
Maytag LAT9704AAE Washer - Top Loading
Maytag LAT9704AAL Washer - Top Loading
Maytag LAT9704AAM Washer - Top Loading
Maytag LAT9704ABE Washer - Top Loading
Maytag LAT9704ABL Washer - Top Loading
Maytag LAT9704ABM Washer - Top Loading
International LAT9704AGE Washer - Top Loading
International LAT9704BGE Washer - Top Loading
Maytag LAT9704DAL Washer - Top Loading
Maytag LAT9704DAM Washer - Top Loading
International LAT9704GGE Washer - Top Loading
Maytag LAT9706AAE Washer - Top Loading
Maytag LAT9706AAM Washer - Top Loading
Maytag LAT9706AAQ Washer - Top Loading
Maytag LAT9706ABE Washer - Top Loading
Maytag LAT9714AAE Washer - Top Loading
Maytag LAT9714AAL Washer - Top Loading
Maytag LAT9714AAM Washer - Top Loading
Maytag LAT9734AAE Washer - Top Loading
Maytag LAT9734AAL Washer - Top Loading
Maytag LAT9734AAM Washer - Top Loading
Maytag LAT9734ABE Washer - Top Loading
Maytag LAT9734ABL Washer - Top Loading
Maytag LAT9757AAE Washer - Top Loading
Maytag LAT9757AAM Washer - Top Loading
Maytag LAT9766AAE Washer - Top Loading
Maytag LAT9800AAL Washer - Top Loading
Maytag LAT9800AAW Washer - Top Loading
Maytag LAT9800ABL Washer - Top Loading
Maytag LAT9800ABW Washer - Top Loading
Maytag LAT9800AGL Washer - Top Loading
Maytag LAT9800AGW Washer - Top Loading
Maytag LAT9800AGX Washer - Top Loading
Maytag LAT9804AAE Washer - Top Loading
Maytag LAT9804AAL Washer - Top Loading
Maytag LAT9804AAM Washer - Top Loading
Maytag LAT9804ABE Washer - Top Loading
Maytag LAT9806AAE Washer - Top Loading
Maytag LAT9806AAM Washer - Top Loading
Maytag LAT9806ABE Washer - Top Loading
International LAT9806AGE Washer - Top Loading
International LAT9806AKM Washer - Top Loading
International LAT9806AKQ Washer - Top Loading
International LAT9806BGE Washer - Top Loading
International LAT9806DAM Washer - Top Loading
International LAT9806DAQ Washer - Top Loading
International LAT9806GGE Washer - Top Loading
Maytag LAT9824AAE Washer - Top Loading
Maytag LAT9824AAL Washer - Top Loading
Maytag LAT9824AAM Washer - Top Loading
Maytag LAT9824ABE Washer - Top Loading
Maytag LAT9824ABL Washer - Top Loading
Maytag LAT9824ABM Washer - Top Loading
International LAT9824AGE Washer - Top Loading
International LAT9824AKM Washer - Top Loading
International LAT9824BGE Washer - Top Loading
International LAT9824DAM Washer - Top Loading
International LAT9824GGE Washer - Top Loading
Maytag LAT9900AAL Washer - Top Loading
Maytag LAT9900AAW Washer - Top Loading
  #2 (permalink)
Old 01-24-2013, 03:12 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Daniel,
I don't think there is anything wrong with the transmission. Also if you'll order the motor from APP and it will fail within 365 days, you can easy return it.
- The motor Part number: 12002353
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Troubleshoot Turntable jemathis01 Microwave Repair 0 08-03-2012 08:43 AM
Help this Mama troubleshoot AnnaD Washer Repair 3 10-13-2011 07:27 PM
troubleshoot freddy kunz Refrigerator & Freezer Repair 0 11-18-2010 06:56 AM
Help getting top off to troubleshoot silvercbx Washer Repair 1 02-22-2010 07:05 PM
Troubleshoot Kenmore brentley Dishwasher Repair 3 02-03-2009 09:18 PM
