Discuss
washer won't spin sometimes
 in
Washer Repair
Hi, I have a direct drive kenmore washer that sometimes won't spin in the spin cycle. It does always drain.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer won't spin sometimes
  #1 (permalink)
Old 01-23-2013, 01:17 PM
Junior Member
jrtredo is on a distinguished road
Default washer won't spin sometimes
Brand: Kenmore   Age: 5 - 10 years
Hi, I have a direct drive kenmore washer that sometimes won't spin in the spin cycle. It does always drain. Over the weekend, the washer was making a noise and not spinning at all. I took it apart and ended up replacing the coupler. I put it back together and it wasnt making that noise but it wasnt spinning, once i turned the drum by hand some, it started spinning again. It spins pretty hard by hand. I would like to try to fix it. I'm thinking I should try replacing the clutch or the brake unit. Does anyone have any ideas for what would be the most liekly fix?
thank you
  #2 (permalink)
Old 01-23-2013, 02:20 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Most likely you need to replace the clutch.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 01-24-2013, 06:01 AM
Junior Member
Default
thanks, I just ordered a clutch to try, how would I go about checking to see if there is something stuck between the drum and the basket?
  #4 (permalink)
Old 01-24-2013, 10:06 AM
Expert
Default
HI.
First try to look through the outer tub, and if that's not gonna help - remove the basket.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
my kenmore washer makes a grinding noise during spin cycle and does not spin bronco48 Washer Repair 2 10-28-2012 02:42 AM
Washer wont spin motor runs but ticking sound occurs when on spin cycle D.Wick Washer Repair 1 01-07-2012 09:28 AM
LOW-SPIN DURING SPIN CYCLE of MayTag Neptune Dryer/Washer stack mrdhoffman Washer Repair 1 08-30-2011 06:45 PM
Front load washer won't spin water out of clothes on last spin cycle Tracey Finley Washer Repair 1 06-28-2011 05:10 PM
Frigidare front load washer will not spin durning final spin cyle binky8992 Washer Repair 2 08-19-2009 06:29 PM
