Discuss
Standard Suds & F35 Solutions Not Working
 in
Washer Repair
Hello, I have a problem with diagnosis on a Whirlpool Duet Steam (WFW9500TW01) and would appreciate your help! Going on
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Standard Suds & F35 Solutions Not Working
  #1 (permalink)
Old 01-22-2013, 05:12 PM
Junior Member
coignrob is on a distinguished road
Unhappy Standard Suds & F35 Solutions Not Working
Model Number: wfw9500TW01   Brand: Whirlpool   Age: 1 - 5 years
Hello, I have a problem with diagnosis on a Whirlpool Duet Steam (WFW9500TW01) and would appreciate your help! Going on 3 weeks without a solution. I have the Suds & then F35 code, with the Suds code coming up immediately as the water starts to fill. The error was sudden, making me think it was electrical, as we have had no trouble with the washer up to this point.
I found the service manual in the machine and started following the diagnostics. I have removed all tubing including the pressure switch tubing and ensured it was cleaned and not leaking. Checked and cleaned the drain tube, found one infant sock and some change. Removed and cleaned the air trap and saw the bottom of the drum was clean with only minor soap scum. Removed and cleaned drum drain hose 8181732 and vertical drain hose W10003250. I replaced the waste water pump motor for good measure as the motor was a bit noisy after ~3 years. After ensuring everything was clean, I replaced the W10415587 pressure switch. The washer was still giving the F35 error, so based on some comments in the repair forum and after checking the connections on the wiring harness, I replaced W10156258 Expansion Control Board. However, no success.
I have run the diagnostics routines. The steamer diagnostic indicates the steamer is working fine, however I get the F35 code on the C01, fill and then drain. Everything else seems to work fine.
My next thought was to replace the main control board W10180782 but I am loosing hope that this will resolve the issue. Please help as I would rather not drop more money on this machine and not fix the problem. Thanks, Rob
Related Models
Whirlpool WFW9500TW01 AUTOMATIC WASHER
Whirlpool WFW9500TW02 AUTOMATIC WASHER
Whirlpool WFW9500TW03 AUTOMATIC WASHER
Whirlpool WFW9550WL00 AUTOMATIC WASHER
Whirlpool WFW9550WL01 AUTOMATIC WASHER
Whirlpool WFW9550WL10 AUTOMATIC WASHER
Whirlpool WFW9550WR00 AUTOMATIC WASHER
Whirlpool WFW9550WR01 AUTOMATIC WASHER
Whirlpool WFW9550WW00 AUTOMATIC WASHER
Whirlpool WFW9550WW01 AUTOMATIC WASHER
Whirlpool WFW9550WW10 AUTOMATIC WASHER
Whirlpool WFW95HEXL0 WASHER
Whirlpool WFW95HEXL1 AUTOMATIC WASHER
Whirlpool WFW95HEXL2 AUTOMATIC WASHER
Whirlpool WFW95HEXR0 WASHER
Whirlpool WFW95HEXR1 AUTOMATIC WASHER
Whirlpool WFW95HEXR2 AUTOMATIC WASHER
Whirlpool WFW95HEXW0 WASHER
Whirlpool WFW95HEXW1 AUTOMATIC WASHER
Whirlpool WFW95HEXW2 AUTOMATIC WASHER
Whirlpool WFW9600TA00 AUTOMATIC WASHER
Whirlpool WFW9600TA01 AUTOMATIC WASHER
Whirlpool WFW9600TA02 AUTOMATIC WASHER
Whirlpool WFW9600TB00 AUTOMATIC WASHER
Whirlpool WFW9600TC00 AUTOMATIC WASHER
Whirlpool WFW9600TU00 AUTOMATIC WASHER
Whirlpool WFW9600TW00 AUTOMATIC WASHER
Whirlpool WFW9600TW01 AUTOMATIC WASHER
Whirlpool WFW9600TW02 AUTOMATIC WASHER
Whirlpool WFW9600TZ00 AUTOMATIC WASHER
Whirlpool WFW9640XW00 AUTOMATIC WASHER
Whirlpool WFW9700VA00 AUTOMATIC WASHER
Whirlpool WFW9700VA01 AUTOMATIC WASHER
Whirlpool WFW9700VW00 AUTOMATIC WASHER
Whirlpool WFW9700VW01 AUTOMATIC WASHER
Whirlpool WFW9750WL00 AUTOMATIC WASHER
Whirlpool WFW9750WL01 AUTOMATIC WASHER
Whirlpool WFW9750WL02 AUTOMATIC WASHER
Whirlpool WFW9750WR00 AUTOMATIC WASHER
Whirlpool WFW9750WR01 AUTOMATIC WASHER
Whirlpool WFW9750WR02 AUTOMATIC WASHER
Whirlpool WFW9750WW00 AUTOMATIC WASHER
Whirlpool WFW9750WW01 AUTOMATIC WASHER
Whirlpool WFW9750WW02 AUTOMATIC WASHER
Whirlpool WFW97HEXL0 WASHER
Whirlpool WFW97HEXL1 WASHER
Whirlpool WFW97HEXL2 AUTOMATIC WASHER
Whirlpool WFW97HEXR0 WASHER
Whirlpool WFW97HEXR1 WASHER
Whirlpool WFW97HEXR2 AUTOMATIC WASHER
Whirlpool WFW97HEXW0 WASHER
Whirlpool WFW97HEXW1 WASHER
Whirlpool WFW97HEXW2 AUTOMATIC WASHER
Amana WG1010.000 COMMERCIAL MICROWAVES
Amana WG1010.010 COMMERCIAL MICROWAVES
Amana WG1010.200 COMMERCIAL MICROWAVES
Amana WG1021.000 COMMERCIAL MICROWAVES
Amana WG1021.200 COMMERCIAL MICROWAVES
Amana WG1065.000 COMMERCIAL MICROWAVES
Amana WG1120.500 COMMERCIAL MICROWAVES
Amana WG1120.600 COMMERCIAL MICROWAVES
Amana WG1121.000 COMMERCIAL MICROWAVES
Amana WG1165.000 COMMERCIAL MICROWAVES
Amana WG1165.700 COMMERCIAL MICROWAVES
Amana WG1166.500 COMMERCIAL MICROWAVES
 WG1804R Air Conditioner
 WG1805RY6 Air Conditioner
Jenn-Air WG200 WALLOVEN- CONT CLEAN GAS
Jenn-Air WG206 WALLOVEN- CONT CLEAN GAS
Jenn-Air WG24000B WALLOVEN- STD GAS
Jenn-Air WG24000W WALLOVEN- STD GAS
Jenn-Air WG30100B WALLOVEN- S/C GAS
Jenn-Air WG30100W WALLOVEN- S/C GAS
Amana WG445.1 COMMERCIAL MICROWAVES
Amana WG445.2 COMMERCIAL MICROWAVES
 WG5200R Air Conditioner
Whirlpool WGD4750XQ0 29" GAS DRYER
Whirlpool WGD4750XQ1 29" GAS DRYER
Whirlpool WGD4800XQ0 DRYER
Whirlpool WGD4850XQ0 29" GAS DRYER
Whirlpool WGD4890XQ0 29" GAS DRYER
Whirlpool WGD4900XW0 29" GAS DRYER
Whirlpool WGD4910XQ0 29" GAS DRYER
Whirlpool WGD5000VQ1 29" GAS DRYER
Whirlpool WGD5100SQ0 29" GAS DRYER
Whirlpool WGD5100VQ0 29" GAS DRYER
Whirlpool WGD5100VQ1 29" GAS DRYER
Whirlpool WGD5200TQ0 29" GAS DRYER
Whirlpool WGD5200VQ0 29" GAS DRYER
Whirlpool WGD5200VQ1 29" GAS DRYER
Whirlpool WGD5300SQ0 29"GAS DRYER
Whirlpool WGD5300ST0 29"GAS DRYER
Whirlpool WGD5300VW0 29" GAS DRYER
Whirlpool WGD5300VW1 29" GAS DRYER
Whirlpool WGD5310SQ0 29"GAS DRYER
Whirlpool WGD5320SQ0 29"GAS DRYER
Whirlpool WGD5321SQ0 29"GAS DRYER
Whirlpool WGD5500SQ0 29"GAS DRYER
Whirlpool WGD5500ST0 29"GAS DRYER
Whirlpool WGD5500XL0 27" ELECTRIC DRYER
Whirlpool WGD5500XL1 27" ELECTRIC DRYER
Whirlpool WGD5500XW0 27" ELECTRIC DRYER
Whirlpool WGD5500XW1 27" ELECTRIC DRYER
Whirlpool WGD5510VQ0 29"GAS DRYER
Whirlpool WGD5510VQ1 29"GAS DRYER
Whirlpool WGD5520SQ0 29" GAS DRYER
Whirlpool WGD5521SQ0 29"GAS DRYER
Whirlpool WGD5530SQ0 29"GAS DRYER
Whirlpool WGD5540SQ0 29"GAS DRYER
Whirlpool WGD5540ST0 29"GAS DRYER
Whirlpool WGD5550SQ0 29" GAS DRYER
Whirlpool WGD5550ST0 29" GAS DRYER
Whirlpool WGD5550XW0 27" GAS DRYER
Whirlpool WGD5550XW1 27" GAS DRYER
Whirlpool WGD5560SQ0 29" GAS DRYER
Whirlpool WGD5590VQ0 29" GAS DRYER
Whirlpool WGD5590VQ1 29" GAS DRYER
Whirlpool WGD5600SQ0 29" GAS DRYER
Whirlpool WGD5600ST0 29" GAS DRYER
Whirlpool WGD5600VQ0 29" GAS DRYER
  #2 (permalink)
Old 01-22-2013, 05:38 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
The only suggestion I can give you at this point - replace the main control board W10180782.The good thing is if you get it from APP you may return it back even if it has been installed.
Please, post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
SUDS and F35 russell77 Washer Repair 1 06-29-2011 05:34 PM
Everlasting suds eajdmaxwell Dishwasher Repair 0 10-05-2010 05:51 PM
