Discuss
Whirlpool Ultimate Care II bangs and jumps in spin cycle
 in
Washer Repair
My Whirlpool Ultimate Care II sounds like a jet is taking off when it enters the spin cycles. The tub
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Ultimate Care II bangs and jumps in spin cycle
  #1 (permalink)
Old 01-22-2013, 02:23 PM
Junior Member
Mcurtis1982 is on a distinguished road
Default Whirlpool Ultimate Care II bangs and jumps in spin cycle
Brand: Whirlpool   Age: More than 10 years
My Whirlpool Ultimate Care II sounds like a jet is taking off when it enters the spin cycles. The tub is hitting the side of the washing machine and making the whole machine move. The springs look fine and it agitates fine and I have leveled it many times. Is it the drive block?
Help, Matt
Ads By Google
  #2 (permalink)
Old 01-22-2013, 04:43 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
What is the complete model number of the unit?
Remove the agitator and check if the basket is loose.
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 01-22-2013, 08:08 PM
Junior Member
Default
Simon,
mod:LSQ9010LW0
Im not sure if the basket is loose, I can move it up and down a little to were the clip is. I can spin it counter clockwise with no problem. If I try to spin it clockwise is gets hung up.
Thanks, Matt
  #4 (permalink)
Old 01-23-2013, 10:29 AM
Expert
Default
Hi.
Remove the agitator and check if the drive block still has the grooves and it's properly engaged with the spin tube.If the grooves are gone, the basket is sinking down and may cause any kind of noise.
Part number: 389140
Part number: 389140
Also, check the balance ring (#15). It's normally filled with fluid, shake it and if you don't here splashing the ring should be replaced.
Here are the breakdown diagrams and Agitator, Basket and Tub parts for Whirlpool LSQ9010LW0 - AppliancePartsPros.com
Simon.
__________________
  #5 (permalink)
Old 01-28-2013, 12:04 PM
Junior Member
Default
Simon,
I replaced the drive block and the springs. The washer still walks around the room. Any suggestions? Replacing the drive block made the basket tighter and the springs seemed to help, with the noise problem. The balance ring has fluid in it. Im still not giving into buying a new washer, as my old lady keeps hinting to.
Thanks, Matt
  #6 (permalink)
Old 01-28-2013, 02:29 PM
Expert
Default
Hi.
One more think to check is how the skate plate #17 oriented on the tub support #4.
Here the breakdown diagram Machine Base parts for Whirlpool LSQ9010LW0 - AppliancePartsPros.com
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool ultimate care II noise durning the spin cycle. Stango Washer Repair 1 12-30-2012 09:20 PM
Whirlpool Ultimate care 2 spins wild and bangs loud jkshadow Washer Repair 5 12-29-2012 08:39 AM
Whirlpool Ultimate Care II wont spin at the end of the cycle giroiradam Washer Repair 6 08-13-2012 10:10 AM
Whirlpool Ultimate Care II won't spin ralphbo Washer Repair 3 11-12-2011 04:32 PM
Whirlpool Ultimate Care II 9 cycle eerod Washer Repair 3 02-12-2009 07:52 PM
