Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Whirlpool direct drive smells like burnt rubber (http://forum.appliancepartspros.com/washer-repair/515955-whirlpool-direct-drive-smells-like-burnt-rubber.html)
Sremmert 01-21-2013 09:16 PM
Ok... I replace the coupler two days ago, snapped the plastic. After I put everything back together, we washed about five loads and the washer smelt of burning rubber. Soon after there was a small leak. I took the shell back off and found the smell. The housing to the pump was melting. There appeared to be some dark plastic that was melting though. I took the pump off and found there was a good bit of lint type stuff in the back flow valve. Anyhow, I replaced the pump and ran three loads, small loads. There seems to be a return of the smell. Not strong and it is possible it is "left over" odor... Letting the washer rest now. My question is, what did I do wrong to cause the pump to turn into something from Alien melting like that...before I burn through another pump, I figured I would ask the experts!
Model number - LSN2000LW0
Simon / APP Team 01-22-2013 11:46 AM
Hi.
There is absolutely nothing you've done wrong.Sometimes the techs find the socks and other interesting things inside the drain pump.
Have a happy laundry.
Simon.
