slow spin
2 Attachment(s)
hi,
The machine spins slowly, not letting all the water out of the clothes. We alreaty replaced the water pump, but still the same problem. There was also a slight burning smell after the last wash. It doesn't leak, no other issues. Also, I'm attaching a photo of a part that we are not sure what it is and if it is normal. Looks like a brace of sorts that should be closed.?..but we have no idea. Couldn't find it on the website. Any help would be sooo appreciated. thank you! maria |
Quote:
The slow spin (wet clothes) could be caused by: unbalanced load; a clogged hoses to and from the drain pump; a bad drive block (#10 at the diagram); a bad basket drive (#1 at the diagram) or a bad clutch (#5 at the diagram). You can find more information in one of our previous threads: http://forum.appliancepartspros.com/...-spinning.html - The drive block Part number: 389140 - The spanner wrench (needed to access the drive block) Part number: TJ90TB123A - The basket drive Part number: 285792 - The clutch assembly Part number: 285785 The part on your picture is the suspension spring. It looks not so bad and I don't think it needs any attention so far. Here are the breakdown diagrams and Parts for Whirlpool LC4900XTW0 - AppliancePartsPros.com Gene. |
hi Gene,
Thank you so much for this info. Should we replace all these parts, one at a time to see which is the true culprit? Which would you start with? On the suspension springs, should those braces at the base be "closed" somehow? I so appreciate all your help. maria ======================= Quote:
Replacing parts without proper troubleshooting is wasting of money and time. I would suggest to open the thread I posted for you and read all instructions.
Gene. |
Quote:
Eric |
Thank you, Eric! I appreciate this answer.
I watched the video on replacing the clutch, but did not see an example of what a 'bad' clutch looks like. Does anyone have a description or a photo? What evidence to look for to know that the clutch is bad and needs replacing?
thank you! |
Did you check the drive block and the basket drive tube yet?
Did you see any signs of leaked oil? Gene. |
There are no signs of leaking oil.
Quote:
Gene. |
| All times are GMT -7. The time now is 03:55 AM. |
