Discuss
Maytag Front Loader Burning Smell
 in
Washer Repair
The washer is emitting a burning odor. The gasket appears to be burned and the likely cause of the smell.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Front Loader Burning Smell
  #1 (permalink)
Old 01-21-2013, 05:29 PM
Junior Member
raj58esh is on a distinguished road
Default Maytag Front Loader Burning Smell
Model Number: MAH8700AWW   Brand: Maytag   Age: 1 - 5 years
The washer is emitting a burning odor. The gasket appears to be burned and the likely cause of the smell. We think the gasket burned because the washer is not balanced due to it making substantial noise when used. Does anyone know if the gasket is the issue, and how to re-balance the washer drum to prevent this gasket from burning up again?
Ads By Google
Related Models
Maytag MAH8700AWW Washer - Horizontal Axis
Maytag MAH9700AWM Washer - Horizontal Axis
Maytag MAH9700AWQ Washer - Horizontal Axis
Maytag MAH9700AWW Washer - Horizontal Axis
Frigidaire MAL123P1A1 Wwh(v1) / Room Air Conditioner
Maytag MAL1800AXM Misc / Accessory
Maytag MAL1800AXQ Misc / Accessory
Maytag MAL1800AXW Misc / Accessory
Maytag MAL2000AXQ Misc / Accessory
Maytag MAL2000AXW Misc / Accessory
Frigidaire MAS183P2A1 Wwh(v1) / Room Air Conditioner
Maytag MAT10CSAAL Washer - Top Loading
Maytag MAT10CSAAW Washer - Top Loading
Maytag MAT10CSAGL Washer - Top Loading
Maytag MAT10CSAGW Washer - Top Loading
Maytag MAT10CSBKL Washer - Top Loading
Maytag MAT10CSEGL Washer - Top Loading
Maytag MAT10CSEGW Washer - Top Loading
Maytag MAT10DAAAL Washer - Top Loading
Maytag MAT10DAAAW Washer - Top Loading
Maytag MAT10DAABL Washer - Top Loading
Maytag MAT10DAABW Washer - Top Loading
Maytag MAT10PDAAL Washer - Top Loading
Maytag MAT10PDAAW Washer - Top Loading
Maytag MAT10PDABL Washer - Top Loading
Maytag MAT10PDABW Washer - Top Loading
Maytag MAT10PDEGW Washer - Top Loading
Maytag MAT10PSAAL Washer - Top Loading
Maytag MAT10PSAAW Washer - Top Loading
Maytag MAT10PSAGL Washer - Top Loading
Maytag MAT10PSAGW Washer - Top Loading
Maytag MAT11CSBKL Washer - Top Loading
Maytag MAT11MNAAW Washer - Top Loading
Maytag MAT11MNAGW Washer - Top Loading
Maytag MAT11MNEGW Washer - Top Loading
Maytag MAT11PDAAL Washer - Top Loading
Maytag MAT11PDAAW Washer - Top Loading
Maytag MAT11PDABL Washer - Top Loading
Maytag MAT11PDABW Washer - Top Loading
Maytag MAT12CSAAL Washer - Top Loading
Maytag MAT12CSAAQ Washer - Top Loading
Maytag MAT12CSAAW Washer - Top Loading
Maytag MAT12CSAGW Washer - Top Loading
Maytag MAT12CSAKL Washer - Top Loading
Maytag MAT12CSAKQ Washer - Top Loading
Maytag MAT12CSDAQ Washer - Top Loading
Maytag MAT12CSDAW Washer - Top Loading
Maytag MAT12CSDGW Washer - Top Loading
Maytag MAT12CSEGW Washer - Top Loading
Maytag MAT12CSFWQ Washer - Top Loading
Maytag MAT12CSFWW Washer - Top Loading
Maytag MAT12PDAAL Washer - Top Loading
Maytag MAT12PDAAW Washer - Top Loading
Maytag MAT12PDABL Washer - Top Loading
Maytag MAT12PDABW Washer - Top Loading
Maytag MAT12PDAGW Washer - Top Loading
Maytag MAT12PDBAL Washer - Top Loading
Maytag MAT12PDBAQ Washer - Top Loading
Maytag MAT12PDBAW Washer - Top Loading
Maytag MAT12PDBBL Washer - Top Loading
Maytag MAT12PDBBQ Washer - Top Loading
Maytag MAT12PDBBW Washer - Top Loading
Maytag MAT12PDCBL Washer - Top Loading
Maytag MAT12PDCBQ Washer - Top Loading
Maytag MAT12PDCBW Washer - Top Loading
Maytag MAT12PDDAQ Washer - Top Loading
Maytag MAT12PDDAW Washer - Top Loading
Maytag MAT12PDDBW Washer - Top Loading
Maytag MAT12PDDGW Washer - Top Loading
Maytag MAT12PDEGW Washer - Top Loading
Maytag MAT12PDLAQ Washer - Top Loading
Maytag MAT12PDLAW Washer - Top Loading
Maytag MAT12PDLGW Washer - Top Loading
Maytag MAT12PDSAW Washer - Top Loading
Maytag MAT12PRAAW Washer - Top Loading
Maytag MAT12PRAEW Washer - Top Loading
Maytag MAT12PRBAW Washer - Top Loading
Maytag MAT12PRDAW Washer - Top Loading
Maytag MAT12PRSAW Washer - Top Loading
Maytag MAT12PSAAW Washer - Top Loading
Maytag MAT12PSAGW Washer - Top Loading
Maytag MAT12PSBAW Washer - Top Loading
Maytag MAT12PSDAW Washer - Top Loading
Maytag MAT12PSLWQ Washer - Top Loading
Maytag MAT12PSLWW Washer - Top Loading
Maytag MAT13MNAAW Washer - Top Loading
Maytag MAT13MNAGW Washer - Top Loading
Maytag MAT13MNDAW Washer - Top Loading
Maytag MAT13MNDGW Washer - Top Loading
Maytag MAT13MNEGW Washer - Top Loading
Maytag MAT13PDAAW Washer - Top Loading
Maytag MAT13PDBAW Washer - Top Loading
Maytag MAT13PNAEW Washer - Top Loading
Maytag MAT13PNDEW Washer - Top Loading
Maytag MAT13PRBWW Washer - Top Loading
Maytag MAT230CAAG Washer - Top Loading
Maytag MAT23PCAAC Washer - Top Loading
Maytag MAT23PCAAG Washer - Top Loading
Maytag MAT23PCAAL Washer - Top Loading
Maytag MAT23PCAAW Washer - Top Loading
Maytag MAT23PCABG Washer - Top Loading
Maytag MAT23PCABL Washer - Top Loading
Maytag MAT23PCABW Washer - Top Loading
Maytag MAT25CSAAG Washer - Top Loading
Maytag MAT25CSAAL Washer - Top Loading
Maytag MAT25CSAAW Washer - Top Loading
Maytag MAT25CSAGG Washer - Top Loading
Maytag MAT25CSAGL Washer - Top Loading
Maytag MAT25CSAGW Washer - Top Loading
Maytag MAT25CSBIL Washer - Top Loading
Maytag MAT25CSCAG Washer - Top Loading
Maytag MAT25CSCAL Washer - Top Loading
Maytag MAT25CSCAW Washer - Top Loading
Maytag MAT25CSEGG Washer - Top Loading
Maytag MAT25CSEGL Washer - Top Loading
Maytag MAT25CSEGW Washer - Top Loading
Maytag MAT25CTAAG Washer - Top Loading
Maytag MAT25CTAAL Washer - Top Loading
Maytag MAT25CTAAW Washer - Top Loading
Maytag MAT25DAAAL Washer - Top Loading
  #2 (permalink)
Old 01-22-2013, 04:23 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
Remove the rear cover and check the belt. Make sure the nut which securing the tub pulley is properly tighten.
When you said "gasket" did you mean the door diaphragm (#24 at the diagram)?
Here are the breakdown diagrams and Parts for Maytag MAH8700AWW Washer - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 01-24-2013, 06:55 PM
Junior Member
Default Smell Location
Yes we believed the smell to be coming from that diaphragm as part of it looked to be burned off as well. Do you know how to go about opening the the front to remove and replace that diaphragm. In addition we believe that the cause could have been that the drum itself may not be balanced properly. Would you know how to go about fixing that as well.
Thank you very much
  #4 (permalink)
Old 01-25-2013, 03:35 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Before replacing the door diaphragm (boot) you have to find and fix whatever caused it. Did you check that nut?
__________________
  #5 (permalink)
Old 01-27-2013, 06:45 AM
Junior Member
Default Nut and Balancing
Which nut are you referring to? In addition, how do you go about removing the diaphragm?
  #6 (permalink)
Old 01-28-2013, 09:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by Gene View Post
...Remove the rear cover and check the belt. Make sure the nut which securing the tub pulley is properly tighten...
It was on 1/22. This nut is shown as #7 at the diagram.
As I told you earlier, replacing the door diaphragm without fixing whatever cause that damage is wasting of time and money for you.
__________________
  #7 (permalink)
Old 02-13-2013, 05:00 PM
Junior Member
bger is on a distinguished road
Default mah8700aww door boot
I have this similar issue, purchased a replacement door boot, then discovered the metal tub does not run true in the plastic drum. I read your post about the pulley nut. It is tight and it does not seem to wobble at the pulley when the metal drum is spun. Curious if there is a common problem with the spinner shaft bending? The pulley does not appear to be effected as I manually spin the drum. The tub wobbles at the door, the pully appears true.
The part I am asking about is the Assy Frame Shaft, item #21 in diagram
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
loud noise then burning smell from front loas rodney.allen221@yahoo.com Washer Repair 1 12-18-2012 06:08 PM
GE Front Loader burning gasket and smoking moomba12502 Washer Repair 1 11-11-2011 12:51 AM
burning smell on my maytag washer wiess Washer Repair 1 04-18-2011 11:14 AM
Maytag Refridge Burning Smell brianmcc2005 Refrigerator & Freezer Repair 0 10-12-2010 05:54 PM
Maytag washer burning smell goldieoldie Washer Repair 1 03-09-2009 05:16 PM
