Discuss
GE top load washer make grinding noise during agitation and spin, but work fine, just
 in
Washer Repair
I moved mt GE washer to clean under it. when I went to wash a load it started maikng a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE top load washer make grinding noise during agitation and spin, but work fine, just
  #1 (permalink)
Old 01-21-2013, 05:11 PM
Junior Member
dchanson55 is on a distinguished road
Unhappy GE top load washer make grinding noise during agitation and spin, but work fine, just
Brand: GE   Age: 5 - 10 years
I moved mt GE washer to clean under it. when I went to wash a load it started maikng a bad grinding sound. The washer works fine, just makes the noise. I filled the tub with water for a small load of clothes, ran it with no clothes, and there was no noise. If I press down on the tub and turn the agitator it makes the grinding sound.
  #2 (permalink)
Old 01-21-2013, 06:14 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Model number?
  #3 (permalink)
Old 01-21-2013, 07:03 PM
Junior Member
Default
Thank you for your reply will get it in the morning, as it is at another house.
  #4 (permalink)
Old 01-22-2013, 01:04 PM
Junior Member
Default
Ge model nm WCSR4170G1WW
  #5 (permalink)
Old 01-22-2013, 01:52 PM
Expert
APP Volunteer
Default
The model you have is on the list of models that can suffer from a sagging front apron. If the front apron sags, the support assembly under the tub can drop low enough that the motor pulley and/or the drive pulley will rub on the bottom of the washer. You should be able to see this with the front panel removed. There is a front apron bracket service kit available to fix this problem.
Eric
  #6 (permalink)
Old 01-23-2013, 05:01 AM
Junior Member
Default
Quote:
Eric
Thanks Eric, how do I remove the front panel, and could it be anything else?
  #7 (permalink)
Old 01-23-2013, 05:53 AM
Expert
APP Volunteer
Default
Insert a putty knife into the top groove of the front panel in line with the lid opening on each side while pulling outward on the panel. Then just lift the panel off. Observe the pulleys while doing a load to determine if this is the problem. If not, try to localize the source of the noise.
Eric
  #8 (permalink)
Old 01-23-2013, 08:23 AM
Junior Member
Default
pulled front cover does not look like it is sagging noise is coming from the bottom area where the drive belts are and only with a load of clothes and and water level set for large load
  #9 (permalink)
Old 01-23-2013, 10:24 AM
Expert
APP Volunteer
Default
So, with a full load, you don't see either pulley hitting the bottom of the washer? Can't really help you any further without seeing/hearing it myself. Can you post a video on youtube?
Eric
  #10 (permalink)
Old 01-24-2013, 04:42 AM
Junior Member
Default
Eric
Yes I can do that, will let you know
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag top-load washer clicking noise during agitation angbrad03 Washer Repair 1 08-20-2017 01:27 PM
Grinding noise during agitation Shadow99 Washer Repair 3 10-07-2013 02:04 PM
Kenmore washer; loud grinding, no agitation/spin jk_ludlow Washer Repair 3 01-31-2011 11:48 AM
No Agitation, Grinding noise harleyt Washer Repair 3 02-15-2009 09:24 AM
grinding noise during agitation kdeldridge Washer Repair 7 04-04-2008 06:24 PM
