| » GE top load washer make grinding noise during agitation and spin, but work fine, just |
I clicked the link for the service kit you had posted earlier, on that page was a box saying check your model number for compatibilty with the service kit and it came back not compatible.
The compatability check is incorrect. The part number is the correct number for your washer. You might try contacting GE and complaining as this is a design flaw and they may provide you with a replacement part at no charge.
Eric Last edited by fairbank56 : 01-24-2013 at 07:58 PM. |
Thanks Eric, you are right, I bought the kit. What is the best way to remove the top cover? Thanks, Dale
Remove the front panel, remove the two screws just under the cover on each side of the cabinet, reach under the cover and squeeze the lid switch retainer to release it while pushing the switch upwards and then stick the switch back down through the opening. Pull the cover towards you while lifting up the front edge to release the two side catches and three rear locking tabs under the control panel.
Eric |
Then apparently, the front apron was not sagging? Did you check it? If it was bent down, you should have straightened it before installing new bracket and top cover. Are you sure the noise is coming from the pulley hitting the bottom of the washer? If so, you may need to replace the suspension rods. The front two are different than the rear two.
Eric Last edited by fairbank56 : 01-29-2013 at 03:55 PM. |
Quote:
No, they are suspension rods, or rod and spring assembly. The springs may be weak, allowing the support assembly to drop too low. It's also possible that the rod support sockets that the suspension rods hang from are badly worn or broken which will also allow the support assembly to drop.
Eric Last edited by fairbank56 : 01-29-2013 at 06:22 PM. |
| Display Modes | |
| Kenmore washer; loud grinding, no agitation/spin | jk_ludlow | Washer Repair | 3 | 01-31-2011 11:48 AM |
| Grinding noise during agitation | Shadow99 | Washer Repair | 0 | 05-13-2009 06:23 AM |
| Maytag top-load washer clicking noise during agitation | angbrad03 | Washer Repair | 0 | 03-13-2009 12:00 PM |
| No Agitation, Grinding noise | harleyt | Washer Repair | 3 | 02-15-2009 09:24 AM |
| grinding noise during agitation | kdeldridge | Washer Repair | 7 | 04-04-2008 06:24 PM |
