Discuss
Kenmore Catalyst won't drain after replacing pump
 in
Washer Repair
We have replaced the pump on the machine & it still will not drain. Fills, agiates & spins, however when
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Catalyst won't drain after replacing pump
  #1 (permalink)
Old 01-20-2013, 08:35 PM
Junior Member
marnidyce is on a distinguished road
Default Kenmore Catalyst won't drain after replacing pump
Model Number: 11020096993   Brand: Kenmore   Age: More than 10 years
We have replaced the pump on the machine & it still will not drain. Fills, agiates & spins, however when it suppose to drain, water fills in the tub while it is spinning & no water drains. What else could be wrong?
Ads By Google
Related Models
Kenmore 11020096993 WASHER
Kenmore 11020097990 WASHER
Kenmore 11020097991 WASHER
Kenmore 11020097992 WASHER
Kenmore 11021062000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021062001 WASHER
Kenmore 11021064000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021064001 WASHER
Kenmore 11021066000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021066001 WASHER
Kenmore 11021082000 WASHER
Kenmore 11021082001 WASHER
Kenmore 11021084000 WASHER
Kenmore 11021084001 WASHER
Kenmore 11021086000 WASHER
Kenmore 11021086001 WASHER
Kenmore 11021882000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021882001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021892000 WASHER
Kenmore 11021894000 WASHER
Kenmore 11022032100 WASHER
Kenmore 11022032101 WASHER
Kenmore 11022032102 AUTOMATIC WASHER
Kenmore 11022036100 WASHER
Kenmore 11022036101 WASHER
Kenmore 11022036102 AUTOMATIC WASHER
Kenmore 11022042100 WASHER
Kenmore 11022042101 WASHER
Kenmore 11022042102 AUTOMATIC
Kenmore 11022052100 WASHER
Kenmore 11022052101 WASHER
Kenmore 11022052102 AUTOMATIC WASHER
Kenmore 11022054100 WASHER
Kenmore 11022054101 WASHER
Kenmore 11022054102 AUTOMATIC WASHER
Kenmore 11022056100 WASHER
Kenmore 11022056101 WASHER
Kenmore 11022056102 AUTOMATIC WASHER
Kenmore 11022062100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022062101 WASHER
Kenmore 11022062102 AUTOMATIC WASHER
Kenmore 11022064100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022064101 WASHER
Kenmore 11022064102 AUTOMATIC WASHER
Kenmore 11022066100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022066101 WASHER
Kenmore 11022066102 AUTOMATIC WASHER
Kenmore 11022082100 WASHER
Kenmore 11022082101 AUTOMATIC WASHER
Kenmore 11022082102 AUTOMATIC
Kenmore 11022084100 WASHER
Kenmore 11022084101 AUTOMATIC WASHER
Kenmore 11022084102 AUTOMATIC
Kenmore 11022086100 WASHER
Kenmore 11022086101 AUTOMATIC WASHER
Kenmore 11022086102 AUTOMATIC
Kenmore 11022292100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022294100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022422100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022432100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022442100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022622100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022632100 WASHER
Kenmore 11022642100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022652100 COMPACT WASHER
Kenmore 11022662100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022692100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022692101 AUTOMATIC WASHER
Kenmore 11023012100 AUTOMATIC WASHER
Kenmore 11023012101 AUTOMATIC WASHER
Kenmore 11023012102 AUTOMATIC WASHER
Kenmore 11023014100 AUTOMATIC WASHER
Kenmore 11023014101 AUTOMATIC WASHER
Kenmore 11023014102 AUTOMATIC WASHER
Kenmore 11023022100 AUTOMATIC WASHER
Kenmore 11023022101 AUTOMATIC WASHER
Kenmore 11023022102 AUTOMATIC WASHER
Kenmore 11023024100 AUTOMATIC WASHER
Kenmore 11023024101 AUTOMATIC WASHER
Kenmore 11023024102 AUTOMATIC WASHER
Kenmore 11023032100 WASHER
Kenmore 11023032101 AUTOMATIC WASHER
Kenmore 11023032102 AUTOMATIC WASHER
Kenmore 11023034100 WASHER
Kenmore 11023034101 AUTOMATIC WASHER
Kenmore 11023034102 AUTOMATIC WASHER
Kenmore 11023036100 WASHER
Kenmore 11023036101 AUTOMATIC WASHER
Kenmore 11023036102 AUTOMATIC WASHER
Kenmore 11023652200 AUTOMATIC WASHER
Kenmore 11023662200 AUTOMATIC WASHER
Kenmore 11023692200 AUTOMATIC WASHER
Kenmore 11023712200 AUTOMATIC WASHER
Kenmore 11023722200 AUTOMATIC WASHER
Kenmore 11023732200 AUTOMATIC WASHER
Kenmore 11023812100 AUTOMATIC WASHER
Kenmore 11023822100 AUTOMATIC WASHER
Kenmore 11023832100 AUTOMATIC WASHER
Kenmore 11023902200 AUTOMATIC WASHER
Kenmore 11023902201 AUTOMATIC WASHER
Kenmore 11023904200 AUTOMATIC WASHER
Kenmore 11023904201 AUTOMATIC WASHER
Kenmore 11023912100 AUTOMATIC WASHER
Kenmore 11023912101 AUTOMATIC WASHER
Kenmore 11023912102 AUTOMATIC WASHER
Kenmore 11023922200 AUTOMATIC WASHER
Kenmore 11023922201 AUTOMATIC WASHER
Kenmore 11023924200 AUTOMATIC WASHER
Kenmore 11023924201 AUTOMATIC WASHER
Kenmore 11023932200 WASHER
Kenmore 11023934200 WASHER
Kenmore 11024082200 AUTOMATIC WASHER
Kenmore 11024084200 AUTOMATIC WASHER
Kenmore 11024086200 AUTOMATIC WASHER
Kenmore 11024422300 AUTOMATIC WASHER
Kenmore 11024432300 AUTOMATIC WASHER
Kenmore 11024442300 AUTOMATIC WASHER
Kenmore 11024622300 AUTOMATIC WASHER
  #2 (permalink)
Old 01-21-2013, 03:34 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
Did it show any error code?
If it did, post it.
If it did not, perform the diagnostic tests as instructed in the attached tech sheet and post the results.
File Type: pdf Tech Sheet - 3954356 - Catalyst 11020096993.pdf (275.9 KB, 4 views)
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing Maytag drain pump bmeiste Washer Repair 0 08-25-2012 02:31 PM
Replacing drain pump jmbmichael Washer Repair 0 08-22-2012 04:45 PM
Replacing Drain Pump KBABA1 Washer Repair 1 01-15-2012 06:52 PM
Replacing drain pump scilabsguy Washer Repair 2 08-17-2011 06:08 PM
replacing drain pump gss2000 Dishwasher Repair 0 11-26-2009 02:40 PM
