Discuss
HydroWave does not agitate, nor spin
 in
Washer Repair
GE HydroWave Model: S3700G1WW Purchase: May 1, 2008 Symptoms: Washer fills and drains, but will not agitate nor spin. Tests
Appliance Repair Forum > Appliance Repair Help > Washer Repair » HydroWave does not agitate, nor spin
  #1 (permalink)
Old 01-20-2013, 05:58 PM
Junior Member
Colimotl is on a distinguished road
Default HydroWave does not agitate, nor spin
Model Number: S3700G1WW   Brand: GE   Age: 1 - 5 years
GE HydroWave
Model: S3700G1WW
Tests made:
1. Checked for error codes. Green light blinks on one second, off one second continuously. I presume there is no error to be shown.
2. I did the reset by unplugging the unit for two minutes, then lifting and shutting the lid seven times within twelve seconds.
3. Checked lid switch for continuity. Switch is good.
4. Checked the shifter Coil for continuity. Resistance was around 91.2 ohms.
5. Checked the motor fuse on the harness. Because the green light blinks, I presume the fuse is good. Furthermore, after unplugging the washer I made a check by locating the neutral terminal on the power cord and disconnecting the farthest left (of four) plug on the motor. I then placed the one lead of my ohmmeter on the neutral terminal of the power cord and the other lead on the white/red wire of the motor plug. I got continuity
The washer has had very light use and otherwise is in mint condition.
Any thoughts on this problem will be greatly appreciated.
Ads By Google
Related Models
Hoover S3755--- Cstr - Spherical,saucer,lc,elec,tp Swivel
Hoover S3755080 Cstr - Spherical,saucer,lc,elec,tp Swivel
Hoover S3765040 Cstr - Spherical,saucer,lc,elec,tp Swivel
Magic Chef S38FA-2CX-94 Range - S/c F/s Ele
Magic Chef S38FK-2CX-94 Range - S/c F/s Ele
Magic Chef S38FK-2CX-OC Range - S/c F/s Ele
Magic Chef S38FY-2CX-94 Range - S/c F/s Ele
International S40STRP Ref - Top Mount
Frigidaire S418B2SA Kel(v0) / Room Air Conditioner
Frigidaire S418C2SB Kel(v1) / Room Air Conditioner
Frigidaire S418F2XA Kel(v1) / Room Air Conditioner
Frigidaire S418T2SA Kel(v4) / Room Air Conditioner
General Electric S4200B0WW Washer
General Electric S4200B1WW Washer
General Electric S4200B2WW Washer
General Electric S4200B3WW Washer
Whirlpool S4257W0
Whirlpool S4257^0
Hoover S5083
General Electric S5100D0WW Washer
General Electric S5100D1WW Washer
Magic Chef S51FK-2KLX-64 Range - D/i Cont Clean Gas
Magic Chef S51FK-2KLX-ON Range - D/i Cont Clean Gas
General Electric S5200E1WW Washer
General Electric S5200E6WW Washer
Hoover S5501---
Hoover S5503---
Hoover S5507---
Hoover S5509---
Hoover S5509021
Hoover S5511---
Hoover S5513---
Hoover S5533---
Hoover S5535---
Hoover S5537---
Hoover S5539---
Hoover S5549
Hoover S5567011
Hoover S5569011
Hoover S5573--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5573011
Hoover S5573022
Hoover S5573033
Hoover S5575---
Hoover S5575001
Hoover S5577--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5579---
Hoover S5581---
Hoover S5583---
Hoover S5585---
Hoover S5587---
Hoover S5589---
Hoover S5593---
Hoover S5601--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5602070 Cvs - Access Kit,instal Kit,power Unit
Hoover S5604070 Cvs - Access Kit,instal Kit,power Unit
Hoover S5604080 Cvs - Access Kit,instal Kit,power Unit
Hoover S5605 Cvs - Access Kit,instal Kit,power Unit
Hoover S5607---
Hoover S5609--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5610--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5610070 Cvs - Access Kit,instal Kit,power Unit
Hoover S5610080 Cvs - Access Kit,instal Kit,power Unit
Hoover S5613--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5615--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5619--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5620--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5620070 Cvs - Access Kit,instal Kit,power Unit
Hoover S5625--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5626--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5627 Cvs - Access Kit,instal Kit,power Unit
Hoover S5627080 Cvs - Access Kit,instal Kit,power Unit
Hoover S5630--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5635--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5636--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5639---
Hoover S5640--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5643--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5645---
Hoover S5645001
Hoover S5647---
Hoover S5649---
Hoover S5651---
Hoover S5655--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5668--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5669--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5671--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5672--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5673--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5673080 Cvs - Access Kit,instal Kit,power Unit
Hoover S5674--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5675--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5675080 Cvs - Access Kit,instal Kit,power Unit
Hoover S5676--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5677--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5678--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5680--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5682--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5684--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5684035 Cvs - Access Kit,instal Kit,power Unit
Hoover S5686--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5688--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5690--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5692--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5697--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5701--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5701035 Cvs - Access Kit,instal Kit,power Unit
Hoover S5703--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5709--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5711--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5713--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5715--- Cvs - Access Kit,instal Kit,power Unit
Hoover S5716--- Cvs - Access Kit,instal Kit,power Unit
International S60STRP Ref - SXS/I&W
Magic Chef S61H-3KLX Range - S/i Cont Clean Gas
Magic Chef S61HA-3KLX Range - S/i Cont Clean Gas
International S61STRP Ref - SXS/I&W
Magic Chef S64F-3CKX Range - S/c S/i Gas
Magic Chef S64F-3CKXW Range - S/c S/i Gas
Magic Chef S64F-3CKXW-NL Range - S/c S/i Gas
  #2 (permalink)
Old 01-21-2013, 07:06 AM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
Need to rule out the timer by taking some voltage measurements at one of the motor/inverter connectors if you have a multimeter and experience using it.
Eric
  #3 (permalink)
Old 01-21-2013, 07:10 AM
Junior Member
Default
Quote:
Eric
Eric,
Thank you for the prompt reply. I'll check out the timer as you suggested.
Daniel
  #4 (permalink)
Old 01-21-2013, 07:45 AM
Expert
APP Volunteer
Default
The rightmost connector on the inverter board is the timer input. You need to check for 120vac (volts AC) on the pins of the circuit board. One lead of the meter should always be on the white/red wire of the leftmost connector. This is neutral. On that leftmost connector, you should have 120vac on the red/black wire and the orange wire (may be gray on some models). On the rightmost connector, white is slow speed, blue is fast speed, violet/white is agitate and red is spin. So for example, in high speed spin mode you should have 120vac on red and blue. If the voltage checks are good, the motor/inverter is bad. If your missing or the voltage is way low on the rightmost connector, either the timer is bad or there is a bad connection/wire somewhere between timer and inverter.
Eric
  #5 (permalink)
Old 01-21-2013, 03:53 PM
Junior Member
Default
Eric,
Again, thanks for the quick reply. Unfortunately the motor proved to be bad. Since this is the second motor to die on this unit, I'm cutting my losses and junking it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Hydrowave Washer won't spin or agitate budmanluvtofish Washer Repair 1 01-15-2013 06:04 AM
Hydrowave washer will not agitate hartley57 Washer Repair 4 11-01-2012 11:13 AM
GE Hydrowave washer won't agitate gaotu49 Washer Repair 2 10-12-2011 02:33 PM
HydroWave will not Spin or Agitate LED blinks 6 times dagalla Dishwasher Repair 1 02-02-2010 05:51 AM
ge hydrowave no agitate or spin floorman Dishwasher Repair 0 01-18-2010 11:38 AM
