Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   washer will not fill with water (http://forum.appliancepartspros.com/washer-repair/515679-washer-will-not-fill-water.html)
pbhall 01-17-2013 03:55 PM
Washer not filling with water. Replaced fill valve, no change. :( The washer runs through all cycles if filled manually with water.
What else should I look at?
Thanks!!
Simon / APP Team 01-17-2013 10:09 PM
Hi.
Open the control panel and check the lid switch assembly fuse.
If it's blown - replace the lid switch assembly
Part number: 22001682
Here are the breakdown diagrams and 06-Top parts for Maytag LAT9800AAW - AppliancePartsPros.com
Post the results.
Simon.
pbhall 01-18-2013 03:22 PM
Simon, the fuse was it! Thank You!!! A good lesson to remember the first thing to check for an electrical problem is any fuse.
Thanks Again!
Peter
Simon / APP Team 01-18-2013 03:47 PM
You are most welcome.
Simon.
