| » Washing machine spin cycle has gone violent |
Model Number: MVWC300XW Brand: Maytag Age: 1 - 5 years
My issue is similar to many others. The spin cycle is completely out of balance and bangs against all sides of the washing machine.
I have checked the legs and their balance and all is good there. What I'm looking for is whether this might be an issue with the washer suspension springs or the counter balance suspension spring? I watched Matt's incredibly awesome videos to get an idea of how to check on this, but I believe my cover panel may be a bit more difficult. Do you have any recommendations for disassembling this beast? And of course, any suggestions as to what the issue is? Thanks! Ads By Google Related Models |
I figured out how to remove the control panel. There were two pieces of metal that I needed to wedge up using my putty knife...but my knife was so wide it was hitting the edge of a rigid piece of metal as well. If having the same difficulty as I did, then slide about a half inch of your putty knife under the front L and front R side of the control panel and press towards the back...you should feel the tension release.
But then my machine had a whole store of surprises for me. Instead of small springs attached at the bottom, it has long metal rods attached to springs and the basket near the bottom/midway pt. The top of the metal rods hangs out at each top corner of the unit. There aren't any counter springs that I could find either. Every spring looks to be in like new condition, and the whole thing is relatively level. The motor and everything looks fine, although I know next to nothing about that stuff. I'm thinking about just putting everything back together to see if it magically works correctly. Any suggestions before I do this? Cheers! |
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
This is a direct drive Whirlpool washer, no suspension rods. I would check the back spring,maybe wore through the frame. If ok, compare the left and right bottom tub area, the skate board under the tub might be miss-aligned.
__________________
Hey Guys,
I want to first apologize for any confusion on the way the parts list comes up when you enter M#MVWC300XW. It seems that when you enter M#MVWC300XW on our website M# MVWC300VW0 & MVWC300VW1 come up, which are two different designs internally. Meaning the models ending VW are direct drive while the XW are not. Our IT have been notified and are working on this issue. Again our apologies for any confusion this has caused.
__________________
Need a part? Buy appliance parts from us. Fast delivery and great prices. Thank you for supporting our free repair help forum. |
Unfortunately the problem is back in full force. Rich, would you mind explaining your idea in a bit more detail? Where is the back spring, and how do I check level of skateboard? Also...what is the skateboard? Much appreciated!
EDIT: And this is damn embarrassing, but I don't remember how to take the casing off. When I remove the top control panel there aren't two retaining clips like EVERY single video and repair guide show. Any thoughts? I have tried to repeat everything I did last time but to no avail. Last edited by HitTheTwit : 02-17-2013 at 01:19 PM. Reason: More questions |
| Display Modes | |
| Washing Machine Won't Go Through the Spin Cycle | subaruni | Washer Repair | 1 | 07-30-2012 09:52 AM |
| Washer moves during spin cycle and comes to violent stop. | christian1959 | Washer Repair | 1 | 07-26-2012 09:56 AM |
| Maytag mav8000aww - violent off center during spin cycle... | ScottCypress | Washer Repair | 9 | 09-02-2011 01:58 AM |
| Violent spin cycle | greywolf94 | Washer Repair | 2 | 02-10-2011 12:00 PM |
| violent stop on spin cycle | dirtguy | Washer Repair | 1 | 05-19-2009 02:11 PM |
