Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   kenmore oasis lid does not lock (http://forum.appliancepartspros.com/washer-repair/51561-kenmore-oasis-lid-does-not-lock.html)
wgb123 09-30-2009 08:24 AM
I have a Kenmore Oasis Washer with two problems.
1: the drain pump will not pump water out unless the drain hose is close to the floor. IE into a 5 gallon bucket.
I orderd a new pump.
2: The lid lock does not engage. It tries, you can hear it click about 5 times but then errors out. This just started today. The manual states to remove obstuction. There's nothing blocking the path for the lid lock.
sidfink43 10-01-2009 04:30 PM
The likely problem is the lock has failed. Here is the service manual which will show you how to trouble shoot it.
https://secured.whirlpool.com/Servic...LE/8178583.pdf
Good luck
