| » Error Codes E23 and E30 |
Model Number: WCVH6800J1WW Brand: GE Age: 5 - 10 years
I have a GE WCVH6800J1WW and getting error codes E23 and E30. I took the pump off and it's working fine when 120V applied. I don't get any voltage when I remove the pump and perform the t05 pump test. Should I get voltage at the pump WITHOUT the pump installed...if so I'm not getting any.
Ideas? Thanks, Ads By Google Related Models |
If the machine should be sending voltage to the pump then your test device should show 110/120 v coming to it. Sounds like the control unit is not directing voltage to the pump when it should, or less likely that there is a problem with the wiring.
__________________
| Display Modes | |
| Error Codes | arthenny | Refrigerator & Freezer Repair | 0 | 06-15-2011 04:23 PM |
| F21 and SD error codes | wacii | Washer Repair | 0 | 12-23-2010 12:41 PM |
| Whirlpool Codes? Do not seem to be error codes | taranewblue | Oven Repair (including Ranges and Cooktops) | 4 | 06-21-2010 06:21 PM |
| frigidaire error code F10 - not listed in your error codes | Skully26 | Oven Repair (including Ranges and Cooktops) | 2 | 02-16-2010 04:29 AM |
| error codes | sal p | Oven Repair (including Ranges and Cooktops) | 0 | 08-25-2009 04:23 PM |
