Discuss
No Spin Cycle
 in
Washer Repair
Hello, I need some help with my Maytag washer. This washer has worked great and never made any unusual noises
Appliance Repair Forum > Appliance Repair Help > Washer Repair » No Spin Cycle
  #1 (permalink)
Old 01-16-2013, 03:36 PM
Junior Member
KJH1961 is on a distinguished road
Default No Spin Cycle
Model Number: A206   Brand: Maytag   Age: More than 10 years
Hello,
I need some help with my Maytag washer. This washer has worked great and never made any unusual noises until recently. I have replaced several parts in the past including the timer, two belts, electric motor, motor glides and water pump. The washer was having a problem where the agitator was barely moving, but would spin and pump out the water.
I removed the old brake assy. which had several (8) screws and noticed that the brake material on the hub was almost down to the metal surface of the housing. I reinstalled the old brake unit, but wasn't sure how far to tighten the screws. When I tried the operation of the washer it would fill and go thru the cycle and agitate, but still wouldn't spin. I then loosened the screws on the old brake and then operated the washer and it would spin, but wouldn't agitate.
After doing some internet research and several blogs and posts most pointed to the brake assy. So, I figured I would try installing a new brake assy. #6-2011900. I ordered the brake and tool thru your company and installed two days ago. The installation was easy, the only issue was I had to remove the old bearing from the old brake housing. I checked the bearing and it was ok and greased and reinstalled the bearing on to the new brake assy.
I operated the washer and it agitates great, like it use to and makes no noises, not until it gets to the spin cycle then the drum doesn't spin and there is a whining sound which sounds like the belt. I took a flashlight while it was on the spin cycle and can see the motor pulley spinning and the pump working, but the belt going to the drum pulley (center) is not moving. I tried moving the pulley by hand to see if the drum moves, but it doesn't. I can spin the drum by hand from inside the washer.
The lady I was talking to from appliance parts mentioned about the brake not releasing. Could this possibly be a defective brake assy? Are there any things I can check? It's just odd everything worked correctly on this washer until the brake unit failed and now I can only get the agitator to work. Does this new brake assy. take a different bearing than the original bearing?
I'm at a loss......can you possibly help?
Sincerely
Kevin Hoffman
Ads By Google
Related Models
Maytag A206 WASHER-TOP LOADING
Maytag A206S WASHER-TOP LOADING
Maytag A207 WASHER-TOP LOADING
Maytag A207S WASHER-TOP LOADING
Maytag A208 WASHER-TOP LOADING
Maytag A208S WASHER-TOP LOADING
Maytag A209 WASHER-TOP LOADING
Maytag A209S WASHER-TOP LOADING
Maytag A210 WASHER-TOP LOADING
Maytag A210S WASHER-TOP LOADING
Maytag A211 WASHER-TOP LOADING
Maytag A211S WASHER-TOP LOADING
Maytag A212 WASHER-TOP LOADING
Maytag A212S WASHER-TOP LOADING
Maytag A21CA MANUAL, PARTS (WASHER)
Maytag A21CM MANUAL, PARTS (WASHER)
Maytag A21CT MANUAL, PARTS (WASHER)
Frigidaire A2238C2 Frg(v9) / Room Air Conditioner
Frigidaire A2238D2 Frg(v9) / Room Air Conditioner
Maytag A22CA MANUAL, PARTS (WASHER)
Maytag A22CM MANUAL, PARTS (WASHER)
Maytag A22CT MANUAL, PARTS (WASHER)
Maytag A23CA MANUAL, PARTS (WASHER)
Maytag A23CDL MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag A23CDW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag A23CSL MANUAL, PARTS (WASHER)
Maytag A23CSW MANUAL, PARTS (WASHER)
Maytag A23CT MANUAL, PARTS (WASHER)
Frigidaire A2438DC2 Frg(v10) / Room Air Conditioner
Frigidaire A2438DD2 Frg(v10) / Room Air Conditioner
Maytag A24CA MANUAL, PARTS (WASHER)
Maytag A25CA MAYTAG LAUNDRY (WASHER)
Maytag A25CAE MAYTAG LAUNDRY (WASHER)
Maytag A25CM MAYTAG LAUNDRY (WASHER)
Maytag A25CME MAYTAG LAUNDRY (WASHER)
Maytag A25CS MAYTAG LAUNDRY (WASHER)
Maytag A25CT MAYTAG LAUNDRY (WASHER)
Maytag A26CA MAYTAG LAUNDRY (WASHER)
Maytag A26CAE MAYTAG LAUNDRY (WASHER)
Maytag A26CD MAYTAG LAUNDRY (WASHER)
Maytag A26CDC MAYTAG LAUNDRY (WASHER)
Maytag A282 WASHER-TOP LOADING
Maytag A283 WASHER-TOP LOADING
Frigidaire A2838C2 Frg(v11) / Room Air Conditioner
Frigidaire A2838D2 Frg(v11) / Room Air Conditioner
Maytag A284 WASHER-TOP LOADING
General Electric A2B348CKALRA Zoneline
General Electric A2B348DAALRA Zoneline
General Electric A2B348DCALR1 Zoneline
General Electric A2B348DCALRA Zoneline
General Electric A2B348DCANR1 Zoneline
General Electric A2B348DEALRA Zoneline
General Electric A2B348DEASR1 Zoneline
General Electric A2B348DEASRA Zoneline
General Electric A2B348DGALRA Zoneline
General Electric A2B348ENFMRA Zoneline
General Electric A2B349DAALRA Zoneline
General Electric A2B358DAALRA Zoneline
General Electric A2B358DAASRA Zoneline
General Electric A2B358DAESRA Zoneline
General Electric A2B358DCALRA Zoneline
General Electric A2B358DCANRA Zoneline
General Electric A2B358DCASRA Zoneline
General Electric A2B358DCENRA Zoneline
General Electric A2B358DCFSRA Zoneline
General Electric A2B358DEALRA Zoneline
General Electric A2B358DEANRA Zoneline
General Electric A2B358DEASRA Zoneline
General Electric A2B358DEFSRA Zoneline
General Electric A2B358DGALRA Zoneline
General Electric A2B358DGANRA Zoneline
General Electric A2B358DGASRA Zoneline
General Electric A2B358ENASRA Zoneline
General Electric A2B358EPASRA Zoneline
General Electric A2B359DEASRA Zoneline
General Electric A2B359DGASRA Zoneline
General Electric A2B368DAALR1 Zoneline
General Electric A2B368DAASR1 Zoneline
General Electric A2B368DCALR1 Zoneline
General Electric A2B368DCASR1 Zoneline
General Electric A2B368DEAL2R Zoneline
General Electric A2B368DEAL3R Zoneline
General Electric A2B368DEALR1 Zoneline
General Electric A2B368DEASR1 Zoneline
General Electric A2B368DGALR1 Zoneline
General Electric A2B368ESASR1 Zoneline
General Electric A2B369DAASR1 Zoneline
General Electric A2B369DAELR1 Zoneline
General Electric A2B378DAALR1 Zoneline
General Electric A2B378DGALR1 Zoneline
General Electric A2B378DGAS1Y Zoneline
General Electric A2B378ESASR1 Zoneline
General Electric A2B379DEESR1 Zoneline
General Electric A2B383DAALR1 Zoneline
General Electric A2B383DAALR2 Zoneline
General Electric A2B383DAASR1 Zoneline
General Electric A2B383DAASR2 Zoneline
General Electric A2B383DACSR1 Zoneline
General Electric A2B383DACSR2 Zoneline
General Electric A2B383DCALR1 Zoneline
General Electric A2B383DCALR2 Zoneline
General Electric A2B383DEALR1 Zoneline
General Electric A2B383DEALR2 Zoneline
General Electric A2B383ENASR1 Zoneline
General Electric A2B383ENASR2 Zoneline
General Electric A2B383EPAS1Y Zoneline
General Electric A2B383EPAS2Y Zoneline
General Electric A2B383EPASR1 Zoneline
General Electric A2B383EPASR2 Zoneline
General Electric A2B383ESASR1 Zoneline
General Electric A2B383ESASR2 Zoneline
General Electric A2B388DAALR1 Zoneline
General Electric A2B388DAALR2 Zoneline
General Electric A2B388DAAS1Y Zoneline
General Electric A2B388DAAS2Y Zoneline
General Electric A2B388DAASR1 Zoneline
General Electric A2B388DAASR2 Zoneline
General Electric A2B388DACSR2 Zoneline
General Electric A2B388DCALR1 Zoneline
General Electric A2B388DCALR2 Zoneline
  #2 (permalink)
Old 01-17-2013, 05:52 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
The diagnosis of the brake not releasing is almost certainly correct, but I cannot really tell you why that is the case.
It is possible you have a bad brake assembly, and if you bought it from this site you can return it for a replacement. My first recommendation is to tear it down again and check the installation and see if you can determine why the brake is not releasing.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool cabrio wtw6400sw2 skips rinse cycle doesn't spin fast in wash cycle jwilman Washer Repair 0 09-13-2012 04:45 PM
washer will not fill with water on any cycle but still runs on spin cycle help Paul Linville Washer Repair 1 08-03-2012 11:39 AM
only spin cycle and drains. no agitate, water fill or rinse cycle reyd1 Washer Repair 0 07-01-2012 07:40 AM
Kenmore Washer - wont stop last spin cycle + how long spin cycle suppose to last? tc38 Washer Repair 3 04-29-2011 07:49 PM
Maytag wash won't spin on regular cycle but will on gentle cycle BlazingSun Washer Repair 0 01-07-2009 08:41 PM
