Discuss
steam & water leak
 in
Washer Repair
Washer was 13 months old when problems began. Steam cycle was intermittent, chronic water leak and service techs unable to
Appliance Repair Forum > Appliance Repair Help > Washer Repair » steam & water leak
  #1 (permalink)
Old 01-15-2013, 11:13 PM
Junior Member
flipfam1 is on a distinguished road
Default steam & water leak
Model Number: WF419aaw/xaa 02   Brand: Samsung   Age: 1 - 5 years
Washer was 13 months old when problems began. Steam cycle was intermittent, chronic water leak and service techs unable to resolve problem. The techs claimed no leak from washer to unrepairable because of lack of part availability.
The last tech insisted the leaking part was the Washer Housing. When the part arrived, it did not fit because my washer has the steam function. The part was for the regular model. Now into month 3, I reassembled the unit (minus the top) and ran it through an entire cycle. No leaking until the steam cycle at which time "Old Faithful" geyser erupted. All attempt to order the melted part were futile (PART NUMBER: DC62-00182A), no one had it in stock. I resorted to ordering the entire Hose Assembly at a significantly higher cost (PART NUMBER: DC97-12578E). Part arrived but it was not the same as the original and had the water flow running the wrong direction as well as lacking a valve. Out of desperation, I attempted to disassemble the new until extracting the part that was melted on mine. It worked, however, once installed the until melted.
I am not a service technician and I tried to talk to someone who is but they all wanted another $80. I was not willing to fork out any more money for unsuccessful repairs.
I finally did fix the unit myself. I removed the inner workings of the little valve at the bottom of the DC62-00182A part so it would function the same as the newly designed part but without having to purchase all new hoses to fit the new part.
I removed the heating unit and cleared out all the calcium and lime that had built up inside. Also removed the mineral deposits from the hose lines and the little spray nozzle that is inside the washer.
I am happy to report I now have a working washing machine. The Washer Housing is not leaking (never was). What happened is mineral deposits had clogged the PART NUMBER: DC97-09101L Substitution: DC97-09101H end nozzle causing a pressure build-up in the system. The original design release valve failed causing the plastic casing to melt and crack thus releasing the steam pressure.
If anyone has this problem, I'll be happy to walk ya through as to how to repair it. Will take about an hour of your time. Took me three days cuz I had to figure it out.
Ads By Google
Related Models
White Westinghouse WFC0510DW1 White Westinghouse/freezer
White Westinghouse WFC05K0DW0 White Westinghouse/freezer
Frigidaire WFC05M2AW0 Wwh(v1) / Chest Freezer
Frigidaire WFC07M2AW0 Wwh(v1) / Chest Freezer
White Westinghouse WFC07M2AW1 White Westinghouse/freezer
White Westinghouse WFC07M2AW2 White Westinghouse/freezer
White Westinghouse WFC07M2AW3 White Westinghouse/freezer
White Westinghouse WFC07M2AW4 White Westinghouse/freezer
White Westinghouse WFC07M2AW5 White Westinghouse/freezer
White Westinghouse WFC07M2AW6 White Westinghouse/freezer
White Westinghouse WFC07M2AW7 White Westinghouse/freezer
White Westinghouse WFC07M2AW8 White Westinghouse/freezer
White Westinghouse WFC07M2AW9 FREEZER
Frigidaire WFC07M3HW0 Whi(v0) / Freezer
White Westinghouse WFC07M3HW1 White Westinghouse/freezer
White Westinghouse WFC09K0DW0 White Westinghouse/freezer
Frigidaire WFC09M2AW0 Wwh(v1)
White Westinghouse WFC09M3BW0 White Westinghouse/freezer
White Westinghouse WFC09M3BW1 Whitewestinghouse/freezer
White Westinghouse WFC09M3BW2 White Westinghouse/freezer
White Westinghouse WFC09M3BW3 White Westinghouse/freezer
White Westinghouse WFC09M3BW4 FREEZER
White Westinghouse WFC09M3BW5 FREEZER
White Westinghouse WFC09M3BW6 FREEZER
Frigidaire WFC09M3HW0 Wwh(v0) / Freezer
White Westinghouse WFC09M3HW1 White Westinghouse/freezer
White Westinghouse WFC1310EW0 White Westinghouse/freezer
White Westinghouse WFC15K2BW0 White Westinghouse/freezer
White Westinghouse WFC15K2BW1 White Westinghouse/freezer
White Westinghouse WFC15K2BW2 White Westinghouse/freezer
White Westinghouse WFC15K2BW3 White Westinghouse/freezer
Frigidaire WFC15M3AW0 Wwh(v1) / Chest Freezer
Frigidaire WFC15M3AW1 Wwh(v1) / Chest Freezer
White Westinghouse WFC15M4BW0 White Westinghouse/freezer
White Westinghouse WFC15M4BW1 White Westinghouse/freezer
White Westinghouse WFC15M4BW2 White Westinghouse/freezer
White Westinghouse WFC15M4BW3 White Westinghouse/freezer
White Westinghouse WFC15M4BW4 FREEZER
White Westinghouse WFC15M4BW5 FREEZER
Frigidaire WFC15M4HW0 Whi(v0) / Refrigerator
White Westinghouse WFC15M4HW1 White Westinghouse/freezer
Frigidaire WFC18M4AW0 Wwh(v1) / Chest Freezer
White Westinghouse WFC20M3AW0 White Westinghouse/freezer
Frigidaire WFC20M4AW0 Wwh(v1) / Chest Freezer
Frigidaire WFC20M4AW1 Wwh(v1) / Chest Freezer
White Westinghouse WFC20M4BW0 White Westinghouse/freezer
White Westinghouse WFC20M4BW1 White Westinghouse/freezer
White Westinghouse WFC20M4BW2 White Westinghouse/freezer
White Westinghouse WFC20M4BW3 White Westinghouse/freezer
White Westinghouse WFC20M4BW4 White Westinghouse/freezer
White Westinghouse WFC20M4BW5 White Westinghouse/freezer
White Westinghouse WFC20M4BW6 FREEZER
Frigidaire WFC20M4HW0 Whi(v1) / Freezer
White Westinghouse WFC20M4HW1 White Westinghouse/freezer
White Westinghouse WFC25M3AW0 White Westinghouse/freezer
White Westinghouse WFC25M4BW0 White Westinghouse/freezer
White Westinghouse WFC25M4BW1 White Westinghouse/freezer
White Westinghouse WFC25M4BW2 White Westinghouse/freezer
White Westinghouse WFC25M4BW3 White Westinghouse/freezer
White Westinghouse WFC25M4BW4 White Westinghouse/freezer
White Westinghouse WFC25M4BW5 FREEZER
White Westinghouse WFC25M4BW6 FREEZER
White Westinghouse WFC25M4BW7 FREEZER
Frigidaire WFC25M4HW0 Whi(v2) / Freezer
White Westinghouse WFC25M4HW1 White Westinghouse/freezer
White Westinghouse WFC25M4HW2 White Westinghouse/freezer
Frigidaire WFC25M7AW0 Wwh(v1) / Chest Freezer
Frigidaire WFC25M7AW1 Wwh(v1) / Chest Freezer
Whirlpool WFC7500VW0 COMPACT AUTOMATIC WASHER
Whirlpool WFC7500VW1 WASHER
Whirlpool WFE114LWS0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool WFE115LXB0 30" ELECTRIC FREESTANDING RANGE
Whirlpool WFE115LXQ0 30" ELECTRIC FREESTANDING RANGE
Whirlpool WFE260LXS0 30" ELECTRIC FREESTANDING RANGE
Whirlpool WFE301LVB0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool WFE301LVQ0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool WFE301LVS0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool WFE321LWB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE321LWQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE321LWS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE324LWB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE324LWB1 30" ELECTRIC FREESTANDING RANGE
Whirlpool WFE324LWQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE324LWQ1 30" ELECTRIC FREESTANDING RANGE
Whirlpool WFE324LWS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE324LWS1 30" ELECTRIC FREESTANDING RANGE
Whirlpool WFE361LVB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE361LVB1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE361LVD0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE361LVD1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE361LVQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE361LVQ1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE361LVS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE361LVS1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE361LVT0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE361LVT1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE364LVB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE364LVD0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE364LVQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE364LVS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE364LVT0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE366LVB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE366LVQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE366LVS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE366LVT0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE371LVB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE371LVQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE371LVS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE371LVT0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE374LVB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WFE374LVQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WFE374LVS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WFE374LVT0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WFE381LVB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WFE381LVB1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE381LVQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WFE381LVQ1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE381LVS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WFE381LVS1 30" ELECTRIC CERAN FREESTANDING RANGE
White Westinghouse WFF334GCA ELECTRIC RANGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet Steam Dryer had water in vent hose dlhord Dryer Repair 6 09-10-2012 05:19 PM
Dishwasher water leak near water pump frogger63 Dishwasher Repair 1 11-25-2011 02:43 AM
LG Tromm Steam Fresh will not steam gadbearr Washer Repair 0 08-22-2009 10:42 AM
water leak in front of refrigerator when using water dispenser RichardCh Refrigerator & Freezer Repair 0 08-10-2009 10:29 AM
water leak in back from water line TRUSTART Refrigerator & Freezer Repair 1 04-05-2009 07:01 AM
