Discuss
Washer wont spin, but agitates?
 in
Washer Repair
Hi! I have a Kenmore 80 series washer and it recently stopped spinning and agitating and I found out it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer wont spin, but agitates?
  #1 (permalink)
Old 01-14-2013, 05:06 PM
Junior Member
Chaase is on a distinguished road
Default Washer wont spin, but agitates?
Brand: Kenmore   Age: 5 - 10 years
Hi! I have a Kenmore 80 series washer and it recently stopped spinning and agitating and I found out it was the coupler. So I changed that and it start to work again, normally. After a week or two it stopped spinning during spin cycle, but it still agitates. I did some research and tests and this is what I came up with over the past two days:
- The coupler is fine
- The pump isn't clogged. It spins fine and drains fine.
- The lid switch works perfectly
- While the agitator is spinning, I can stop it by holding it with my hand from making a rotation forward or backwards. I couldn't do that before
- I can spin the tub with my hands with about 5-10lbs of resistance.
- The clutch under the tub doesn't spin during spin cycle.
- When I change speed settings(medium to low or to high) for the agitator, the speed doesn't change.
From doing searching I think that it could possibly be the Gearcase/Transmission, the Tub Hub, or the Belt, if it has one and that is as much as I know.
Please help me figure this problem out. Its pretty annoying not having a working washer :/
Ads By Google
  #2 (permalink)
Old 01-14-2013, 05:32 PM
Junior Member
Default
The model number is 110.29842991
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer wont drain or spin - agitates throughout cycle Washer Puzzle Washer Repair 1 09-04-2012 05:53 PM
amana washer wont spin,pump free ,replaced belt and pulley, agitates but makes terri hndy1331 Washer Repair 1 03-05-2012 02:33 PM
agitates but wont spin possh23 Washer Repair 2 09-27-2011 03:58 PM
Washer Agitates Really Slow and Wont spin lowside Washer Repair 0 11-11-2010 03:48 PM
GE washer agitates but wont spin maddness35 Washer Repair 3 11-14-2008 05:05 AM
