Discuss
F-11 Error Kenmore Elite Frontloading Washer
 in
Washer Repair
F-11 problem shortly after trying to start wash cycle. Already replaced CCU without benefit. Almost all other tests in the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » F-11 Error Kenmore Elite Frontloading Washer
  #1 (permalink)
Old 01-14-2013, 01:52 PM
Junior Member
geo999 is on a distinguished road
Default F-11 Error Kenmore Elite Frontloading Washer
Model Number: 11042926200   Brand: Kenmore   Age: 5 - 10 years
F-11 problem shortly after trying to start wash cycle. Already replaced CCU without benefit. Almost all other tests in the Service Manual are in Spec. Checked all that connections and wires - no obvious issue but cleaned connectors w QD Electronics Cleaner. Made sure all connections are snug. Checked the connections to the motor - all good. Windings in motor in spec on continuity test. Is there any way to find out if this is a fault within the wiring harness and where. Also any way to nail down whether this is an MCU problem. Again checked the continuity test and connections for the MCU and connections are snug and continuity readings at the MCU are nominal. Needless to say I am frustrated that I can't fix the machine and pin down what exactly is wrong. Replacing expensive parts to find out is not what I had in mind. TIA
George
Ads By Google
Related Models
Kenmore 11049182992 WASHER
Kenmore 11049722990 AUTOMATIC WASHER
Kenmore 11049722991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11049722992 COMPACT WASHER
Kenmore 11051115 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051140 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051309 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051730 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055592 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055593 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055594 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055610 WORM GEAR CASE ASSEMBLY
Kenmore 11055614 WORM GEAR CASE ASSEMBLY
Kenmore 11056171 WORM GEAR CASE ASSEMBLY
Kenmore 11056172 WORM GEAR CASE ASSEMBLY
Kenmore 11056464 WORM GEAR CASE ASSEMBLY
Kenmore 11057624 KENMORE PERMANENT INSTALLATION CONV KIT
Kenmore 11057929 KENMORE DUAL AGITATOR KIT
Kenmore 1105809106 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809500 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809502 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809503 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809702 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809703 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809704 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809800 KENMORE GAS CONBINATION WASHER-DRYER
Kenmore 1105907400 KENMORE GAS DRYER
Kenmore 1105907500 KENMORE GAS DRYER
Kenmore 1105907501 KENMORE GAS DRYER
Kenmore 1105907600 KENMORE GAS DRYER
Kenmore 1105907610 KENMORE GAS-DRYER
Kenmore 1105907700 KENMORE GAS DRYER
Kenmore 1105907710 KENMORE GAS DRYER
Kenmore 1105907720 KENMORE GAS DRYER
Kenmore 1105907721 KENMORE GAS DRYER
Kenmore 1105907730 KENMORE GAS DRYER
Kenmore 1105907800 KENMORE GAS DRYER
Kenmore 1105907801 KENMORE GAS DRYER
Kenmore 1105907802 KENMORE GAS DRYER
Kenmore 1105907950 KENMORE GAS DRYER
Kenmore 1105907951 KENMORE GAS DRYER
Kenmore 1105908000 KENMORE ELECTRIC DRYER
Kenmore 1105908100 KENMORE ELECTRIC DRYER
Kenmore 1105908300 KENMORE ELECTRIC DRYER
Kenmore 1105908400 KENMORE ELECTRIC DRYER
Kenmore 1105908500 KENMORE ELECTRIC DRYER
Kenmore 1105908501 KENMORE ELECTRIC DRYER
Kenmore 1105908600 KENMORE ELECTRIC DRYER
Kenmore 1105908700 KENMORE ELECTRIC DRYER
Kenmore 1105908710 KENMORE ELECTRIC DRYER
Kenmore 1105908711 KENMORE ELECTRIC DRYER
Kenmore 1105908800 KENMORE ELECTRIC DRYER
Kenmore 1105908801 KENMORE ELECTRIC DRYER
Kenmore 1105908810 KENMORE ELECTRIC DRYER
Kenmore 1105908811 KENMORE ELECTRIC DRYER
Kenmore 1105908950 KENMORE ELECTRIC DRYER
Kenmore 1105908951 KENMORE ELECTRIC DRYER
Kenmore 1105908960 KENMORE ELECTRIC DRYER
Kenmore 1105909500 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105909501 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105909502 KENMORE GAS COMBINATON WASHER-DRYER
Kenmore 1105909503 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105917200 KENMORE GAS DRYER
Kenmore 1105917400 KENMORE GAS DRYER
Kenmore 1105917500 KENMORE GAS DRYER
Kenmore 1105917510 KENMORE GAS DRYER
Kenmore 1105917600 KENMORE GAS DRYER
Kenmore 1105917620 KENMORE GAS DRYER
Kenmore 1105917630 KENMORE GAS DRYER
Kenmore 1105918400 KENMORE ELECTRIC DRYER
Kenmore 1105918500 KENMORE ELECTRIC DRYER
Kenmore 1105918600 KENMORE ELECTRIC DRYER
Kenmore 1105918620 KENMORE ELECTRIC DRYER
Kenmore 11060052990 DRYER/WASHER
Kenmore 11060052991 ELECTRIC DRYER
Kenmore 11060056990 ELECTRIC DRYER
Kenmore 11060056991 ELECTRIC DRYER
Kenmore 1106007101 KENMORE GAS DRYER
Kenmore 11060072990 DRYER
Kenmore 11060072991 ELECTRIC DRYER
Kenmore 1106007301 KENMORE GAS DRYER
Kenmore 1106007400 KENMORE GAS DRYER
Kenmore 1106007430 KENMORE GAS DRYER
Kenmore 1106007440 KENMORE GAS DRYER
Kenmore 1106007500 KENMORE GAS DRYER
Kenmore 1106007600 KENMORE GAS DRYER
Kenmore 1106007610 KENMORE GAS DRYER
Kenmore 1106007700 KENMORE GAS DRYER
Kenmore 1106007710 KENMORE GAS DRYER
Kenmore 1106007711 KENMORE GAS DRYER
Kenmore 1106007712 KENMORE GAS DRYER
Kenmore 1106007713 KENMORE GAS DRYER
Kenmore 1106007714 KENMORE GAS DRYER
Kenmore 1106007715 KENMORE GAS DRYER
Kenmore 1106007716 KENMORE GAS DRYER
Kenmore 1106007717 KENMORE GAS DRYER
Kenmore 1106007800 KENMORE GAS DRYER
Kenmore 1106007950 KENMORE GAS DRYER
Kenmore 1106008000 KENMORE ELECTRIC DRYER
Kenmore 1106008100 KENMORE ELECTRIC DRYER
Kenmore 1106008300 KENMORE ELECTRIC DRYER
Kenmore 1106008400 KENMORE ELECTRIC DRYER
Kenmore 1106008430 KENMORE ELECTRIC DRYER
Kenmore 1106008440 KENMORE ELECTRIC DRYER
Kenmore 1106008500 KENMORE ELECTRIC DRYER
Kenmore 1106008600 KENMORE ELECTRIC DRYER
Kenmore 1106008700 KENMORE ELECTRIC DRYER
Kenmore 1106008710 KENMORE ELECTRIC DRYER
Kenmore 1106008711 KENMORE ELECTRIC DRYER
Kenmore 11061062000 DRYER
Kenmore 11061064000 DRYER
Kenmore 11061066000 DRYER
Kenmore 1106107400 KENMORE GAS DRYER
Kenmore 1106107401 KENMORE GAS DRYER
Kenmore 1106107500 KENMORE GAS DRYER
Kenmore 1106107501 KENMORE GAS DRYER
Kenmore 1106107502 KENMORE GAS DRYER
Kenmore 1106107700 KENMORE GAS DRYER
Kenmore 1106107701 KENMORE GAS DRYER
Kenmore 1106107710 KENMORE GAS DRYER
  #2 (permalink)
Old 01-15-2013, 05:44 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by geo999 View Post
...Almost all other tests in the Service Manual are in Spec...
Hi George,
The diagnostic test consists of 8 steps. Can you post which of them were out of spec and what was it?
Check that the serial harness at the MCU is not mounted upside down. The wires should be to the left when facing the MCU connector.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 01-16-2013, 05:21 AM
Junior Member
Default F11 Error
Test sequence gives F11 error at C-2. When I check suggested causes all are in spec. When I have followed the service manual for f11 error, I am down to the Motor Control Board and the Wiring Harness. Already replaced the CCU. All tests listed in user manual are in spec except for checks that required running the machine. Needless to say I am not happy that there is no way to discern if it is the MCU or wiring without replacing them. Two questions I am most suspicious of a problem with the serial comm connector. Is the a way to buy replacement connectors to splice and try? What is the proper way to tight the connectors on each end? TIA
G
  #4 (permalink)
Old 01-16-2013, 12:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
...Is the a way to buy replacement connectors to splice and try?...
...What is the proper way to tight the connectors on each end?...
Hi George,
The first answer is No. Whirlpool does not sell it separate.
I don't think it is possible to tight it.
Based on the information you provided more likely the problem is a bad MCU. The part is expensive but if you'll order it from APP and it would not fix the problem then you can return it.
- The MCU Part number: 8182706
__________________
  #5 (permalink)
Old 01-16-2013, 01:31 PM
Junior Member
Default
Quote:
Originally Posted by Gene View Post
Hi George,
I have already ordered it. Hoping and praying it solves the issue.
  #6 (permalink)
Old 01-16-2013, 02:12 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I hope so. Keep us posted.
__________________
  #7 (permalink)
Old 01-20-2013, 03:11 PM
Junior Member
Default
MCU replacement did not work. Ordered a new wiring harness.
  #8 (permalink)
Old 01-21-2013, 01:56 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Which CCU is currently installed - old or new?
__________________
  #9 (permalink)
Old 01-22-2013, 04:44 PM
Junior Member
Default F-11 Error
1. Replaced the CCU - no go.
2. Replaced the MCU - also no go.
3. Wire connectors checked and in the process of "tightening" - no go so far have done 11, 6,7, 8 connectors on CCU and all connectors on MCU - no go
4. Wirings on Motor all 6 ohms - nominal
5. Motor spins w/o difficulty
6. Connectors to motor are tight
7. Pulley belt in good shape.
8. Cleaned drain filter and tubes from tub to drain motor.
9. Impeller spins w/o difficulty and electrical contact appears solid
10. Cleaned tube for Pressure switch w ass plastic attachment to tub
11. Ordered new wire harness for CCU and waiting for it to come in.
Needless to say this is my last shot at this. If the wire harness does not work will call Sears repairman. If you have any other ideas I am all ears.
The door lock solenoid clicks twice in the early part of the cycle and door check indicates it is locked as it should be. Also no FDL errors.
  #10 (permalink)
Old 01-22-2013, 10:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
It should work with both new CCU and MCU installed. Otherwise I'm stumped. Unfortunately abilities of remote diagnosis are limited.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Error Code F5 for Model #11045087404 - Kenmore Elite Residential washer robertmach@hotmail.com Washer Repair 2 03-13-2012 03:52 PM
Kenmore Elite Washer model 110.22052100 error code 6 with heavy loads rapafe Washer Repair 0 03-13-2012 02:11 PM
Ho6 error code on Kenmore Elite HE4t washer Baldhills Washer Repair 0 08-28-2011 04:45 AM
Kenmore Elite Washer F1 Error Code garystarh Washer Repair 3 06-25-2011 10:46 AM
Kenmore Elite HE3 Electric Washer F-DL Error BerkelUSA Washer Repair 3 07-20-2009 09:00 AM
