Discuss
Washer fills completely then stops cycle
 in
Washer Repair
Kenmore Elite Model 26922 Top Load Washer, purchased 6/5/05. On normal wash cycle, it fills completely. When it follows the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer fills completely then stops cycle
  #1 (permalink)
Old 01-14-2013, 10:03 AM
Junior Member
Jay1454 is on a distinguished road
Default Washer fills completely then stops cycle
Model Number: 26922   Brand: Kenmore   Age: 5 - 10 years
Kenmore Elite Model 26922 Top Load Washer, purchased 6/5/05. On normal wash cycle, it fills completely. When it follows the cycle and goes to agitate, it becomes completely dead. It doesn't start agitating, nor is there any noise to indicate the motor has engaged. If I turn the timer to spin, etc. nothing happens. Now, if I disconnect the power for about 10s, then resume timer on agitate, it will run till competion. I checked lid switch & water fill switch, and appears they are working properly. Any ideas?
Ads By Google
Related Models
Maytag 2699A Refrigerator/Freezer
Maytag 2699W Refrigerator/Freezer
Jenn-Air 2700EEL WALLOVEN- STD ELE
Hoover 2720
Hoover 2726
Roper 2733*0A Ranges, Electric*
Roper 2733W0A Ranges, Electric*
Roper 2735*0A Ranges, Electric*
Jenn-Air 2750ELS WALLOVEN- STD ELE
Roper 2763*0A Ranges, Electric*
Roper 2763W0A Ranges, Electric*
Roper 2765*0A Ranges, Electric*
Roper 2765W0A Ranges, Electric*
Jenn-Air 2770ELD WALLOVEN- STD ELE
Jenn-Air 2775ELD WALLOVEN- STD ELE
Hoover 2800
Frigidaire 2803 GAS RANGE
Frigidaire 2803-80B GAS RANGE
Frigidaire 28044 FRIGIDAIRE GAS RANGE
Frigidaire 280440C GAS RANGE
Frigidaire 280447C GAS RANGE
Frigidaire 2809A GAS RANGE
Frigidaire 2811 GAS RANGE
Frigidaire 2812A GAS RANGE
Frigidaire 2813-80B GAS RANGE
Frigidaire 2813A GAS RANGE
Frigidaire 2819A GAS RANGE
Frigidaire 2820A GAS RANGE
Frigidaire 282240A GAS RANGE
Frigidaire 282240B GAS RANGE
Frigidaire 282240C GAS RANGE
Frigidaire 282247B GAS RANGE
Frigidaire 282247C GAS RANGE
Frigidaire 2822A GAS RANGE
Frigidaire 2823 GAS RANGE
Frigidaire 2823-80B GAS RANGE
Frigidaire 2828A GAS RANGE
Frigidaire 2829A GAS RANGE
Hoover 2830
Frigidaire 2833 GAS RANGE
Frigidaire 2833-80B GAS RANGE
Frigidaire 2834-80A GAS RANGE
Frigidaire 2834-80B FRIGIDAIRE GAS RANGE
Frigidaire 2834-87B FRIGIDAIRE GAS RANGE
Frigidaire 283440A GAS RANGE
Frigidaire 283440B GAS RANGE
Frigidaire 283440C FRIGIDAIRE GAS RANGE
Frigidaire 283440D GAS RANGE
Frigidaire 283447B GAS RANGE
Frigidaire 283447C FRIGIDAIRE GAS RANGE
Frigidaire 283447D GAS RANGE
Frigidaire 283460B GAS RANGE
Frigidaire 283460C GAS RANGE
Frigidaire 283467B GAS RANGE
Frigidaire 283467C GAS RANGE
Hoover 2836
Frigidaire 28364 GAS RANGE
Frigidaire 2841A GAS RANGE
Frigidaire 284260A GAS RANGE
Frigidaire 284267A GAS RANGE
Frigidaire 2843-80A GAS RANGE
Frigidaire 2843-80B GAS RANGE
Frigidaire 2843-80C GAS RANGE
Roper 2843W0A Ranges, Electric*
Frigidaire 284440A GAS RANGE
Frigidaire 284440B GAS RANGE
Frigidaire 284447A GAS RANGE
Frigidaire 284447B GAS RANGE
Frigidaire 2851A GAS RANGE
Frigidaire 2853 GAS RANGE
Frigidaire 28564 FRIGIDAIRE GAS RANGE
Frigidaire 285640A FRIGIDAIRE GAS RANGE
Frigidaire 285640B GAS RANGE
Frigidaire 285640D GAS RANGE
Frigidaire 285640E GAS RANGE
Frigidaire 285647A FRIGIDAIRE GAS RANGE
Frigidaire 285647B GAS RANGE
Frigidaire 285647D GAS RANGE
Frigidaire 285647E GAS RANGE
Frigidaire 285660A GAS RANGE
Frigidaire 285667A GAS RANGE
Frigidaire 28584 GAS RANGE
Frigidaire 285840A GAS RANGE
Frigidaire 285840B GAS RANGE
Frigidaire 285840C GAS RANGE
Frigidaire 285840D GAS RANGE
Frigidaire 285847A GAS RANGE
Frigidaire 285847B GAS RANGE
Frigidaire 285847C GAS RANGE
Frigidaire 285847D GAS RANGE
Frigidaire 28586 FRIGIDAIRE GAS RANGE
Frigidaire 285860A GAS RANGE
Frigidaire 285860B FRIGIDAIRE GAS RANGE
Frigidaire 285860C FRIGIDAIRE GAS RANGE
Frigidaire 285867A GAS RANGE
Frigidaire 28594 FRIGIDAIRE GAS RANGE
Frigidaire 285940A FRIGIDAIRE GAS RANGE
Frigidaire 285940B GAS RANGE
Frigidaire 285941A FRIGIDAIRE GAS RANGE
Frigidaire 285947A FRIGIDAIRE GAS RANGE
Frigidaire 285947B GAS RANGE
Frigidaire 2859A GAS RANGE
Frigidaire 2861A GAS RANGE
Frigidaire 2864 GAS RANGE
Frigidaire 2864-80B GAS RANGE
Frigidaire 2869A GAS RANGE
Frigidaire 2871A GAS RANGE
Roper 2872*0A Ranges, Electric*
Frigidaire 2872A GAS RANGE
Roper 2872W0A Ranges, Electric*
Frigidaire 2873 GAS RANGE
Frigidaire 2873B GAS RANGE
Frigidaire 2879A GAS RANGE
Frigidaire 2881 GAS RANGE
Frigidaire 2883 GAS RANGE
Roper 2883*10 Ranges, Electric*
Frigidaire 2883-80A GAS RANGE
Frigidaire 2883-81A GAS RANGE
Frigidaire 2883-81B GAS RANGE
Roper 2883W10 Ranges, Electric*
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
My washer fills so slowly with cold water & stops before rinse cycle JennH Washer Repair 6 07-29-2012 10:20 AM
the timer sticks and will not finish cycle when it gets to rinse it fills but stops metalbender Washer Repair 2 03-15-2012 04:18 PM
maytag dishwasher promply stops after it fills and attempts cycle start.. morelandjoseph Dishwasher Repair 0 07-24-2011 05:47 PM
washer fills water,agitate,drain and spin than completely stops.replace timer no t ok stuiwailevu Washer Repair 1 06-23-2011 10:37 AM
Water fills for initial cycle then stops isturgill Dishwasher Repair 0 06-06-2010 02:21 PM
