| » Need help to correct water fill on washer |
Model Number: number not legible Brand: Frigidaire Age: 5 - 10 years
I have a Gallery Series washer (new in 2005, 13 cycles, two speed motor) that will not fill with enough water to wash large loads of laundry (other cycles work properly). I cannot read the serial numbers since they are located on the inside lid and are not legible.
Can I do anything to change the water level? Ads By Google Related Models |
Hi.
Was this problem from the beginning or slowly developed? Try this: drain water completely out, remove the air hose from the pressure switch and blow inside.Reconnect it back and see if that help. If not - you may need to replace the pressure switch. Check if there is the part # on the body. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Need help to correct water fill on washer | pwnoble14 | Washer Repair | 1 | 01-15-2013 05:44 PM |
| washer won't fill with water. | mikeshawver | Washer Repair | 2 | 04-21-2012 02:27 PM |
| washer will not fill with water | molarkey | Washer Repair | 5 | 01-03-2010 04:50 PM |
| washer will not fill up with water | mory8687 | Washer Repair | 1 | 05-12-2009 05:03 PM |
| washer doesn't fill with water | cla | Washer Repair | 2 | 02-06-2008 03:30 PM |
