Discuss
Washing machine spin cycle off balance
 in
Washer Repair
I have an Admiral washer that is off balance in the spin cycle almost every wash. You have to rebalance
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washing machine spin cycle off balance
  #1 (permalink)
Old 02-03-2008, 08:34 PM
Junior Member
Mike Diven is on a distinguished road
Default Washing machine spin cycle off balance
Model Number: LNC6757   Brand: Admiral   Age: 5 - 10 years
I have an Admiral washer that is off balance in the spin cycle almost every wash. You have to rebalance the clothes quite a few times to make it through the wash cycle. Any ideas?
Ads By Google
Related Models
International LNC6760A71 Washer - Top Loading
Admiral LNC6760B71 Washer - Top Loading
International LNC6762A01 Washer - Top Loading
Admiral LNC6762A01 Washer - Top Loading
International LNC6762A71 Washer - Top Loading
Admiral LNC6762A71 Washer - Top Loading
International LNC6762A77 Washer - Top Loading
Admiral LNC6762A77 Washer - Top Loading
Admiral LNC6762B01 Washer - Top Loading
Admiral LNC6762B71 Washer - Top Loading
Admiral LNC6764A00 Washer - Top Loading
Admiral LNC6764A71 Washer - Top Loading
Admiral LNC6766A00 Washer - Top Loading
Admiral LNC6766A01 Washer - Top Loading
Admiral LNC6766A71 Washer - Top Loading
Admiral LNC6766A77 Washer - Top Loading
Admiral LNC6766B71 Washer - Top Loading
Admiral LNC7760A00 Dryer - Ele
Admiral LNC7760A71 Dryer - Ele
Admiral LNC7764A00 Dryer - Ele
Admiral LNC7764A71 Dryer - Ele
Admiral LNC7764A77 Dryer - Ele
Admiral LNC7766A00 Dryer - Ele
International LNC7766A00 Dryer - Ele
Admiral LNC7766A71 Dryer - Ele
International LNC7766A71 Dryer - Ele
Admiral LNC7766B71 Dryer - Ele
International LNC8760A00 Dryer - Gas
International LNC8760A01 Dryer - Gas
International LNC8760A71 Dryer - Gas
International LNC8760A77 Dryer - Gas
Admiral LNC8764A00 Dryer - Gas
Admiral LNC8764A71 Dryer - Gas
Admiral LNC8766A00 Dryer - Gas
International LNC8766A00 Dryer - Gas
Admiral LNC8766A71 Dryer - Gas
International LNC8766A71 Dryer - Gas
Admiral LNC8766B71 Dryer - Gas
Amana LP13300.A Mwave - Family Size (60 Hz)
Amana LP13300.B Mwave - Family Size (60 Hz)
Amana LP13600.A Mwave - Family Size (60 Hz)
Amana LP13600.B Mwave - Family Size (60 Hz)
Amana LP13610.A Mwave - Family Size (60 Hz)
Amana LP13610.B Mwave - Family Size (60 Hz)
Amana LP16400.A Mwave - Family Size (60 Hz)
Amana LP16400.B Mwave - Family Size (60 Hz)
Amana LP16600.A Mwave - Family Size (60 Hz)
Amana LP16600.B Mwave - Family Size (60 Hz)
Amana LP16610.A Mwave - Family Size (60 Hz)
Amana LP16610.B Mwave - Family Size (60 Hz)
Amana LP24400.A Mwave - Family Size (60 Hz)
Amana LP24400.B Mwave - Family Size (60 Hz)
Amana LP24600.A Mwave - Family Size (60 Hz)
Amana LP24600.B Mwave - Family Size (60 Hz)
Amana LP83400.A Mwave - Family Size (60 Hz)
Amana LP83400.B Mwave - Family Size (60 Hz)
Amana LP83430.A Mwave - Family Size (60 Hz)
Amana LP83430.B Mwave - Family Size (60 Hz)
Amana LP83600.A Mwave - Family Size (60 Hz)
Amana LP83600.B Mwave - Family Size (60 Hz)
Amana LP83620.A Mwave - Family Size (60 Hz)
Amana LP83630.A Mwave - Family Size (60 Hz)
Amana LP83630.B Mwave - Family Size (60 Hz)
Admiral LPK5404ARW Kitchen Compact
Admiral LPK5404ARZ Kitchen Compact
Admiral LPR1115ADW Range - F/s Std Gas
Whirlpool LPR4231AG0
Whirlpool LPR4231AN0
Whirlpool LPR4231AW0
Whirlpool LPR6244AN0
Whirlpool LPR6244AW0
Maytag LRSC20A Ref - Sxs
Maytag LRSD20A Ref - Sxs
Maytag LRSD22A Ref - Sxs
Maytag LRSD24A Ref - Sxs
Maytag LRSW22A Ref - SXS/I&W
Maytag LRSW24A Ref - SXS/I&W
  #2 (permalink)
Old 02-04-2008, 01:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Is the washer leveled properly? Both front legs are adjustable.
Is the floor solid?
Is it enough water in the washer? Insufficient amount of water could cause a dis-balance.
Remove the front panel and check the suspension.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-05-2008, 12:18 AM
Junior Member
Default
Yes the washer is level and is solid. I took the front off and found all 6 springs good. The washer does fill up to the proper level. On this model is there pads or anything that it rides on? I didn't see anything out of the ordinary. Do you know where I can look at the repair manual so I can see what the tub turns on undeneath and see if that is the problem?
  #4 (permalink)
Old 01-01-2009, 09:51 AM
Junior Member
tbrady is on a distinguished road
Default To replace snubber
Admiral Washer LNC6760A71, LNC6762, LNC6757, LNC6764, LNC6766 and others
Snubber is a cone shaped Teflon ring that supports the weight of the drum and transmission. When it wears out, drum will knock on sides of cabinet and washer may walk across floor. To replace snubber :
  • Remove power and all hoses
  • Lift top by inserting putty knife just inside front clips to release
  • Remove front and rear panels, 10mm
  • Disconnect drain hose from bottom of drum, pliers - spring clip
  • Remove 6 springs from bottom of drum using channel lock or spring tool
  • Lay on side, remove drive belt by turning large drive pulley and side tension to belt
  • Remove water level hose on side of drum, pliers - spring clip
  • Remove drum from cabinet by sliding out top. It is not necessary to remove drum from transmission.
  • Inspect base plate for damage
  • Lay drum on padded surface, upside down
  • Remove C clip, drive pulley, being careful to observe order of parts and washers
  • Loosen 6 screws holding down old snubber. DO NOT REMOVE SCREWS, THERE IS A VERY STRONG SPRING UNDER THIS PLATE. Loosen screws only enough to get old snubber out.
  • Clean dust from area.
  • Insert new snubber, keeping it even while tightening screws.
  • Reverse other processes above to assemble washer. Replace any broken drum springs. Replace belt if worn.
Cost: $5.00 time: 1.5 hours
__________________
Harry Homeowner
  #5 (permalink)
Old 01-03-2009, 10:30 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Thank you Harry. Very useful information.
__________________
  #6 (permalink)
Old 02-04-2010, 09:55 AM
Junior Member
GCUC is on a distinguished road
Default
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
  #7 (permalink)
Old 02-04-2010, 10:03 AM
Junior Member
Default Off balanced Admiral
I have the same problem. Must be a common one with Adimirals. I have a Adimiral AAV7000AWW. Whould this be the same procedure for this clothes washer? Thanks, GCUC
  #8 (permalink)
Old 02-04-2010, 11:16 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by GCUC View Post
I have the same problem. Must be a common one with Admirals. I have a Adimiral AAV7000AWW. Whould this be the same procedure for this clothes washer? Thanks, GCUC
Yes, I believe so.
__________________
  #9 (permalink)
Old 09-10-2010, 06:22 PM
Junior Member
dannelson is on a distinguished road
Default
I have the same deal and was wondering if there is any way to service or adjust the counterweight, as my ring and springs look and seem to be in good condition.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washing machine leaking during last spin cycle FRABBIELE Washer Repair 0 02-09-2010 12:23 PM
Washing machine jumps during spin cycle hobbyasu Washer Repair 2 06-16-2009 05:11 PM
Washing machine spin cycle does not work pamilyas@gmail.com Washer Repair 9 05-17-2008 10:54 AM
Washing Machine leaking - spin basket out of balance? sherryh Washer Repair 1 03-31-2008 02:00 PM
Washing Machine leaking - spin basket out of balance? sherryh Washer Repair 1 03-31-2008 01:26 PM
