| » Another F code problem |
Model Number: GHW9400PL Brand: Maytag Age: 5 - 10 years
I don't remember the exact code but have an F1, 10 or 11 code pop up and the washer stops and beeps. THis started a couple of years ago. On another forum at that time, I was told that one of the tricks to start the machine again was to tap the upper left rear side towards the back with a rubber mallot. I guess it knoks something loose enough to get it going again. Well it's happening too much these days and the part needs to be replaced. I need help identifying the component in the area described. Can anyone help? Thanks. Scott
Hi Scott,
Per your description it could be the Central Control Unit (#15 at the diagram), a bad connections between the CCU and the Motor Control Unit (#1 at the diagram) or a bad MCU. Check the wires and connections and replace the CCU first. If it would not fix the problem, replace the MCU. - The CCU Part number: 8182697 - The MCU Part number: 8182706 Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| F13 Error Code - Broiler Problem | treydyer | Oven Repair (including Ranges and Cooktops) | 10 | 03-17-2012 08:28 AM |
| code F50, F51 problem | khordad34 | Washer Repair | 1 | 01-23-2012 01:11 PM |
| fault code problem | dc123 | Oven Repair (including Ranges and Cooktops) | 0 | 09-28-2009 07:22 AM |
| f7 code problem | Dang | Oven Repair (including Ranges and Cooktops) | 0 | 03-02-2009 08:35 AM |
| Frigidaire oven problem F13 code | Brent | Oven Repair (including Ranges and Cooktops) | 0 | 09-20-2007 03:21 PM |
