Discuss
wet clothes
 in
Washer Repair
so it fits tight into the pump with no sloppiness, correct? and could you tell me what the belt size
Appliance Repair Forum > Appliance Repair Help > Washer Repair » wet clothes
  #11 (permalink)
Old 01-19-2013, 04:11 PM
Junior Member
ljs.52 is on a distinguished road
Default wet clothes
and could you tell me what the belt size is?
  #12 (permalink)
Old 01-19-2013, 04:29 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Yes, the shaft should fit tight into the pump.
Here is what Maytag says about the belts for this model, so you do need to make sure you have the right one.
"Reassembly of Pump and Belt
NOTE: Install pump and belt together. Drive belt MUST
be replaced with belt No. 40053602 for one and
two speed models; or 40053601 for some two
speed models and three speed models (special
clutch-type belt) for proper washer operation.
Refer to Parts Manual for proper belt part
number."
I would order a new belt from APP, if you have both your model number and serial number they should be able to get you the right one.
__________________
  #13 (permalink)
Old 01-19-2013, 04:45 PM
Junior Member
Default wet clothes
thanks for all your help.
  #14 (permalink)
Old 01-20-2013, 10:06 AM
Junior Member
Default wet clothes
Ok, the new motor didn't change things, now that I know what the belt size is supposed to be, it's stretched about 1 inch over size, is this something that could be the problem or is there another reason why machine doesn't seem to be rotating fast enough to pull more of the excess water out of the clothes. Running them through another spin cycle leaves them soppy wet.
  #15 (permalink)
Old 01-20-2013, 01:38 PM
Senior Expert
APP Volunteer
Default
Get the right belt. It will either fix things or you will be able to rule out the belt as a problem.
__________________
  #16 (permalink)
Old 01-23-2013, 04:45 PM
Junior Member
Default
Ccccccccccccccccccc
  #17 (permalink)
Old 01-23-2013, 06:12 PM
Junior Member
Default wet clothes
Xxxxxxxxxxxxx
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE large capacity clothes washer leaves clothes soaking wet gbtribe Washer Repair 0 12-14-2010 08:01 PM
Maytag clothes washer, new pump and belt replaced, clothes wet after spin, further qu yzhong Washer Repair 3 09-22-2009 09:35 AM
Maytag clothes washer, new pump and belt replaced, clothes wet after spin, further qu yzhong Washer Repair 0 08-26-2009 02:18 PM
Maytag clothes washer, new pump and belt replaced, clothes wet after spin, more quest yzhong Washer Repair 1 07-21-2009 02:41 AM
Maytag clothes washer, with pump and belt replaced in Nov. 2007, clothes were too wet yzhong Washer Repair 1 04-22-2009 01:10 PM
