| » GE Washer will not start |
Model Number: WPRE6100G0WT Brand: GE Age: 1 - 5 years
My washer won't start. I hit the button and nothing.
When I change the load selector the cycle times change. Please help Ads By Google Related Models |
Try a reset by unplugging the washer for 2 minutes. When you plug it back in, does the display come on right away or do you have to press the start button for it to come on?
Try going into service mode by pressing and holding the start button and rotate the cycle selector 180 degrees (8 clicks). Release start button and display should show 88 and all 3 LED indicators should be on. Rotate 2 clicks to the right to check for error codes. Error codes are indicated by any of the 3 LED indicators being on. If on, note which ones. Rotate one more click to the right to check for further error codes and note them. Each successive click after that will activate the hot water valve, cold water valve, slow agitate, fast agitate, pump, and spin. To exit service mode, press/hold start button and rotate cycle knob 180 degrees, release start button. Eric |
| Display Modes | |
| Washer/Dryer Stacked Unit - Washer won't start! | dru | Washer Repair | 4 | 09-21-2012 02:44 PM |
| maytag neptune washer does not start when start button pressed | teriden73 | Washer Repair | 0 | 08-07-2012 05:35 PM |
| Dryer will not start - will power up, but when push the start button, will not start | perduena | Dryer Repair | 0 | 07-12-2010 07:14 PM |
| maytag d-washer start/stop/start | mike kennedy | Dishwasher Repair | 0 | 01-11-2010 09:51 PM |
| My front load washer will not start. push start and nothing happens | kimmoe | Washer Repair | 1 | 01-06-2010 01:41 PM |
