Discuss
leaking water bottom
 in
Washer Repair
washer leaking water under machine, only when using warm fill up. Doesnt seem to leak with just cold or just
Appliance Repair Forum > Appliance Repair Help > Washer Repair » leaking water bottom
  #1 (permalink)
Old 01-12-2013, 12:42 PM
Junior Member
otto208 is on a distinguished road
Default leaking water bottom
Model Number: A211   Brand: Maytag   Age: 5 - 10 years
washer leaking water under machine, only when using warm fill up. Doesnt seem to leak with just cold or just hot fill up. All outside hoses dry. Already changed both belts, one was off completly. just the other day.
Thanks for any help you may have.
Ads By Google
Related Models
Maytag A211 Washer - Top Loading
Maytag A211S Washer - Top Loading
Maytag A211T Washer - Top Loading
Maytag A212 Washer - Top Loading
Maytag A212S Washer - Top Loading
Maytag A212ST Washer - Top Loading
Maytag A212T Washer - Top Loading
Maytag A21CA Washer - Top Loading
Maytag A21CM Washer - Top Loading
Maytag A21CT Washer - Top Loading
Frigidaire A2238C2 Frg(v9) / Room Air Conditioner
Frigidaire A2238D2 Frg(v9) / Room Air Conditioner
Maytag A22CA Washer - Top Loading
Maytag A22CM Washer - Top Loading
Maytag A22CT Washer - Top Loading
Maytag A23CA Washer - Top Loading
Maytag A23CDL Washer - Top Loading
Maytag A23CDW Washer - Top Loading
Maytag A23CSL Washer - Top Loading
Maytag A23CSW Washer - Top Loading
Maytag A23CT Washer - Top Loading
Frigidaire A2438DC2 Frg(v10) / Room Air Conditioner
Frigidaire A2438DD2 Frg(v10) / Room Air Conditioner
Maytag A24CA Washer - Top Loading
Maytag A25CA Washer - Top Loading
Maytag A25CAE Washer - Top Loading
Maytag A25CM Washer - Top Loading
Maytag A25CME Washer - Top Loading
Maytag A25CS Washer - Top Loading
Maytag A25CT Washer - Top Loading
Maytag A26CA Washer - Top Loading
Maytag A26CAE Washer - Top Loading
Maytag A26CD Washer - Top Loading
Maytag A26CDC Washer - Top Loading
Maytag A282 Washer - Top Loading
Maytag A282T Washer - Top Loading
Maytag A283 Washer - Top Loading
Frigidaire A2838C2 Frg(v11) / Room Air Conditioner
Frigidaire A2838D2 Frg(v11) / Room Air Conditioner
Maytag A283T Washer - Top Loading
Maytag A284 Washer - Top Loading
Maytag A284T Washer - Top Loading
General Electric A2B348CKALRA Zoneline
General Electric A2B348DAALRA Zoneline
General Electric A2B348DCALR1 Zoneline
General Electric A2B348DCALRA Zoneline
General Electric A2B348DCANR1 Zoneline
General Electric A2B348DEALRA Zoneline
General Electric A2B348DEASR1 Zoneline
General Electric A2B348DEASRA Zoneline
General Electric A2B348DGALRA Zoneline
General Electric A2B348ENFMRA Zoneline
General Electric A2B349DAALRA Zoneline
General Electric A2B358DAALRA Zoneline
General Electric A2B358DAASRA Zoneline
General Electric A2B358DAESRA Zoneline
General Electric A2B358DCALRA Zoneline
General Electric A2B358DCANRA Zoneline
General Electric A2B358DCASRA Zoneline
General Electric A2B358DCENRA Zoneline
General Electric A2B358DCFSRA Zoneline
General Electric A2B358DEALRA Zoneline
General Electric A2B358DEANRA Zoneline
General Electric A2B358DEASRA Zoneline
General Electric A2B358DEFSRA Zoneline
General Electric A2B358DGALRA Zoneline
General Electric A2B358DGANRA Zoneline
General Electric A2B358DGASRA Zoneline
General Electric A2B358ENASRA Zoneline
General Electric A2B358EPASRA Zoneline
General Electric A2B359DEASRA Zoneline
General Electric A2B359DGASRA Zoneline
General Electric A2B368DAALR1 Zoneline
General Electric A2B368DAASR1 Zoneline
General Electric A2B368DCALR1 Zoneline
General Electric A2B368DCASR1 Zoneline
General Electric A2B368DEAL2R Zoneline
General Electric A2B368DEAL3R Zoneline
General Electric A2B368DEALR1 Zoneline
General Electric A2B368DEASR1 Zoneline
General Electric A2B368DGALR1 Zoneline
General Electric A2B368ESASR1 Zoneline
General Electric A2B369DAASR1 Zoneline
General Electric A2B369DAELR1 Zoneline
General Electric A2B378DAALR1 Zoneline
General Electric A2B378DGALR1 Zoneline
General Electric A2B378DGAS1Y Zoneline
General Electric A2B378ESASR1 Zoneline
General Electric A2B379DEESR1 Zoneline
General Electric A2B383DAALR1 Zoneline
General Electric A2B383DAALR2 Zoneline
General Electric A2B383DAASR1 Zoneline
General Electric A2B383DAASR2 Zoneline
General Electric A2B383DACSR1 Zoneline
General Electric A2B383DACSR2 Zoneline
General Electric A2B383DCALR1 Zoneline
General Electric A2B383DCALR2 Zoneline
General Electric A2B383DEALR1 Zoneline
General Electric A2B383DEALR2 Zoneline
General Electric A2B383ENASR1 Zoneline
General Electric A2B383ENASR2 Zoneline
General Electric A2B383EPAS1Y Zoneline
General Electric A2B383EPAS2Y Zoneline
General Electric A2B383EPASR1 Zoneline
General Electric A2B383EPASR2 Zoneline
General Electric A2B383ESASR1 Zoneline
General Electric A2B383ESASR2 Zoneline
General Electric A2B388DAALR1 Zoneline
General Electric A2B388DAALR2 Zoneline
General Electric A2B388DAAS1Y Zoneline
General Electric A2B388DAAS2Y Zoneline
General Electric A2B388DAASR1 Zoneline
General Electric A2B388DAASR2 Zoneline
General Electric A2B388DACSR2 Zoneline
General Electric A2B388DCALR1 Zoneline
General Electric A2B388DCALR2 Zoneline
General Electric A2B388DCASR1 Zoneline
General Electric A2B388DCASR2 Zoneline
General Electric A2B388DEALR1 Zoneline
General Electric A2B388DEALR2 Zoneline
  #2 (permalink)
Old 01-14-2013, 06:02 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Operate it with the front panel off and see if you can determine where the leak is coming from. What I suspect is that with the warm water setting you have more water pressure than either hot or cold, and that the leak is coming from a broken splash guard.
I have seen this before on these Maytags
__________________
  #3 (permalink)
Old 01-25-2013, 08:51 AM
Junior Member
Thumbs up
Thanks so much Sid...looked for the leak after taking off the front panel and it was from the top left area. After removing the top lid, it turned out to be the "intake valve". Very common problem from what i hear. Its a small black tube with plastic inner piece, costs about 4$. Its where the main water comes in from back of the machine and its to airate the water.
It can get hard and rotted and not allow water to flow properly and squirts the water out on of the top, thu a plastic shield it has over it. Its anout in the middle left upper area of the machine.
Thanks again for your helpful directions
  #4 (permalink)
Old 01-25-2013, 09:35 AM
Senior Expert
APP Volunteer
Default
Well glad you found the source of the problem and thanks for the detailed description. That will be very helpful to people who read this Forum.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Leaking Water on bottom right side ehensch Refrigerator & Freezer Repair 0 06-19-2011 09:06 AM
Water leaking from the bottom 9isaiah9 Washer Repair 1 03-21-2011 11:51 AM
washer leaking water from bottom gricodrywall Washer Repair 7 07-17-2010 10:30 AM
Amana leaking water out of bottom snag181 Washer Repair 1 02-10-2010 06:41 PM
Ice in bottom of freezer, Leaking water duoduo Refrigerator & Freezer Repair 0 01-27-2009 03:53 AM
