Discuss
Whirlpool Ultimate Care II not draining and not spinning
 in
Washer Repair
My Maytag Ultimate Care II (2) Does not drain. I checked and even changed the water pump and the timer.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Ultimate Care II not draining and not spinning
  #1 (permalink)
Old 01-12-2013, 09:14 AM
Junior Member
iceman9001 is on a distinguished road
Default Whirlpool Ultimate Care II not draining and not spinning
Brand: Whirlpool   Age: 1 - 5 years
My Maytag Ultimate Care II (2) Does not drain. I checked and even changed the water pump and the timer. The pipes are not clogged because water would drain when I lie the hose flat on the ground.
The washer agitates but when it comes to draining the water, it does not drain and just sits with a tub full of water. When I select rinse on the timer, it will fill the tub (after I manually remove the water by placing the hose flat on the ground) but it would not spin. Any ideas on what could the repair symptom be?
Sam
Ads By Google
  #2 (permalink)
Old 01-12-2013, 09:38 AM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
Does the motor hum during drain/spin? If not, does this washer normally agitate with lid open? If it does, then I suspect the lid switch. If the motor just hums, sounds like a gearcase issue.
Eric
  #3 (permalink)
Old 01-12-2013, 01:40 PM
Junior Member
Default
Thanks Fairbanks. There's no humming from the washer when it is time to drain the water. The washer agitated when the lid switch is set to close. It agitated when I remove the lid switch from the machine so I tried a direct wire to connect the 2 live circuits of the lid switch. Any ideas, so you think I should get a new lid switch? Any other things I should look for?
  #4 (permalink)
Old 01-12-2013, 02:36 PM
Expert
APP Volunteer
Default
I need the model number of the washer, meant to ask before.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Ultimate Care II Oakrad1 Washer Repair 0 04-07-2012 05:18 AM
Whirlpool Ultimate Care II fayef Washer Repair 3 10-29-2011 02:02 AM
Whirlpool Ultimate Care II Washer Joistman Washer Repair 1 03-04-2011 09:06 AM
whirlpool ultimate care II washer queen_dior Washer Repair 1 07-31-2009 10:51 AM
whirlpool ultimate care 2 higleyml Washer Repair 4 07-05-2009 11:04 AM
