| » Need to Replace agitator and clutch |
Model Number: LSR8444LQ0 Brand: Whirlpool Age: 5 - 10 years
Quote:
Quote:
All I can suggest is to push it back in all the way and make sure the agitator shaft is clean and smooth. You may need some sandpaper to get the rust off the splined part of the shaft. When pulling out, try twisting and pulling at the same time. You might have someone else use a block of wood and hammer to tap on the top of the agitator shaft as your pulling it out the bottom. Once you do get it out, make sure you rotate the brake cam drive CCW while pushing back in on the spin tube, I see that it has dropped a bit.
Eric |
| Display Modes | |
| Replace clutch too? | stuffduff | Washer Repair | 6 | 11-01-2012 01:18 AM |
| Replace Clutch | gate1 | Washer Repair | 1 | 01-29-2012 03:41 AM |
| Replace Dog Or Agitator Clutch | halljb57 | Washer Repair | 3 | 09-06-2011 05:00 AM |
| How to replace retainer ring on clutch | Brainiac | Washer Repair | 2 | 03-13-2011 12:57 PM |
| Replace clutch on top loading washer | knobby | Washer Repair | 1 | 12-04-2009 03:33 PM |
