| » brakes not working under load kenmore series 80 |
Model Number: 110.29852991 Brand: Kenmore Age: 5 - 10 years
My washer was not spinning at random loads. replaced the clutch and also replaced balance spring at same time. Now when the drum is empty during spin cycle and the lid is opened brakes activate. When spinning with a load of clothes and lid is opened the drum will spin to a stop with no braking effect. Did I screw something up with the repair. It agitates, drains and spins properly.
I was thinking that may be the problem. Any time you remove the gearcase, before re-installing, you need to make sure the basket drive is fully seated. The act of pulling the gearcase can pull the basket drive down a tad. It can't go too far because the basket is still attached. The brake assembly is mounted to the bottom of the drive tube. You just rotate CCW on the brake cam while pushing in to ensure the drive is all the way in.
Eric |
| Display Modes | |
| Kenmore top load Series 80 won't spin | tedmlane | Washer Repair | 0 | 09-07-2011 03:26 PM |
| kenmore series 90 top load washing machine | richard 5 | Washer Repair | 1 | 01-31-2011 08:07 AM |
| Brakes on Maytag top load stuck | canonfodder | Washer Repair | 5 | 07-25-2010 01:29 AM |
| Kenmore Washer top load 70 Series | gmcanazon | Washer Repair | 1 | 08-17-2009 05:18 PM |
| Kenmore 90 series Brakes | marlinjac | Washer Repair | 5 | 07-12-2009 02:39 PM |
