Discuss
Maytag Epic Z Washer Will Not Fully Drain
 in
Washer Repair
I have a Maytag Epic Z washer. The washer keeps shutting off when trying to drain. There are no error
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Epic Z Washer Will Not Fully Drain
  #1 (permalink)
Old 01-11-2013, 04:13 AM
Junior Member
clewisch is on a distinguished road
Default Maytag Epic Z Washer Will Not Fully Drain
Brand: Maytag   Age: 1 - 5 years
I have a Maytag Epic Z washer. The washer keeps shutting off when trying to drain. There are no error codes just the washer shuts down and the door stays locked. I first thought it was the pump so I ordered a new pump and no results. I then removed the drain hose from the tub to the pump. Found nothing that would stop the washer from draining. I also checked the discharge hose and again it is clear. I have ran a diagnosis on the machine and no error codes come up. The washer has failed during the diagnosis phase. I am not sure what to even look at now.
Ads By Google
  #2 (permalink)
Old 01-11-2013, 06:16 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Check the wire harness from the drain pump to the control board.
Also could be faulty pressure switch, control board.
Please provide the complete model number.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Epic Z front load washer bellows replacement Andrew M Washer Repair 0 03-16-2011 08:14 PM
Washer does not fully drain JMJNet Washer Repair 1 07-06-2010 01:06 PM
maytag washer -epic z misterfixall Washer Repair 2 04-16-2010 11:01 AM
GE washer doest fully drain kmitch Washer Repair 1 05-17-2009 07:35 PM
washer both leaks and fails to fully drain mathias Washer Repair 4 08-05-2008 02:28 PM
