Discuss
Maytag repair
 in
Washer Repair
My maytag ensignia washer will fill with water but then nothing happens. A repair guy told me it was he
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag repair
  #1 (permalink)
Old 01-09-2013, 08:26 AM
Junior Member
StephKing is on a distinguished road
Default Maytag repair
Model Number: Mav6457aww   Brand: Maytag   Age: 5 - 10 years
My maytag ensignia washer will fill with water but then nothing happens. A repair guy told me it was he timer & wants to charge me $300 to fix it. I don't mind getting the part & fixing it myself but after reading some other problem solving forum, it may not be the problem. Help!
Ads By Google
Related Models
Maytag MAV6457AWW Washer, Atlantis
Maytag MAV6458AWW Washer, Atlantis
Maytag MAV6548AWQ Washer, Atlantis
Maytag MAV6548AWW Washer, Atlantis
Maytag MAV6601AWQ Washer, Atlantis
Maytag MAV6601AWW Washer, Atlantis
Maytag MAV6650AWW Washer, Atlantis
Maytag MAV7000AWQ Washer, Atlantis
Maytag MAV7000AWW Washer, Atlantis
Maytag MAV7057AWQ Washer, Atlantis
Maytag MAV7057AWW Washer, Atlantis
Maytag MAV7200AWQ Washer, Atlantis
Maytag MAV7200AWW Washer, Atlantis
Maytag MAV7257AWQ Washer, Atlantis
Maytag MAV7257AWW Washer, Atlantis
Maytag MAV7258AWQ Washer, Atlantis
Maytag MAV7258AWW Washer, Atlantis
Maytag MAV7260AWW Washer, Atlantis
Maytag MAV7260BWW Washer, Atlantis
Maytag MAV7357AWQ Washer, Atlantis
Maytag MAV7357AWW Washer, Atlantis
Maytag MAV7358AWQ Washer, Atlantis
Maytag MAV7358AWW Washer, Atlantis
Maytag MAV7450AWQ Washer, Atlantis
Maytag MAV7450AWW Washer, Atlantis
Maytag MAV7501EWW Washer, Atlantis
Maytag MAV7504EWW Washer, Atlantis
Maytag MAV7550AWQ Washer, Atlantis
Maytag MAV7550AWW Washer, Atlantis
Maytag MAV7551AWQ Washer, Atlantis
Maytag MAV7551AWW Washer, Atlantis
Maytag MAV7557EWQ Washer, Atlantis
Maytag MAV7557EWW Washer, Atlantis
Maytag MAV7580EWQ Washer, Atlantis
Maytag MAV7580EWW Washer, Atlantis
International MAV7600ACQ Washer - Top Loading
International MAV7600AGW Washer - Top Loading
Maytag MAV7600AWQ Washer, Atlantis
Maytag MAV7600AWW Washer, Atlantis
International MAV7600BGW Washer - Top Loading
International MAV7600CGW Washer - Top Loading
Maytag MAV7650AWQ Washer, Atlantis
Maytag MAV7650AWW Washer, Atlantis
Maytag MAV7657EWQ Washer, Atlantis
Maytag MAV7657EWW Washer, Atlantis
Maytag MAV7700AWQ Washer, Atlantis
Maytag MAV7700AWW Washer, Atlantis
International MAV7750AGW Washer - Top Loading
International MAV7750BGW Washer - Top Loading
International MAV7750CGW Washer - Top Loading
Maytag MAV7757AWQ Washer, Atlantis
Maytag MAV7757AWW Washer, Atlantis
Maytag MAV8000AWQ Washer, Atlantis
Maytag MAV8000AWW Washer, Atlantis
Maytag MAV8057AWQ Washer, Atlantis
Maytag MAV8057AWW Washer, Atlantis
Maytag MAV8260AWQ Washer, Atlantis
Maytag MAV8260AWW Washer, Atlantis
Maytag MAV8500AWA Washer, Atlantis
Maytag MAV8500AWQ Washer, Atlantis
Maytag MAV8500AWW Washer, Atlantis
Maytag MAV8551AWQ Washer, Atlantis
Maytag MAV8551AWW Washer, Atlantis
Maytag MAV8557AWQ Washer, Atlantis
Maytag MAV8557AWW Washer, Atlantis
Maytag MAV8600AWQ Washer, Atlantis
Maytag MAV8600AWW Washer, Atlantis
Maytag MAV8601AWQ Washer, Atlantis
Maytag MAV8601AWW Washer, Atlantis
Maytag MAV8757AWQ Washer, Atlantis
Maytag MAV8757AWW Washer, Atlantis
Maytag MAV9501EWQ Washer, Atlantis
Maytag MAV9501EWW Washer, Atlantis
Maytag MAV9504EWQ Washer, Atlantis
Maytag MAV9504EWW Washer, Atlantis
Maytag MAV9557EWQ Washer, Atlantis
Maytag MAV9557EWW Washer, Atlantis
Maytag MAV9600EWQ Washer, Atlantis
Maytag MAV9600EWW Washer, Atlantis
Maytag MAV9657EWQ Washer, Atlantis
Maytag MAV9657EWW Washer, Atlantis
Maytag MAV9750AGW Washer, Atlantis
Maytag MAV9750AWQ Washer, Atlantis
Maytag MAV9750AWW Washer, Atlantis
Maytag MAVT236AWW Washer - Top Loading
Maytag MAVT346AWW Washer - Top Loading
Maytag MAVT446AWW Washer - Top Loading
Maytag MAVT546EWW Washer - Top Loading
Maytag MAVT634AWW Washer, Atlantis
Maytag MAVT734EWW Washer, Atlantis
Maytag MAVT754EWW Washer, Atlantis
Maytag MAVT834AWQ Washer, Atlantis
Maytag MAVT834AWW Washer, Atlantis
Whirlpool MB1110SLQ Microwave Oven 1.1 Cubic Foot
International MB1927PEHB  Ref - Maytag Int'l Bot Mount
International MB1927PEHW  Ref - Maytag Int'l Bot Mount
International MB2216PUAW Ref - Bottom Mounts
International MB2227PEHB  Ref - Maytag Int'l Bot Mount
International MB2227PEHW  Ref - Maytag Int'l Bot Mount
Thermador MB245
General Electric MB536BB1 Electric range
Whirlpool MB7120XYB0
Whirlpool MB7120XYB1
General Electric MB757WB1 Electric range
Maytag MBB1952GRQ  Ref - Bottom Mounts
Maytag MBB1952GRW  Ref - Bottom Mounts
Maytag MBB1952HEB Ref - Bottom Mounts
Maytag MBB1952HEQ Ref - Bottom Mounts
Maytag MBB1952HEW Ref - Bottom Mounts
Maytag MBB1954GEB  Ref - Bottom Mounts
Maytag MBB1954GEQ  Ref - Bottom Mounts
Maytag MBB1954GES  Ref - Bottom Mounts
Maytag MBB1954GEW  Ref - Bottom Mounts
Maytag MBB1954HEW Ref - Bottom Mounts
Maytag MBB1956GEB  Ref - Bottom Mounts
Maytag MBB1956GEQ  Ref - Bottom Mounts
Maytag MBB1956GES  Ref - Bottom Mounts
Maytag MBB1956GEW  Refrigerator
Maytag MBB1956HEB Ref - Bottom Mounts
Maytag MBB1956HEQ Ref - Bottom Mounts
  #2 (permalink)
Old 01-09-2013, 11:19 AM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
After it fills and stops, does the timer advance on it's own? If you advance it manually, will it drain and spin? If not, most likely the lid switch.
Eric
  #3 (permalink)
Old 01-09-2013, 06:07 PM
Junior Member
Default
Quote:
Eric
The dial does not advance on its own. I even tried to advance be knob a smidge thinking it maybe got caught or something, but nothing. If I manually turn it to spin, it will. Thanks!
  #4 (permalink)
Old 01-09-2013, 07:24 PM
Expert
APP Volunteer
Default
Then it may be the water level pressure switch. Open the control panel, the switch is on the left side. With washer off, remove and jump together the yellow and gray wires. Set timer to start a normal cycle, it should start agitating right away.
Eric
  #5 (permalink)
Old 01-09-2013, 08:16 PM
Junior Member
gregaguilar is on a distinguished road
Default
fairbanks56 how are you doing quick question? how do you go about testing the shifter on the maytag mvwx700 washer? I have one that does the same it just blinks--lid switch i mean thanks
  #6 (permalink)
Old 01-10-2013, 05:40 AM
Expert
APP Volunteer
Default
There should be a manual inside the cabinet of your washer that explains how to get into diagnostic mode and the various tests for the shift actuator.
Eric
  #7 (permalink)
Old 01-10-2013, 07:15 AM
Junior Member
Default maytag actuator testing
on maytag diagnostic there is no diagnostic sheet in or on machine i have looked but thanks any way
  #8 (permalink)
Old 01-10-2013, 07:39 AM
Expert
APP Volunteer
Default
This is a Whirlpool vertical modular washer design. There are slight differences between Whirlpool, Maytag, Kenmore...etc. but they are all essentially the same overall design. Some models have the old style water level pressure switch and others have a pressure sensor that is an integral part of the computer control board. There are also slight differences in the wash cycle indicator LED's.
Eric
  #9 (permalink)
Old 01-11-2013, 06:58 PM
Junior Member
Default
Eric! You rock! So the repair guy said the problem was either the timer or the motor. Timer replaced, didn't agitate. He didn't bring the motor so had to go pick one up at parts store 4 towns away. Motor replaced, still not agitating. He basically told me to go washer shopping. I laughed but was annoyed. I told him about this site & the answers I got. He laughed & said with a cocky attitude that he already checked the water pressure connection. He pulled down the control panel to show me but the second he touched the wire, the agitator startd immediately! Needless to say, he was speechless. Thank you so much for saving me from buying a new washer! I will definitely use you guys again!
  #10 (permalink)
Old 01-12-2013, 06:41 AM
Expert
APP Volunteer
Default
Well, I hope he didn't charge you for all that wasted time and parts. I wouldn't call him again. Since it drained and spun ok, that indicates the motor is ok. For agitate, the power feed to the start winding is reversed which is accomplished at the timer. A lot of "appliance techs" don't know how to use a logical troubleshooting procedure and don't have training/experience at electrical troubleshooting. They just throw parts at it til it's fixed or they give up. Anyway, glad you got it fixed. Keep that thing going cause you don't want one of the new piece's of junk they are selling now
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Repair Manual SaintsFan Dishwasher Repair 2 03-24-2013 01:58 PM
maytag washer repair monty310 Washer Repair 2 01-05-2013 03:37 PM
Maytag Repair Help Littlewolf Dishwasher Repair 2 04-09-2010 08:55 AM
maytag repair poc16 Oven Repair (including Ranges and Cooktops) 0 11-23-2009 06:20 PM
Maytag Washer Repair parrisk Washer Repair 3 06-05-2009 06:11 AM
