Problem with draining and spinnining washer
Model Number: 11025062500 Brand: Kenmore Age: 5 - 10 years
I have a Kenmore washer (model # 110-25062500) that will not either drain or go into spin mode. I looked it up on the net and it appears that this machine is famous for having issues with clogs in the drain motor and drain lines. I removed pump and its all clear as is the line,the impeller can be moved with one finger. Still not draining. Drain line clear and properly elevated. Can it be the capacitor on the motor? or no power coming from control board, how can I check control board to see if its sending power? Checked lid switch and it clicks, but haven't checked it to be sure its closing the switch, so it may be something just that stupid (machine thinks lid is open) I first assumed it was aclog as daughter told me that she had washed a chenille blanket and it had fallen to pieces and I believed that was the culprit. Can't find any technical manuals on this particular machine as to what does what. Can someone assist me and tell me what to do next>
Ads By Google
Related Models
