| » Maytag Atlantis MAV9600EWW washer wont agitate. |
Model Number: MAV9600EWW Brand: Maytag Age: 1 - 5 years
we have a Maytag washer that fills up with water and then wont agitate. The timer doesnt advance and after a while the timer starts to smell. It will pump out the water and spin when manually moving the timer. This happens on all clothes settings. The timer will advance in the rinse setting. The transmission moves freely. There is a circuit board mounted on the timer and thw two big resistors have brown marks on the board. (seems this is the smell) Also the timer turns in both directions.
Hi.
Most likely it's a bad timer Part number: 22003445 The control board should be a water temperature control. Here are the breakdown diagrams and 03-Control Panel parts for Maytag MAV9600EWW - AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
if the control board is for temp control why would it be frying when the machine is going from filling up and then agitating? I mean the boards stinks everytime I try a run to TS it. If I dont turn the timer off, press knob down, it will start to heat up and stink and then you know the next would be burning up. Anyway, Im new to this dryer and dont know of a timer that turns both ways. Im thinking timer also, but id hate to have my roomies buy the timer and then the control board be bad. both are costly. thank you so much for your quick reply and help
Hi.
If you'll get the parts from APP you may return any parts that you don't need, even if they have been installed. Simon.
__________________
You are welcome.
Simon.
__________________
| Display Modes | |
| Maytag Atlantis no agitate/spin | colusapaul | Washer Repair | 1 | 01-19-2012 06:44 PM |
| Maytag Atlantis--Spin, but no agitate. | Bmackkc | Washer Repair | 0 | 09-17-2010 06:44 PM |
| Maytag Atlantis will not Agitate | bigshow1976 | Washer Repair | 1 | 01-23-2010 03:56 PM |
| Maytag atlantis washer wont spin | davec1228 | Washer Repair | 8 | 10-31-2008 12:21 PM |
| Maytag Atlantis overflows - wont agitate | Woody | Washer Repair | 4 | 08-27-2007 03:11 PM |
