| » Washer works ok but won't do final spin unless empty |
Model Number: WHDSEC820COWW Brand: GE Age: 5 - 10 years
Just installed a new clutchless 2 speed motor to replace the old 2 speed clutch motor. Now it works fine thru all the cycles until the final spin where it won't spin unless the tub is empty. Since it is a topload with magnet on door I get it spinning, empty, then throw clothes in one at a time, let it build up to speed then another piece of clothing and so on until it stops spinning at the end of the cycle. Also the 2nd rinse is shut off but the red light on control goes on and it does a second rinse. I blew into the pressure hose and heard the control knob click and nothing in hose. Could it be the control board or the transmission?? It agitates and spins well until final cycle when clothes are soaking wet and spin wont go on..Clothes are soaking wet but no water left in tub after draining.
| Display Modes | |
| GE washer works when empty, but..... | karlchap | Washer Repair | 3 | 06-18-2012 10:01 AM |
| washer won't empty or spin cycle | t keefe | Washer Repair | 0 | 11-25-2010 06:14 AM |
| Kenmore 500: spin cycle works when empty, does not work when full | silv50 | Washer Repair | 15 | 08-27-2010 12:52 PM |
| Washer won't empty or spin | sandyreta | Washer Repair | 1 | 08-23-2010 01:05 PM |
| Washer won't empty/spin | ironglen | Washer Repair | 2 | 09-20-2007 08:28 AM |
