Discuss
top load washer
 in
Washer Repair
I have a top loaded washer, made by kanmore that when it is filling up it over float please can
Appliance Repair Forum > Appliance Repair Help > Washer Repair » top load washer
  #1 (permalink)
Old 01-06-2013, 09:02 AM
Junior Member
jose silva is on a distinguished road
Default top load washer
Model Number: 11022642100   Brand: Kenmore   Age: 1 - 5 years
I have a top loaded washer, made by kanmore that when it is filling up it over float please can any body me? thanks
Ads By Google
Related Models
Kenmore 11022642100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022652100 COMPACT WASHER
Kenmore 11022662100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022692100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022692101 AUTOMATIC WASHER
Kenmore 11023012100 AUTOMATIC WASHER
Kenmore 11023012101 AUTOMATIC WASHER
Kenmore 11023012102 AUTOMATIC WASHER
Kenmore 11023014100 AUTOMATIC WASHER
Kenmore 11023014101 AUTOMATIC WASHER
Kenmore 11023014102 AUTOMATIC WASHER
Kenmore 11023022100 AUTOMATIC WASHER
Kenmore 11023022101 AUTOMATIC WASHER
Kenmore 11023022102 AUTOMATIC WASHER
Kenmore 11023024100 AUTOMATIC WASHER
Kenmore 11023024101 AUTOMATIC WASHER
Kenmore 11023024102 AUTOMATIC WASHER
Kenmore 11023032100 WASHER
Kenmore 11023032101 AUTOMATIC WASHER
Kenmore 11023032102 AUTOMATIC WASHER
Kenmore 11023034100 WASHER
Kenmore 11023034101 AUTOMATIC WASHER
Kenmore 11023034102 AUTOMATIC WASHER
Kenmore 11023036100 WASHER
Kenmore 11023036101 AUTOMATIC WASHER
Kenmore 11023036102 AUTOMATIC WASHER
Kenmore 11023652200 AUTOMATIC WASHER
Kenmore 11023662200 AUTOMATIC WASHER
Kenmore 11023692200 AUTOMATIC WASHER
Kenmore 11023712200 AUTOMATIC WASHER
Kenmore 11023722200 AUTOMATIC WASHER
Kenmore 11023732200 AUTOMATIC WASHER
Kenmore 11023812100 AUTOMATIC WASHER
Kenmore 11023822100 AUTOMATIC WASHER
Kenmore 11023832100 AUTOMATIC WASHER
Kenmore 11023902200 AUTOMATIC WASHER
Kenmore 11023902201 AUTOMATIC WASHER
Kenmore 11023904200 AUTOMATIC WASHER
Kenmore 11023904201 AUTOMATIC WASHER
Kenmore 11023912100 AUTOMATIC WASHER
Kenmore 11023912101 AUTOMATIC WASHER
Kenmore 11023912102 AUTOMATIC WASHER
Kenmore 11023922200 AUTOMATIC WASHER
Kenmore 11023922201 AUTOMATIC WASHER
Kenmore 11023924200 AUTOMATIC WASHER
Kenmore 11023924201 AUTOMATIC WASHER
Kenmore 11023932200 WASHER
Kenmore 11023934200 WASHER
Kenmore 11024082200 AUTOMATIC WASHER
Kenmore 11024084200 AUTOMATIC WASHER
Kenmore 11024086200 AUTOMATIC WASHER
Kenmore 11024422300 AUTOMATIC WASHER
Kenmore 11024432300 AUTOMATIC WASHER
Kenmore 11024442300 AUTOMATIC WASHER
Kenmore 11024622300 AUTOMATIC WASHER
Kenmore 11024632300 AUTOMATIC WASHER
Kenmore 11024642300 AUTOMATIC WASHER
Kenmore 11024652300 AUTOMATIC WASHER
Kenmore 11024692300 AUTOMATIC WASHER
Kenmore 11024812200 AUTOMATIC WASHER
Kenmore 11024812201 AUTOMATIC WASHER
Kenmore 11024822200 AUTOMATIC WASHER
Kenmore 11024822201 AUTOMATIC WASHER
Kenmore 11024832200 AUTOMATIC WASHER
Kenmore 11024832201 AUTOMATIC WASHER
Kenmore 11024892300 AUTOMATIC
Kenmore 11024894300 AUTOMATIC
Kenmore 11024902200 AUTOMATIC WASHER
Kenmore 11024902201 AUTOMATIC WASHER
Kenmore 11024904200 AUTOMATIC WASHER
Kenmore 11024904201 AUTOMATIC WASHER
Kenmore 11024922200 AUTOMATIC WASHER
Kenmore 11024922201 AUTOMATIC WASHER
Kenmore 11024924200 AUTOMATIC WASHER
Kenmore 11024924201 AUTOMATIC WASHER
Kenmore 11024932200 AUTOMATIC WASHER
Kenmore 11024932201 AUTOMATIC WASHER
Kenmore 11024934200 AUTOMATIC WASHER
Kenmore 11024934201 AUTOMATIC WASHER
Kenmore 11024942300 AUTOMATIC WASHER
Kenmore 11024944300 AUTOMATIC WASHER
Kenmore 11024946300 AUTOMATIC WASHER
Kenmore 11024952300 AUTOMATIC WASHER
Kenmore 11024954300 AUTOMATIC WASHER
Kenmore 11024956300 AUTOMATIC WASHER
Kenmore 11024962300 AUTOMATIC WASHER
Kenmore 11024964300 AUTOMATIC WASHER
Kenmore 11024966300 AUTOMATIC WASHER
Kenmore 11024972300 AUTOMATIC WASHER
Kenmore 11024974300 AUTOMATIC WASHER
Kenmore 11024982300 AUTOMATIC WASHER
Kenmore 11024992300 AUTOMATIC WASHER
Kenmore 11024994300 AUTOMATIC WASHER
Kenmore 11024996300 AUTOMATIC WASHER
Kenmore 11026292690 AUTOMATIC WASHER
Kenmore 11026292691 AUTOMATIC WASHER
Kenmore 11026292692 AUTOMATIC WASHER
Kenmore 11026292693 AUTOMATIC WASHER
Kenmore 11026292694 WASHER
Kenmore 11026292695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026294690 AUTOMATIC WASHER
Kenmore 11026294691 AUTOMATIC WASHER
Kenmore 11026294692 AUTOMATIC WASHER
Kenmore 11026294693 AUTOMATIC WASHER
Kenmore 11026294694 WASHER
Kenmore 11026294695 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11026702694 AUTOMATIC WASHER
Kenmore 11026722690 WASHER
Kenmore 11026801690 AUTOMATIC WASHER
Kenmore 11026812690 WASHER
Kenmore 11026814690 WASHER
Kenmore 11026822690 WASHER
Kenmore 11026824690 WASHER
Kenmore 11026824692 AUTOMATIC WASHER
Kenmore 11026832690 AUTOMATIC WASHER
Kenmore 11026832694 AUTOMATIC WASHER
Kenmore 11026834690 WASHER
Kenmore 11026834694 AUTOMATIC WASHER
Kenmore 11026842690 WASHER
Kenmore 11026842694 AUTOMATIC WASHER
  #2 (permalink)
Old 01-06-2013, 10:28 AM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
Need to check the air dome and hose on the right rear quadrant of the outer tub for gunk. Check hose fitting at air dome and pressure switch behind control panel. When tub is empty, you can disconnect hose from air dome and blow into it to see if you can hear the pressure switch activate. Check pressure switch for continuity. Should have continuity between where violet and pink wires connect and when switch is activated, should be between violet and tan wires, violet and pink should be open circuit.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE top load washer klrz28 Washer Repair 1 01-12-2012 06:16 PM
G E Top Load Washer wont drain w/full load Mike 384 Washer Repair 1 02-05-2011 05:11 PM
top load washer BS5363 Washer Repair 1 01-29-2011 03:56 AM
top load washer will only fill to small load level ibnanny Washer Repair 0 07-05-2010 08:42 PM
Load Thumping Noise & Unbalanced Condition On GE front load washer Luke Vincent Washer Repair 2 08-06-2009 05:43 PM
