| » Error 43 |
Model Number: GLTF2940FEO Brand: Frigidaire Age: 1 - 5 years
I have a Frigidaire front load washer model number gltf294feo we were having issues with the machine we couldnt get it to tumble or spin would only put water in then do nothing esle ...so we check for error code and was getting E5E...so when we got to checking the machine we noticed we had a leak from a black hose at the top that had dripped water onto the motor control board (speed sensor board) so we replaced it and the leaking hose thinking it would correct any issues...well now the machine fills with water tumbles does everything but high spin when it gets to spin it just shuts off ....we ran it in diagnostics mode and everything passes until we try the spin then it throws error E43 ...well from everything i have read on the internet it all says check the door lock so we pulled the lock check it with meter its 1385 ohms so thats ok we also checked it another way to make sure its locking and unlocking and everything checks out ....I guess what I am asking is what part should i replace now the top control panel board or the door lock very confused
Ads By Google Related Models Last edited by CristylJohnson : 01-05-2013 at 05:00 PM. |
| Display Modes | |
| Whirlpool Oven Error Code F3 E2 - Replaced Oven Tem Sensor and still getting error | loanguy7171973 | Oven Repair (including Ranges and Cooktops) | 1 | 12-01-2012 03:53 AM |
| ERROR CODE F6E5 Cancel key error | tammike | Oven Repair (including Ranges and Cooktops) | 8 | 08-06-2012 08:54 AM |
| Error f51 corrected. now f50 error | soletc | Washer Repair | 3 | 12-07-2011 11:29 AM |
| LG error code OE - drain error | JPotter | Washer Repair | 0 | 04-01-2011 07:20 AM |
| frigidaire error code F10 - not listed in your error codes | Skully26 | Oven Repair (including Ranges and Cooktops) | 2 | 02-16-2010 04:29 AM |
