Discuss
maytag washer repair
 in
Washer Repair
I have a Maytag stacked washer drier, the other day the washer stopped working. After looking on this forum I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » maytag washer repair
  #1 (permalink)
Old 01-05-2013, 08:34 AM
Junior Member
monty310 is on a distinguished road
Default maytag washer repair
Model Number: lse7806ace   Brand: Maytag   Age: 5 - 10 years
I have a Maytag stacked washer drier, the other day the washer stopped working. After looking on this forum I found the location of the 1amp fuse, replaced it and voila I was a hero for ten minutes in my house. Once the tub was full it stopped. I've tried the spin cycle and different temp. settings but nothing else is a go, the fuse is still good and if I manually drain it , it will re-fill. Anyone got any ideas on where to go next?
Ads By Google
Related Models
Maytag LSE7806ACE Stacked Laundry - Ele
Maytag LSE7806ACM Stacked Laundry - Ele
Maytag LSE7806ACQ Stacked Laundry - Ele
Maytag LSE7806ADE Stacked Laundry - Ele
Maytag LSE7806ADM Stacked Laundry - Ele
Maytag LSE7806ADQ Stacked Laundry - Ele
Maytag LSE7806AEE Stacked Laundry - Ele
Maytag LSE7806BCE Stacked Laundry - Ele
International LSE7806GGE Stacked Laundry - Ele
Whirlpool LSE9355BQ0
Whirlpool LSE9355BZ0
Maytag LSE9900 Stacked Laundry - Ele
Maytag LSE9900ACE Stacked Laundry - Ele
Maytag LSE9900ACL Stacked Laundry - Ele
Maytag LSE9900ACW Stacked Laundry - Ele
Maytag LSE9900ADE Stacked Laundry - Ele
Maytag LSE9900ADL Stacked Laundry - Ele
Maytag LSE9900ADW Stacked Laundry - Ele
Maytag LSE9900AEE Stacked Laundry - Ele
Maytag LSE9900AEL Stacked Laundry - Ele
Maytag LSE9900AEW Stacked Laundry - Ele
Maytag LSE9900AFE Stacked Laundry - Ele
Maytag LSE9900AFL Stacked Laundry - Ele
Maytag LSE9900AFW Stacked Laundry - Ele
Maytag LSE9904ACE Stacked Laundry - Ele
Maytag LSE9904ACL Stacked Laundry - Ele
Maytag LSE9904ACM Stacked Laundry - Ele
Maytag LSE9904ADE Stacked Laundry - Ele
Maytag LSE9904ADL Stacked Laundry - Ele
Maytag LSG1000 Stacked Laundry - Gas
Maytag LSG1000T Stacked Laundry - Gas
Jenn-Air LSG2700W Stacked Laundry - Gas
Jenn-Air LSG2704W Stacked Laundry - Gas
Maytag LSG7800 Stacked Laundry - Gas
Maytag LSG7800AAE Stacked Laundry - Gas
Maytag LSG7800AAL Stacked Laundry - Gas
Maytag LSG7800AAW Stacked Laundry - Gas
Maytag LSG7800ABE Stacked Laundry - Gas
Maytag LSG7800ABL Stacked Laundry - Gas
Maytag LSG7800ABW Stacked Laundry - Gas
Maytag LSG7804AAE Stacked Laundry - Gas
Maytag LSG7804AAL Stacked Laundry - Gas
Maytag LSG7804AAM Stacked Laundry - Gas
Maytag LSG7804ABE Stacked Laundry - Gas
Maytag LSG7804ABL Stacked Laundry - Gas
Maytag LSG7804ABM Stacked Laundry - Gas
Maytag LSG7806AAE Stacked Laundry - Gas
Maytag LSG7806AAM Stacked Laundry - Gas
Maytag LSG7806AAQ Stacked Laundry - Gas
Maytag LSG7806ABE Stacked Laundry - Gas
Maytag LSG7806ABM Stacked Laundry - Gas
Maytag LSG7806ABQ Stacked Laundry - Gas
Maytag LSG9900 Stacked Laundry - Gas
Maytag LSG9900AAE Stacked Laundry - Gas
Maytag LSG9900AAL Stacked Laundry - Gas
Maytag LSG9900AAW Stacked Laundry - Gas
Maytag LSG9900ABE Stacked Laundry - Gas
Maytag LSG9900ABL Stacked Laundry - Gas
Maytag LSG9900ABW Stacked Laundry - Gas
Maytag LSG9904AAE Stacked Laundry - Gas
Maytag LSG9904AAL Stacked Laundry - Gas
Maytag LSG9904AAM Stacked Laundry - Gas
Whirlpool LSH9264HQ0
Whirlpool LSL9244EQ0
Whirlpool LSL9244EZ0
Whirlpool LSL9345EQ0
Whirlpool LSL9345EQ1
Whirlpool LSL9345EZ0
Whirlpool LSL9345EZ1
Whirlpool LSL9355DQ0
Whirlpool LSL9355EQ0
Whirlpool LSL9355EQ1
Whirlpool LSN1000HQ0
Whirlpool LSN1000HZ0
Whirlpool LSN1000JQ0
Whirlpool LSN1000JQ1
Whirlpool LSN1000JT0
Whirlpool LSN1000JT1
Whirlpool LSN1000KQ0
Whirlpool LSN1000KT0
Whirlpool LSN1000LG0
Whirlpool LSN1000LG1 Automatic Washer
Whirlpool LSN1000LG2 Automatic Washer
Whirlpool LSN1000LG3 Automatic Washer
Whirlpool LSN1000LW0
Whirlpool LSN1000LW1 Automatic Washer
Whirlpool LSN1000LW2 Automatic Washer
Whirlpool LSN1000LW3 Automatic Washer
Whirlpool LSN1000PQ0 Automatic Washer
Whirlpool LSN1000PQ1 Automatic Washer
Whirlpool LSN1000PQ2 Automatic Washer
Whirlpool LSN1000PQ3 Automatic Washer
Whirlpool LSN2000JQ0
Whirlpool LSN2000JQ1
Whirlpool LSN2000JQ2
Whirlpool LSN2000JT0
Whirlpool LSN2000JT1
Whirlpool LSN2000JT2
Whirlpool LSN2000LG0
Whirlpool LSN2000LG1 Automatic Washer
Whirlpool LSN2000LW0
Whirlpool LSN2000LW1 Automatic Washer
Whirlpool LSN2000PG0 Automatic Washer
Whirlpool LSN2000PG1 Automatic Washer
Whirlpool LSN2000PG2 Automatic Washer
Whirlpool LSN2000PG3 Automatic Washer
Whirlpool LSN2000PG4 Automatic Washer
Whirlpool LSN2000PW0 Automatic Washer
Whirlpool LSN2000PW1 Automatic Washer
Whirlpool LSN2000PW2 Automatic Washer
Whirlpool LSN2000PW3 Automatic Washer
Whirlpool LSN2000PW4 Automatic Washer
Whirlpool LSN3000PG0 Automatic Washer
Whirlpool LSN3000PG1 Automatic Washer
Whirlpool LSN3000PG2 Automatic Washer
Whirlpool LSN3000PG3 Automatic Washer
Whirlpool LSN3000PG4 Automatic Washer
Whirlpool LSN3000PW0 Automatic Washer
Whirlpool LSN3000PW1 Automatic Washer
Whirlpool LSN3000PW2 Automatic Washer
  #2 (permalink)
Old 01-05-2013, 02:39 PM
Junior Member
Default
looking at another tread I've pulled out the switch assembly, and got things going by holding the lid switch manually, I cleaned the contacts, put it back together and blew the 1amp fuse. Reading the other thread I saw comment that the switch assembly has it's own fuse(where is it) and what test do I perform to see if the lid switch or the check switch are still good?
  #3 (permalink)
Old 01-05-2013, 03:37 PM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
The lid switch assembly on your washer does not have it's own fuse, it just comes with one when you order a new one. The only fuse is the one you replaced on the left side of the cabinet. You either have a bad lid switch assembly or it's not engaging properly. There are two switches in the assembly, the lid switch and the check switch. It is designed to blow the fuse if the lid switch contacts are stuck closed. If they are stuck closed, as soon as you open the lid, when the check switch opens, a short circuit is placed across the fuse and it blows. A blown fuse prevents the water inlet valves from operating which basically renders the washer inoperable.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Washer repair feevbee Washer Repair 1 08-06-2011 06:00 PM
washer repair maytag 1 yr old speedymp Washer Repair 1 04-05-2011 06:05 PM
Maytag washer repair lisadominguez Washer Repair 1 02-14-2011 06:59 AM
Maytag Washer Repair indianjoe Washer Repair 14 12-16-2010 12:13 PM
Maytag Washer Repair dancnqueen19 Washer Repair 0 06-12-2008 08:01 AM
