Discuss
replaced ccu on whirlpool duet getting f11
 in
Washer Repair
duet washer displayed f11 code after the drain cycle would not spin,turned washer off tried the drain and spin cycle
Appliance Repair Forum > Appliance Repair Help > Washer Repair » replaced ccu on whirlpool duet getting f11
  #1 (permalink)
Old 01-04-2013, 08:54 AM
Junior Member
robin k is on a distinguished road
Unhappy replaced ccu on whirlpool duet getting f11
Model Number: ghw9150pw1   Brand: Whirlpool   Age: 5 - 10 years
duet washer displayed f11 code after the drain cycle would not spin,turned washer off tried the drain and spin cycle would run for 30 sec displayed f11 again and fdl several times,repairman said to replace the ccu,no luck still giving f11 but no door latch code,the door latch is working properly,called him back said to replace the door latch,doI need the door stricker,or the assembly?Could it be a bad mcu? This washer is being a big pain!!!!! Thanks for any adcvice.
Ads By Google
Related Models
Whirlpool GHW9150PW1 Automatic Washer
Whirlpool GHW9150PW2 Automatic Washer
Whirlpool GHW9150PW3 Automatic Washer
Whirlpool GHW9150PW4 Automatic Washer
Whirlpool GHW9160PW0 Automatic Washer
Whirlpool GHW9160PW1 Automatic Washer
Whirlpool GHW9160PW2 Automatic Washer
Whirlpool GHW9160PW3 Automatic Washer
Whirlpool GHW9160PW4 Automatic Washer
Whirlpool GHW9200LQ0
Whirlpool GHW9200LW0
Whirlpool GHW9250ML0 Automatic Washer
Whirlpool GHW9250ML1 Automatic Washer
Whirlpool GHW9250ML2 Automatic Washer
Whirlpool GHW9250MQ0 Automatic Washer
Whirlpool GHW9250MQ1 Automatic Washer
Whirlpool GHW9250MQ2 Automatic Washer
Whirlpool GHW9250MT0 Automatic Washer
Whirlpool GHW9250MT1 Automatic Washer
Whirlpool GHW9250MT2 Automatic Washer
Whirlpool GHW9250MW0 Automatic Washer
Whirlpool GHW9250MW1 Automatic Washer
Whirlpool GHW9250MW2 Automatic Washer
Whirlpool GHW9300PW0 Automatic Washer
Whirlpool GHW9300PW1 Automatic Washer
Whirlpool GHW9300PW2 Automatic Washer
Whirlpool GHW9300PW3 Automatic Washer
Whirlpool GHW9300PW4 Automatic Washer
Whirlpool GHW9400PL0 Automatic Washer
Whirlpool GHW9400PL1 Automatic Washer
Whirlpool GHW9400PL2 Automatic Washer
Whirlpool GHW9400PL3 Automatic Washer
Whirlpool GHW9400PL4 Automatic Washer
Whirlpool GHW9400PT0 Automatic Washer
Whirlpool GHW9400PT1 Automatic Washer
Whirlpool GHW9400PT2 Automatic Washer
Whirlpool GHW9400PT3 Automatic Washer
Whirlpool GHW9400PT4 Automatic Washer
Whirlpool GHW9400PW0 Automatic Washer
Whirlpool GHW9400PW1 Automatic Washer
Whirlpool GHW9400PW2 Automatic Washer
Whirlpool GHW9400PW3 Automatic Washer
Whirlpool GHW9400PW4 Automatic Washer
Whirlpool GHW9400SU0 Automatic Washer
Whirlpool GHW9460PL0 Automatic Washer
Whirlpool GHW9460PL1 Automatic Washer
Whirlpool GHW9460PL2 Automatic Washer
Whirlpool GHW9460PL3 Automatic Washer
Whirlpool GHW9460PL4 Automatic Washer
Whirlpool GHW9460PW0 Automatic Washer
Whirlpool GHW9460PW1 Automatic Washer
Whirlpool GHW9460PW2 Automatic Washer
Whirlpool GHW9460PW3 Automatic Washer
Whirlpool GHW9460PW4 Automatic Washer
Whirlpool GHWT160JXX0
Whirlpool GI1500PHB0
Whirlpool GI1500PHB3
Whirlpool GI1500PHB4 Ice Cube Maker
Whirlpool GI1500PHB5 Ice Cube Maker
Whirlpool GI1500PHB6 Ice Cube Maker
Whirlpool GI1500PHB7 Ice Cube Maker
Whirlpool GI1500PHB8 Ice Cube Maker
Whirlpool GI1500PHW0
Whirlpool GI1500PHW3
Whirlpool GI1500PHW4 Ice Cube Maker
Whirlpool GI1500PHW5 Ice Cube Maker
Whirlpool GI1500PHW6 Ice Cube Maker
Whirlpool GI1500PHW7 Ice Cube Maker
Whirlpool GI1500PHW8 Ice Cube Maker
Whirlpool GI1500XHB0
Whirlpool GI1500XHB1
Whirlpool GI1500XHB2
Whirlpool GI1500XHB3
Whirlpool GI1500XHB4 Ice Cube Maker
Whirlpool GI1500XHB5 Ice Cube Maker
Whirlpool GI1500XHB6 Ice Cube Maker
Whirlpool GI1500XHB7 Ice Cube Maker
Whirlpool GI1500XHB8 Ice Cube Maker
Whirlpool GI1500XHB9 Ice Cube Maker
Whirlpool GI1500XHN0
Whirlpool GI1500XHN1
Whirlpool GI1500XHN2
Whirlpool GI1500XHN3
Whirlpool GI1500XHN4 Ice Cube Maker
Whirlpool GI1500XHS0
Whirlpool GI1500XHS1
Whirlpool GI1500XHS2
Whirlpool GI1500XHS3
Whirlpool GI1500XHS4 Ice Cube Maker
Whirlpool GI1500XHS5 Ice Cube Maker
Whirlpool GI1500XHS6 Ice Cube Maker
Whirlpool GI1500XHS7 Ice Cube Maker
Whirlpool GI1500XHS8 Ice Cube Maker
Whirlpool GI1500XHS9 Ice Cube Maker
Whirlpool GI1500XHT1
Whirlpool GI1500XHT2
Whirlpool GI1500XHT3
Whirlpool GI1500XHT4 Ice Cube Maker
Whirlpool GI1500XHT5 Ice Cube Maker
Whirlpool GI1500XHT6 Ice Cube Maker
Whirlpool GI1500XHT7 Ice Cube Maker
Whirlpool GI1500XHT8 Ice Cube Maker
Whirlpool GI1500XHT9 Ice Cube Maker
Whirlpool GI1500XHW0
Whirlpool GI1500XHW1
Whirlpool GI1500XHW2
Whirlpool GI1500XHW3
Whirlpool GI1500XHW4 Ice Cube Maker
Whirlpool GI1500XHW5 Ice Cube Maker
Whirlpool GI1500XHW6 Ice Cube Maker
Whirlpool GI1500XHW7 Ice Cube Maker
Whirlpool GI1500XHW8 Ice Cube Maker
Whirlpool GI1500XHW9 Ice Cube Maker
Whirlpool GI15NDXTB0 Ice Cube Maker
Whirlpool GI15NDXTB1 Ice Cube Maker
Whirlpool GI15NDXTQ0 Ice Cube Maker
Whirlpool GI15NDXTQ1 Ice Cube Maker
Whirlpool GI15NDXTQO Ice Cube Maker
Whirlpool GI15NDXTS0 Ice Cube Maker
Whirlpool GI15NDXTS1 Ice Cube Maker
  #2 (permalink)
Old 01-06-2013, 11:52 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
This washer is very difficult diagnose and you often have to just replace parts to see if you can find out the problem.
I would replace the MCU and if you buy from this site and the part does not fix the problem you can replace it. See if the tech under the top will help with some testing.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replaced duet sport bellows and now have bigger leak than the old one!! laura s Washer Repair 1 06-10-2012 08:47 AM
Duet replaced ccu now wont run at all fiercefun Washer Repair 7 12-26-2011 09:19 AM
Whirlpool Duet does not drain - replaced pump mberling Washer Repair 1 01-04-2011 10:34 AM
Whirlpool Qt Prtnr II, Replaced Htg Element Does the Control Panel Nd 2 B Replaced? DirtyDishes4Five Dishwasher Repair 1 10-26-2010 02:14 AM
I replaced my pump assembly on my Whirpool Duet!!! frostywashdry Washer Repair 1 04-18-2009 05:27 PM
